ok, der erster versuch...
ich habe nun den folgenden code in die asuro.c eingefügt:
/*****************ultrasonic********************************/
* being used insted TIMER2_OVF_vect during ultrasonic polling
ISR(TIMER2_COMP_vect)
TCNT2 += 0x25;
count36kHz++;
if(!count36kHz) timebase++;
* initialises the Ultrasonic module
* this function is automaticly called by Chirp
void InitUltrasonics(void)
// Change Oscillator-frequency of Timer 2
// to 40kHz, no toggling of IO-pin:
TCCR2 = (1 << WGM21) | (1 << CS20);
OCR2 = 100; // 40kHz @8MHz crystal
TIMSK |= (1 << OCIE2); // OCIE2: Timer/Counter2 Output Compare Match Interrupt Enable
ADCSRA = (0 << ADEN); // deactivate ADC
ACSR |= (1 << ACIS1); // Comparator Interrupt on Falling Output Edge
ADMUX = 0x03; // connect ADC3-input with comparator
SFIOR |= (1 << ACME); // connect ADC multiplexer to comparator
DDRD &= ~(1 << 6); // use Port D Pin 6 as input (AIN0)
* restores the hardware after using the Ultrasonic module
* this function is called automaticly after a Chirp
void RestoreAsuro(void)
TCCR2 = (1 << WGM20) | (1 << WGM21) | (1 << COM20) | (1 << COM21) | (1 << CS20);
OCR2 = 0x91; // duty cycle for 36kHz
TIMSK |= (0 << OCIE2); // OCIE2: Timer/Counter2 Output Compare Match Interrupt Enable
ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1); // clk/64
ACSR |= (0 << ACIS1);
if(autoencode) {
EncoderInit();
Sleep(1);
* @return distance in cm
int Chirp(void)
unsigned int sleeptime = 0, dist = 0;
InitUltrasonics();
// chripen:
count36kHz = 0;
while(count36kHz != 20) {
OCR2 = 100 + 20 / 2 - count36kHz;
OCR2 = 100;
// analyse echoes:
while(TRUE) {
Sleep(1);
sleeptime++;
if((ACSR & (1 << ACI))) {
dist = (unsigned int) ((long) ((344L * ((sleeptime * 1000L) / 72L) / 10000L) / 2L));
ACSR |= (1 << ACI);
break;
ACSR |= (1 << ACI);
if(sleeptime > 3500) {
return -1;
RestoreAsuro();
return dist;
aufgerufen wird es durch:
#include "asuro.h"
int main(void)
Init();
SerWrite("\r\n --- georgs ultrasonic test ---",35);
Msleep(1000);
StatusLED(OFF);
do
Chirp();
SerWrite("\r\n distanz in cm: ",30);
Msleep(500);
PrintInt(dist);
while(1);
return 0;
das ergebnis beim kompilieren sieht nicht so furchtbar schlecht aus:
../ultrasonic.c: In function `main':
../ultrasonic.c:16: warning: implicit declaration of function `Chirp'
../ultrasonic.c:19: error: `dist' undeclared (first use in this function)
../ultrasonic.c:19: error: (Each undeclared identifier is reported only once
../ultrasonic.c:19: error: for each function it appears in.)
make: *** [ultrasonic.o] Error 1
Build failed with 3 errors and 1 warnings...
aber trotzdem scheint es irgendwo zu klemmen. Könnte mir jemnad einen tipp geben welche datei denn noch irgendwo fehlt? benutzt habe ich die lib 2.7., habe vorsichtshalber alle parts als sources eingefügt (entfernen kann ich sie nach erfolgreichem kompilieren probeweise ja immer noch...)
danke...
