Du teilst falsch. Du musst die Bildbreite durch die array Länge teilen, nicht umgekehrt.
sind noch weitere Änderungen im Code drin.Code:#include <iostream>
#include <vector>
#include <fstream>
#include <string>
#include <stdio.h>
#include <limits.h>
#include <math.h>
#include <VG/openvg.h>
#include <VG/vgu.h>
#include <fontinfo.h>
#include <shapes.h>
#include "diaSound.hpp"
#define BLACK 0, 0, 0
#define WHITE 255, 255, 255
#define MAGENTA 255, 0, 255
#define RED 255, 0, 0
#define YELLOW 255, 255, 0
#define LIME 0, 255, 0
#define GREEN 0, 128, 0
#define CYAN 0, 255, 255
#define AQUA 102, 204, 204
#define BLUE 0, 0, 255
int _width_=1024, _height_=600;
int _fontsize_ = 10;
bool ausgabe = true;
void initOpenVG()
initWindowSize(0, 0, _width_, _height_);
init(&_width_, &_height_);
Start(_width_, _height_);
Background(0, 0, 0);
StrokeWidth(1.0);
WindowClear();
void plotArray(int32_t *array, int32_t arrlength, int y0)
float xscale=1.0, border=100.0;
xscale = _width_ / (float) (arrlength-border);
int i;
Fill(CYAN, 1);
Stroke(0, 255, 255, 1);
for(i=0;i<arrlength;i++)
Line((VGfloat)xscale*i, (VGfloat) y0, (VGfloat)xscale*i, (VGfloat)(y0+array[i]));
End();
void analyse(int32_t *array, int32_t arrlength)
int32_t sbuf[128];
int32_t bias, minr, maxr, baseline,
signalstart, signalend;
int32_t maximum = array[0];
int32_t minimum = array[0];
int32_t maxpos, minpos;
int32_t i;
if(array[i] > maximum)
maximum = array[i];
maxpos = i;
if(array[i] < minimum)
minimum = array[i];
minpos = i;
maximum = array[0];
minimum = array[0];
for(i=0;i<arrlength; ++i)
maximum = array[i];
maxpos = i;
minimum = array[i];
minpos = i;
// calculate baseline from last 100 array cells:
// init vars
baseline=(array[minpos] + array[maxpos]) / 2; // init baseline by (min+max)/2
minr=baseline - 1;
maxr=baseline + 1;
// auto-adjust:
for(i=arrlength-100; i<arrlength; ++i)
// mean baseline
baseline = round((0.5*(float)array[i] + 0.5*(float)baseline)) ;
// smoothed out max noise
if(array[i] >= baseline) maxr = round((0.6*(float)array[i] + 0.4*(float)maxr)) +1 ;
// smoothed out min noise
if(array[i] <= baseline) minr = round((0.6*(float)array[i] + 0.4*(float)minr)) -1 ;
bias = max(baseline-minr, maxr-baseline) +1;
// noise reduction start/end
// drop small noise
for(i=0;i<arrlength;++i)
if((array[i]>baseline) && (array[i] <= baseline + bias)) array[i] = baseline ; // little higher value => drop to baseline
else
if((array[i]<baseline) && (array[i] >= baseline - bias)) array[i] = baseline ; // little lower value => rise to baseline
// signalstart, signalend: threshold = bias + (bias/2)
signalstart = 0;
i = 0;
while((array[i]<=baseline + 4 * bias/3) && (i<SHRT_MAX-1)) ++i;
signalstart = i;
if(i > 0) signalstart -= 1;
signalend=arrlength-1;
i=arrlength-1;
while((array[i]<=baseline + + 4*bias/3) && (i>signalstart)) --i;
signalend = i;
if(i<arrlength-1) signalstart +=1;
if(ausgabe)
cout << "Bias: " << bias << endl;
cout << "Maximal: " << maximum << endl;
cout << "Minimal: " << minimum << endl;
cout << "Signalstart: " << signalstart << endl;
cout << "Signalende: " << signalend << endl;
int main(int argc, char *argv[])
fstream datei;
int32_t waveBuffer[SHRT_MAX];
int32_t i;
char s[3];
initOpenVG();
if(argc <= 1) audioCapture(waveBuffer, SHRT_MAX, "plughw:1,0", 1, 12000, 8);
else
datei.open(argv[1], ios::in);
for(i=0;i<SHRT_MAX;++i)
datei >> waveBuffer[i];
datei.close();
for(i=0;i<SHRT_MAX;i++)
waveBuffer[i] = waveBuffer[i] & 0x00ff;
plotArray(waveBuffer, SHRT_MAX, 0);
analyse(waveBuffer, SHRT_MAX);
plotArray(waveBuffer, SHRT_MAX, 255);
if(ausgabe)
uint8_t *wave;
wave = (uint8_t *) malloc(SHRT_MAX+1);
for(i=0;i<SHRT_MAX;i++) wave[i] = waveBuffer[i];
playCaptured(wave, SHRT_MAX, "plughw:1,0", 1, 12000, 8);
free(wave);
fgets(s, 2, stdin);
SaveEnd("plott.raw");
finish();
return 1;
