Mein Vorposter hat doch schon geschrieben :
Unter http://www.rowalt.de/mc/ gibts ne kleine Einführung in Bascom!
Wer lesen kann ist besser dran. Lese die Seiten durch und melde dich d a n n nochmal. :-)
Gruss
Gruss
ok danke jetzt hab ich das endlich gefunden
Hallo Vish!Zitat:
Zitat von vish
Ich habe mir BASCOM einmal in der Demo-Version heruntergeladen, es gehen neuerdings anscheinend auch 4kB Code.
Auszug aus der Lizenzvereinbarung:
Code:Thank you for trying this DEMO of BASCOM-AVR
This file contains some additional info on BASCOM-AVR.
This demo can compile up to 4096 bytes of code, when you have more code, you
will receive an error.
The commercial version is available for : 79 euro.
Support and updates are free for the commercial version.
It is the intention of MCS Electronics to keep updates free.
In the future, support might be a paid service, while updates remain free.
But again, the intention is to keep it free.
There is no support for this DEMO other than when you encounter
problems during installation.
There is a forum at www.mcselec.com/forum with members that can help you.
The DEMO may not be used to created commercial devices.
Have fun,
Mark Alberts
MCS Electronics
*************** IMPORTANT ***********************
When you don't see the pictures of the buttons in the IDE you need to install
a newer version of the comctl32.dll.
You can download the file 40comupd.exe from microsoft,or from MCS.
When you get an Error 123 you probably don't have a printer installed
Install a printer driver (HP Laserjet 4 for example) and run again.
There does not need to be a printer connected, only as printer created.
When you get an OleSysError, reboot Windows and run SETUP again.
After rebooting again, run BASCOM again.
When you install the software on a NT machine you need administrator rights
during SETUP. You also must run BASCOM once as an administrator so that the
ioport.sys driver will be setup. After this you can use the software logged on
as a normal user without administation rights.
- If you run into problems send an email to support@mcselec.com
with the problem and all the generated file of your project(rpt,cfg,bas,bin,etc.)
Please specify that your version is the DEMO version.
- Check out the sample files which contain info on the syntax.
The samples are a bit simple and only intended to show the syntax of the commands.
Some samples require a specific chip or more code then the DEMO can create.
You will get errors then at compile time.
While the demo is restricted, it allows you to work with the smaller chips and to try
all functions.
The DEMO is ideal for educational institutes as you only need some cheap hardware.
As we do not earn money on the demo, we do not give support, or limited support.
Customers are helped first, then DEMO users are helped if there is time.
The last restriction on the DEMO is that it does not come with the LIB Assembler code.
The LIB assem code only comes with the full version.
Grüsse Wolfgang
Hallo Wolfgang!
Davon weiß ich ja noch gar nichts! Welche Version benutzt du denn?
Ich habe Version 1.11.7.4, dort bin ich noch auf 2048 Bytes beschränkt.
Grüsse zurück,
Jonas
Ich hab die aktuellste Version 1.11.7.7 downgeloadet, da sind es dann 4kB Code anstatt der bisherigen 2kB...Zitat:
Zitat von vish
Also holen! :-)
Grüsse Wolfgang
Was hat sich denn noch mit den neueren Versionen geändert?
MFG Moritz
Hallo RCO!
Das kann ich dir nicht genau sagen, ich habe mir nur aus Interesse BASCOM geladen, ich programmier AVR oder andere Dinge auser der CC nicht in BASIC, wollte es mir nur auch einmal mit ansehen. Aber was brauchst du für Informationen? Frag einfach mal wichtige Dinge, ich kanns ja nachsehen, einen Vergleich kann ich selbst jedoch nicht durchführen da ich eine alte Version nicht besitze.
Grüsse Wolfgang
Nachtrag: Die Samples als Info?
Die Libraries:Code:
Datentr„ger in Laufwerk C: SYSTEM
Seriennummer des Datentr„gers: 1946-16D4
Verzeichnis von C:\Programme\MCS Electronics\BASCOM-AVR\SAMPLES
. <DIR> 05.01.05 21:18 .
.. <DIR> 05.01.05 21:18 ..
