Menü im bascom simulator bedienen?!
Hallo...
dies ist das halbfertige programm
$regfile = "m88def.dat" 'Für ATMega88 Mikrokontroller
$framesize = 32
$swstack = 32
$hwstack = 34
$crystal = 8000000
$baud = 19200 'Baud Rate ( 8,N,1 ist default - flow control=NONE)
Rem Dim A As String * 1
Menue:
Rem Menueanfang
Cscreen:
Cls
Dim A As String * 1
Dim B As String * 1
Print "Schnittstelle und Achsen setzen........1"
Print "Referenzfahrt..........................2"
Print "Sonde Fahren...........................3"
Print "Messpunkte per Hand fahren.............4"
Print "Ende Programm..........................5"
Warte:
A = Waitkey()
If B = "" Then Goto Warte
If B = "1" Then Gosub Achse
If B = "2" Then Gosub Referenzfahrt
If B = "3" Then Gosub Fahren
If B = "4" Then Gosub Hand
If B = "0" Then Gosub Cscreen
Print "End Programm"
End 'end program
Rem Messfahrt durchfuehren
Fahren:
Print "@0M 50000,2000,5000,10000,2000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,5000,5000,10000,2000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,1000,5000,10000,2000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,4000,5000,10000,10000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,7000,5000,10000,10000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,2000,5000,10000,20000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,1000,5000,10000,20000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
Print "@0M 50000,10000,5000,10000,20000,1000,0,30"
A = Waitkey()
Print A
Rem Wait 1
A = Waitkey()
Print A
Rem Wait 1
Print "@0r7"
A = Waitkey()
Print A
Print "@0g0"
A = Waitkey()
Print A
Return
Achse:
Print "@07"
A = Waitkey()
Print A
Return
Referenzfahrt:
Print "@0d20000,20000,20000,20000"
A = Waitkey()
Print A
Print "@0r7"
A = Waitkey()
Print A
Print "@0g1"
A = Waitkey()
Print A
Return
Rem daten von tastatur eingeben
Hand:
Cls
Print "Weg von Hand in die Tastatur eingeben"
Print "Positive Bewegungen finden in der Richtung vom Motor weg statt"
Input "x in mm" ; "X"
Input "y in mm" ; "Y"
Input "z in mm" ; "Z"
Nun möchte ich über das menü die einzelenen labels ansteuern aber immer wenn ich im simulator in das blaue feld eine zahl eingebe die das label beschreibt kommt er aus der waitkeyschleife nach dem menü nicht raus. Nun meine frage: Muss ich irgendwas beachten bei der eingabe oder kann ich einfach in das blaue feld klicken wo das meü dann zu sehen ist und die zahl eingeben oder geht dies nicht und wie würde es sonst gehen?
Würde mich über Hilfe sehr freuen.
