The Introduction of Digital Electronic Clock Temperature Voltage Module for Arduino S
Hello friends, today I introduce this wonderful digital electronic clock module from http://www.icstation.comin details. This product is developed by ICStation Team recently.We share it to you and welcome all friend to evaluate this product.With your kind suggestions, ICStation team will be better.And this product will be sold on our website in the near future and then we will provide you the product link. Hope all of you will like it a lot!
Anhang 27627
Applicable Occasions:
Electronic calendar 2.Digital clock 3. Environment temperature detection
Features:
1.5 different kinds of display mode:
(1) only show time(2) only show the date (3) only show the temperature (4) only show voltage (5) time, temperature alternating display
2..Use DS1302 clock module to provide accurate time.You can set or adjust the time.With CR927 backup battery,when power off, time goes on.
3..The module can be used as a voltmeter to measure voltage(the input voltage must be more than 7V).
4..The module can measure the temperature where it works.
5..This module small,exquisite and takes up little space. (Long:40 mm wide:13 mm high:17 mm)
6.This module can display clearly in the bright place because of good digital tube.
7.With the function of 24 hours timing error correction settings.
Anhang 27628
If you want to know more details, please click the link:http://www.instructables.com/id/The-...c-Clock-Tempe/