LAWICEL <DIR> 05.01.05 21:18 Lawicel
123 BAS 287 09.04.00 23:07 123.BAS
BOOT128 INC 10.014 29.05.03 23:52 boot128.inc
SMALLF~1 FON 834 16.08.02 0:34 smallfont8x8.font
FONT8X~1 FON 6.547 03.10.03 15:04 font8x8.font
CHR BAS 406 05.01.03 2:02 CHR.BAS
APN3 BAS 3.678 05.01.03 1:59 APN3.BAS
$INC BAS 784 21.07.03 12:47 $inc.bas
$SERIA~1 BAS 2.268 05.01.03 1:58 $serialinput.bas
1200 BAS 318 05.07.03 16:02 1200.bas
1WIRE BAS 2.362 05.01.03 1:58 1wire.bas
1WIRED~1 BAS 10.642 03.02.03 15:26 1wireDS2450.bas
1WIRES~1 BAS 2.237 05.01.03 1:58 1wireSearch.bas
A_RENAME BAS 22 09.04.00 20:28 a_rename.bas
ADC BAS 1.531 02.05.04 21:52 adc.bas
ADC_INT BAS 1.745 02.05.04 21:52 adc_int.bas
APPNT1 BAS 1.435 05.01.03 1:59 APPNT1.BAS
ARRAY BAS 936 05.01.03 1:59 Array.bas
AT86RF~1 BAS 2.022 03.07.03 11:54 AT86RF401_1.bas
AT86RF~2 BAS 1.325 03.07.03 23:54 AT86RF401_2.bas
AT86RF~3 BAS 1.953 01.07.03 13:10 AT86RF401_3.bas
BIN2BC~1 BAS 640 31.10.00 0:58 bin2bcd16.bas
ATTINY13 BAS 119 28.09.04 21:26 attiny13.bas
BARCODE BAS 3.739 05.01.03 1:59 barcode.bas
BASMON BAS 3.876 24.08.04 21:50 basmon.bas
BCD BAS 2.119 05.12.02 23:33 bcd.bas
BCH_FN~1 BAS 17.455 06.05.02 0:33 bch_fnc_zeh.bas
BG30DB~1 BAS 8.831 03.07.01 23:29 BG30dB_LCD.bas
BG30DB~2 BAS 8.052 03.07.01 23:29 BG30dB_LED.bas
BITS-N~1 BAS 712 09.10.04 22:31 bits-nbits.bas
BOOLEAN BAS 1.654 05.01.03 2:01 Boolean.bas
BOOT BAS 7.920 08.01.02 0:20 boot.bas
BOOT128 BAS 9.750 28.07.02 12:00 boot128.bas
BOOT128X BAS 1.624 30.05.03 0:18 boot128x.bas
BOOTM8 BAS 13.910 24.01.03 16:04 BootM8.bas
BOOTM8V BAS 16.343 29.04.04 21:29 BootM8V.bas
BOOTNEW BAS 564 30.05.03 0:10 bootnew.bas
DELAY BAS 629 05.01.03 2:03 DELAY.BAS
CONST BAS 975 05.01.03 2:02 CONST.BAS
CAPTURE BAS 2.922 14.09.02 17:05 capture.bas
CASE BAS 630 05.01.03 2:01 Case.bas
CIRCLE BAS 1.106 16.04.02 13:19 circle.bas
CLIENT~1 BAS 4.206 01.01.03 23:26 clienttest.bas
CLOCK BAS 3.895 18.10.02 0:41 Clock.bas
CLOCKENG BAS 14.048 24.04.03 10:18 clockeng.bas
CONFIG~1 BAS 6.207 20.05.03 9:51 CONFIG_AVR-DOS.bas
CONFIG~2 BAS 2.278 01.05.03 0:03 Config_FlashCardDrive.bas
CONFIG~3 BAS 1.931 02.05.03 8:43 Config_FlashCardDrive_EL_PIN.bas
CONFIG~4 BAS 365 02.05.03 8:43 Config_XRAMDrive.bas
DATETI~1 BAS 13.448 08.12.02 21:49 DateTime_Test1.bas
DEBOUN BAS 967 07.10.99 0:59 Deboun.bas
DECLARE BAS 3.883 05.01.03 2:02 Declare.bas
