mainwindow.ui
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
<class>MainWindow</class>
<widget class="QMainWindow" name="MainWindow">
<property name="geometry">
<rect>
<x>0</x>
<y>0</y>
<width>474</width>
<height>411</height>
</rect>
</property>
<property name="windowTitle">
<string>MainWindow</string>
</property>
<widget class="QWidget" name="centralWidget">
<widget class="QPushButton" name="pushButton">
<rect>
<x>180</x>
<y>300</y>
<width>101</width>
<height>31</height>
</rect>
</property>
<property name="text">
<string>Quit</string>
</property>
</widget>
<widget class="MyWidget" name="widget" native="true">
<rect>
<x>10</x>
<y>10</y>
<width>451</width>
<height>271</height>
</rect>
</property>
</widget>
</widget>
<widget class="QMenuBar" name="menuBar">
<rect>
<x>0</x>
<y>0</y>
<width>474</width>
<height>21</height>
</rect>
</property>
</widget>
<widget class="QToolBar" name="mainToolBar">
<attribute name="toolBarArea">
<enum>TopToolBarArea</enum>
</attribute>
<attribute name="toolBarBreak">
<bool>false</bool>
</attribute>
</widget>
<widget class="QStatusBar" name="statusBar"/>
<widget class="QToolBar" name="toolBar">
<string>toolBar</string>
</property>
</attribute>
<bool>false</bool>
</attribute>
</widget>
<action name="action">
<string/>
</property>
</action>
</widget>
<layoutdefault spacing="6" margin="11"/>
<customwidgets>
<customwidget>
<class>MyWidget</class>
<extends>QWidget</extends>
<header>mywidget.h</header>
<container>1</container>
</customwidget>
</customwidgets>
<resources/>
<connections>
<connection>
<sender>pushButton</sender>
<signal>clicked()</signal>
<receiver>MainWindow</receiver>
<slot>close()</slot>
<hints>
<hint type="sourcelabel">
<x>234</x>
<y>171</y>
</hint>
<hint type="destinationlabel">
<x>260</x>
<y>229</y>
</hint>
</hints>
</connection>
</connections>
</ui>
qt_btn_paint.pro
# Project created by QtCreator 2019-09-16T12:09:00
QT += core gui
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = GUI_app
TEMPLATE = app
# The following define makes your compiler emit warnings if you use
# any feature of Qt which as been marked as deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if you use deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000 # disables all the APIs deprecated before Qt 6.0.0
SOURCES += main.cpp\
mainwindow.cpp \
mywidget.cpp
HEADERS += mainwindow.h \
mywidget.h
FORMS += mainwindow.ui
- - - Aktualisiert - - -
