Doch da war ein Beispielprogramm dabei, doch da zeigt bascom mir auch nur fehler an.
' (c) 2004 MCS Electronics
' This demo shows an example of the TWI in SLAVE mode
' Not all AVR chips have TWI (hardware I2C)
$regfile = "M32def.dat"
$crystal = 16000000
$baud = 9600
Print "MCS Electronics TWI-slave demo"
#if _build >= 11175
Config Twislave = &H70 , Btr = 1 , Bitrate = 100000
' the code below #else is executed by the compiler when you use version 11175 or higher
#else
'as this is available in 1.11.7.5 some manual work mus tbe done
$lib "i2c_twi-slave.lbx" ' include
$external _twi_slave 'include code from the lib
Const _twisdaport = Portd
Const _twisclport = Portd
Const _twisdaddr = Ddrd
Const _twisclddr = Ddrd
Const _twisda = 1
Const _twiscl = 0
Const Twi_cbtr = 1 'how many bytes we will receive
Dim Twi As Byte , Twi_btr As Byte
rcall _twi_init
Twbr = 12 'bit rate register
Twsr = 0
Twar = &B01110000 ' own slave address
Twcr = &B01000101 'general call not enabled
On Twi _twi_slave_isr Nosave
Enable Twi
#endif
'as you might need other interrupts as well, you need to enable them manual
Enable Interrupts
'this is just an empty loop but you could perform other tasks there
nop
End
'A master can send or receive bytes.
'A master protocol can also send some bytes, then receive some bytes
'The master and slave must match.
'the following labels are called from the library
Twi_stop_rstart_received:
Print "Master sent stop or repeated start"
Return
Twi_addressed_goread:
Print "We were addressed and master will send data"
Return
'this label is called when the master sends data and the slave has received the byte
'the variable TWI holds the received value
Twi_gotdata:
Print "received : " ; Twi
Return
'this label is called when the master receives data and needs a byte
'the variable twi_btr is a byte variable that holds the index of the needed byte
'so when sending multiple bytes from an array, twi_btr can be used for the index
Twi_master_needs_byte:
Print "Master needs byte : " ; Twi_btr
Twi = 65 ' twi must be filled with a value
Return
'when the mast has all bytes received this label will be called
Twi_master_need_nomore_byte:
Print "Master does not need anymore bytes"
Return
schau mal unter:
https://www.roboternetz.de/phpBB2/vi...3c667e62a79bba
da steht ja ein Beispiel zum Slave.
Die Slave LIB braucht man für die ganzen Tinys die ja kein hardware TWI haben. Der M8 Ist da irgendwie eine Ausnahme.
Der M8 hat ja Hardware TWI, geht aber auch mit der Slave LIB.
Die größeren Megas gehen wohl dann nur mit dem Hardware TWI als Slave.
Gruß RePi!