DECR BAS 519 05.01.03 2:02 DECR.BAS
STRINGS BAS 3.732 05.01.03 2:16 STRINGS.BAS
SINGLE BAS 1.636 05.01.03 2:15 SINGLE.BAS
DIM BAS 1.156 05.01.03 2:03 DIM.BAS
DO_LOOP BAS 795 05.01.03 2:03 DO_LOOP.BAS
DOUBLE1 BAS 4.645 27.11.04 22:41 double1.bas
DOUBLE2 BAS 1.779 27.11.04 22:54 double2.bas
DS1307 BAS 3.455 13.11.02 23:29 ds1307.bas
DS1620 BAS 9.790 05.01.03 2:03 DS1620.BAS
DS2405 BAS 1.268 05.01.03 2:04 ds2405.bas
DT006_1 BAS 1.989 05.01.03 2:04 DT006_1.bas
DT104 BAS 793 22.12.99 0:57 dt104.bas
DTMFOUT BAS 1.731 01.09.01 1:05 dtmfout.bas
EEPROM BAS 2.078 18.11.00 0:54 EEPROM.BAS
EEPROM2 BAS 1.995 01.10.03 21:45 EEPROM2.bas
ENCODER BAS 1.382 14.03.04 22:42 Encoder.bas
EXIT BAS 684 05.01.03 2:04 EXIT.BAS
FLASHC~1 BAS 12.488 29.05.03 2:15 FlashCard-demo.bas
FLASHD~1 BAS 2.634 11.05.03 2:43 FlashDisk.bas
FOR_NEXT BAS 745 05.01.03 2:04 FOR_NEXT.BAS
FORMAT BAS 479 05.01.03 2:05 format.bas
FS_SUB~1 BAS 8.142 07.05.03 9:00 FS_SubFunc_Decl_lib.bas
FUNCTION BAS 1.182 05.01.03 2:05 Function.bas
FUSING BAS 962 05.01.03 2:05 fusing.bas
FUTUTE~1 BAS 833 07.02.02 0:20 fututelec8535.bas
GETATKBD BAS 3.711 13.09.03 22:09 getatkbd.bas
GETATK~1 BAS 4.844 28.08.03 14:24 getatkbd_int.bas
GETKBD BAS 794 05.01.03 2:05 getkbd.bas
GETRC BAS 1.200 05.03.00 2:46 getrc.bas
GOSUB BAS 675 05.01.03 2:06 GOSUB.BAS
GREYCODE BAS 769 05.01.03 2:06 greycode.bas
I2C BAS 3.309 05.01.03 2:06 I2C.BAS
I2CSLA~1 BAS 5.039 14.02.03 23:38 i2cslave_pcf8574.bas
IDLE BAS 1.227 05.01.03 2:06 idle.bas
IF_THEN BAS 1.123 05.01.03 2:06 IF_THEN.BAS
INCLUDE BAS 462 05.01.03 2:06 INCLUDE.BAS
INCR BAS 465 05.01.03 2:06 INCR.BAS
INITMI~1 BAS 780 09.10.04 22:25 initmicro.bas
INKEY BAS 1.047 05.01.03 2:07 Inkey.bas
INPUT BAS 1.141 05.01.03 2:07 INPUT.BAS
INSTR BAS 698 05.01.03 2:07 instr.bas
INT0 BAS 1.318 05.01.03 2:07 INT0.BAS
INTERP~1 BAS 51.171 12.05.03 13:42 Interpreter.bas
KS108 BAS 2.565 03.10.03 14:56 KS108.bas
LCD BAS 4.803 07.05.04 22:53 LCD.BAS
LCD_I2~1 BAS 5.915 06.08.02 19:22 lcd_i2c_demo.bas
LCD4 BAS 113 29.07.01 1:09 lcd4.bas
LCD4BUSY BAS 767 05.01.03 2:09 lcd4busy.bas
LCDCUS~1 BAS 412 16.03.01 23:28 lcdcustom4bit.bas
LCDCUS~2 BAS 651 17.03.01 0:15 lcdcustom4bit2e.bas
LCDSTK~1 BAS 4.566 05.01.03 2:09 LcdSTK200.bas
LIBDEMO BAS 692 05.01.03 2:09 libDEMO.bas
LONG BAS 1.238 05.01.03 2:09 LONG.BAS
LOOKDOWN BAS 996 05.01.03 2:10 lookdown.bas
LTC1257 BAS 593 05.01.03 2:10 ltc1257.bas
M128 BAS 1.693 13.05.03 23:17 m128.bas
M128103 BAS 649 30.03.02 0:44 m128103.bas
M128CAN BAS 572 24.11.04 23:28 m128CAN.bas
M16 BAS 1.969 18.11.02 0:58 M16.bas
M161 BAS 1.006 05.01.03 2:10 M161.bas
M162 BAS 1.691 10.10.03 0:02 M162.bas
M163 BAS 524 13.03.03 0:12 M163.bas
M169_LCD BAS 3.050 29.09.04 21:11 m169_LCD.bas
M32 BAS 976 20.07.04 22:50 m32.bas
M323 BAS 413 16.04.02 12:26 m323.bas
M64 BAS 1.519 31.05.03 22:27 m64.bas
M8515 BAS 524 13.03.03 0:13 M8515.bas
M8535 BAS 554 13.03.03 0:26 M8535.bas
M8-TWI~1 BAS 2.365 10.07.04 22:14 M8-TWI-master.bas
M8-TWI~2 BAS 3.322 07.11.04 1:05 M8-TWI-slave.bas
MAGCARD BAS 2.062 05.01.03 2:11 magcard.bas
MEGA48 BAS 1.365 22.11.04 0:42 mega48.bas
MEGA8 BAS 575 04.11.03 0:21 mega8.bas
MEGA88 BAS 1.709 23.11.04 23:42 mega88.bas
MEGACL~1 BAS 2.144 02.06.03 22:06 megaclock.bas
MINMAX BAS 818 07.05.04 21:59 minmax.bas
MODBUS~1 BAS 4.378 05.01.03 2:11 modbus slave.bas
ONGOSUB BAS 738 05.01.03 2:12 ONGOSUB.BAS
OPEN BAS 2.209 05.01.03 2:12 open.bas
PEEK BAS 1.050 05.01.03 2:12 PEEK.BAS
PORT BAS 2.001 05.01.03 2:12 PORT.BAS
POWER BAS 465 05.01.03 2:12 POWER.BAS
PRINT BAS 1.231 05.01.03 2:12 PRINT.BAS
PS2_EMUL BAS 1.684 18.03.03 0:01 ps2_emul.bas
PS2_KB~1 BAS 1.640 30.12.02 23:29 ps2_kbdemul.bas
RC5 BAS 1.533 05.01.03 2:12 rc5.bas
READDATA BAS 1.639 05.01.03 2:13 READDATA.BAS
RND BAS 585 13.02.00 23:19 rnd.bas
ROTATE BAS 1.131 20.06.99 2:44 rotate.bas
ROUND_~1 BAS 347 05.05.02 1:52 round_fix_int.bas
RS232B~1 BAS 1.846 05.01.03 2:13 rs232buffer.bas
RS232B~2 BAS 1.953 05.01.03 2:13 RS232BUFFER1.BAS
RS232B~3 BAS 723 05.05.02 23:52 rs232bufferOut.bas
RS232B~4 BAS 904 05.05.02 23:54 RS232BUFFEROUT1.BAS
SED BAS 2.318 20.06.04 22:56 sed.bas
SED1520 BAS 2.024 20.06.04 22:56 SED1520.bas
SENDRC5 BAS 819 05.01.03 2:13 sendrc5.bas
SENDRC6 BAS 987 05.01.03 2:14 sendrc6.bas
SENDSPI BAS 1.153 27.04.02 22:52 sendspi.bas
SERIN_~1 BAS 1.444 10.10.04 21:31 serin_out.bas
SERINT BAS 2.580 05.01.03 2:14 serint.bas
SERVER~1 BAS 4.881 01.01.03 23:34 servertest.bas
SERVOS BAS 1.426 09.04.03 16:22 servos.bas
SHIFT BAS 1.665 12.02.00 0:49 shift.bas
SHOWPICE BAS 1.362 16.04.02 10:50 showpicE.bas
SHT11_~1 BAS 3.893 08.06.02 3:51 SHT11_Bascom.bas
SIMM100 BAS 914 30.10.00 1:20 simm100.bas
SINGLE~1 BAS 7.363 06.05.01 12:58 SinglePID.bas
SMS BAS 6.087 05.01.03 2:15 sms.bas
SONYSEND BAS 558 05.01.03 2:15 sonysend.bas
SOUND BAS 666 05.01.03 2:15 Sound.bas
SPI BAS 142 27.01.04 0:22 spi.bas
SPI-SL~1 BAS 1.812 11.11.01 18:01 spi-slave.bas
PS2_EMUL ERR 195 05.01.05 21:22 PS2_EMUL.ERR
EEPROM EEP 5 22.02.01 1:25 EEPROM.EEP
SPI-SO~1 BAS 2.412 05.01.03 2:15 spi-softslave.bas
STACK BAS 1.487 03.02.02 22:51 stack.bas
STK500~1 BAS 332 29.07.01 0:56 stk500print.bas
SWAP BAS 710 05.01.03 2:16 SWAP.BAS
T6963_~1 BAS 3.870 05.01.03 2:16 t6963_240_128.bas
T6963V3 BAS 2.538 14.05.03 8:28 t6963v3.bas
TCPIP BAS 2.679 25.12.02 1:25 tcpip.bas
TEST_F~1 BAS 4.156 05.07.03 16:08 Test_FPTrig2.bas
TIMEOUT BAS 770 10.10.04 22:13 timeout.bas
TIMER0 BAS 2.198 09.07.00 0:25 timer0.bas
TIMER1 BAS 2.545 14.09.02 17:06 timer1.bas
TINY15 BAS 121 16.08.03 22:09 tiny15.bas
TINY26 BAS 479 26.09.04 0:16 tiny26.bas
TWI-MA~1 BAS 2.014 11.10.04 0:16 TWI-master.bas
TWI-SL~1 BAS 3.260 11.10.04 0:33 TWI-slave.bas
UDPTEST BAS 5.336 01.01.03 23:13 udptest.bas
WATCHD BAS 696 03.05.04 22:23 WATCHD.BAS
WEBSER~1 BAS 11.005 03.01.03 3:42 webserver.bas
WHILE_W BAS 694 05.01.03 2:17 WHILE_W.BAS
X10 BAS 1.495 06.06.03 0:11 x10.bas
XRAM BAS 1.075 05.01.03 2:17 XRAM.BAS
KS108 BGF 570 28.09.03 16:22 KS108.bgf
MCS BGF 1.086 02.12.02 20:50 mcs.bgf
SMILE BGF 145 11.08.02 22:17 smile.bgf
MCS BMP 2.110 14.10.00 1:49 mcs.bmp
EEPROM2 EEP 46 01.10.03 21:44 EEPROM2.EEP
SHOWPICE EEP 621 16.04.02 10:44 SHOWPICE.EEP
FONT16~1 FON 8.688 03.10.03 14:54 font16x16.font
BASAVR LOG 37 05.01.05 21:22 basavr.log
SINGLE~1 OBJ 8.558 05.01.05 21:24 SINGLEPID.OBJ
SINGLE~1 RPT 49.646 05.01.05 21:24 SINGLEPID.RPT
SINGLE~1 SMX 13 05.01.05 21:24 SINGLEPID.SMX
SINGLE~1 HEX 5.311 05.01.05 21:24 SINGLEPID.HEX
SINGLE~1 BIN 1.882 05.01.05 21:24 SINGLEPID.BIN
SINGLE~1 DBG 8.828 05.01.05 21:24 SINGLEPID.DBG
SINGLE~1 SIM 324 05.01.05 21:25 SINGLEPID.SIM
INFO TXT 0 06.01.05 9:50 info.txt
DIT BAT 16 06.01.05 9:50 dit.bat
204 Datei(en) 611.724 Bytes
3 Verzeichnis(se) 15.979,28 MB frei
Verzeichnis von C:\Programme\MCS Electronics\BASCOM-AVR\LIB
AVR-DOS LBX 62.638 26.11.04 17:35 AVR-DOS.LBX
CF_EMB~1 LIB 9.768 20.04.04 10:31 CF_EmbedSysXRAM.LIB
CF_EMB~1 LBX 6.004 20.04.04 10:32 CF_EmbedSysXRAM.LBX
SQR LBX 2.573 06.05.02 0:50 SQR.LBX
BCD LBX 736 11.03.02 21:46 bcd.LBX
DATETIME LBX 11.090 26.06.04 21:53 datetime.LBX
DOUBLE LBX 36.221 20.10.04 10:55 Double.LBX
EDTP_X~1 LBX 6.130 03.11.03 0:19 EDTP_XRAMDrive0.LBX
EDTP_X~1 LIB 10.165 15.10.03 9:07 EDTP_XRAMDrive0.lib
EUROTI~1 LBX 1.182 07.05.02 22:36 eurotimedate.LBX
FLASHC~1 LBX 3.680 21.06.03 14:08 FlashCardDrive.LBX
FLASHC~1 LIB 8.227 21.06.03 14:08 FlashCardDrive.lib
FLASHC~2 LBX 4.937 21.06.03 14:08 FlashCardDrive_EL_PIN.LBX
FLASHC~2 LIB 9.925 21.06.03 14:08 FlashCardDrive_EL_PIN.lib
FLASHC~3 LBX 4.082 26.11.04 17:33 FlashCardDrive_MMC.LBX
FP_TRIG LBX 15.752 14.11.04 11:42 FP_Trig.LBX
GLCD LBX 7.673 02.12.02 20:48 glcd.LBX
GLCDKS~1 LBX 5.541 03.10.03 15:15 glcdKS108.LBX
GLCDSED LBX 5.288 17.05.03 17:21 glcdSED.LBX
GLCDSE~1 LBX 5.271 29.10.03 22:39 glcdSED1520.LBX
I2C LBX 3.509 24.12.04 23:44 i2c.LBX
I2C_TWI LBX 2.421 04.07.04 11:18 i2c_TWI.LBX
LCD_BU~1 LBX 1.604 11.05.04 23:46 lcd_butterfly.LBX
LCD4 LBX 1.235 11.03.02 21:47 lcd4.LBX
LCD4BUSY LBX 2.236 06.05.02 0:54 lcd4busy.LBX
LCD4E2 LBX 1.604 11.03.02 21:48 lcd4e2.LBX
MCS LBX 54.355 13.12.04 23:28 mcs.lbx
MCSBYTE LBX 1.673 06.05.02 0:50 mcsbyte.LBX
MCSBYT~1 LBX 2.680 06.05.02 0:50 mcsbyteint.LBX
MODBUS LBX 339 11.03.02 21:48 modbus.LBX
MYLIB LBX 241 11.03.02 21:48 mylib.LBX
MYLIB LIB 3.150 10.03.02 1:46 mylib.lib
NE2000 LBX 11.694 02.02.03 22:43 ne2000.LBX
SPISLAVE LBX 1.390 27.04.02 23:53 spislave.LBX
TCPIP LBX 18.576 05.07.04 21:42 tcpip.LBX
X10 LBX 3.908 08.06.03 20:59 x10.LBX
XRAMDR~1 LBX 6.790 02.05.03 7:07 XRAMDrive.LBX
XRAMDR~1 LIB 7.958 02.05.03 7:07 XRAMDrive.lib
INFO TXT 0 06.01.05 9:54 info.txt
40 Datei(en) 342.262 Bytes
2 Verzeichnis(se) 15.978,17 MB frei
hi jungs,
ich habe versucht, mit der Bascom Version 1.11.7.7 das Programm "rncontroltest.bas" zu bearbeiten, Dabei gibt es Probleme.
Gruß stupsi
Ich habe auch mal versucht mit der neuen Version das rncontroltest.bas zu übersetzen. Bei mir meckert er über die lokale Stringvariable "Zustand", was wohl an der fehlenden Längenangabe liegt. Wenn ich die Länge angebe und neu übersetze hat er am Quelltext erst mal nichts zu meckern aber es kommt die Fehlermeldung "File not found" ohne eine Angabe welches File er denn sucht. Danach kann ich auch nicht neu übersetzen da die Schaltflächen nicht aktivierbar sind. Muß die Datei erst schließen und wieder öffnen???
Bei mir meckert Bascom auch ständig das er eine nicht näher beschriebene Datei nicht gefunden hätte. Etwas verwirrend das ganze.
Grüsse,
Jonas
