Das Updateprogramm bei mir heisst "all-avr_upd_130.exe"
und zeigt das folgende Bild (ich habe nicht den Jumper gesetzt, damit der Programmer in den Update Modus geht, es ist aber diese BIOS Version)
Hab mal aus einem Atmega168 die Fuses im verbose mode gelesen:
Also ist es die Firmwareversion 1.14Code:sudo avrdude -p m168 -c avrispmkii -P usb -v
avrdude: Version 5.11.1, compiled on Oct 18 2011 at 21:41:15
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : avrispmkii
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200064271
AVR Part : ATMEGA168
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
Hardware Version: 1
Firmware Version Master : 1.14
Vtarget : 4.8 V
SCK period : 12.62 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9406
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as DD
avrdude: safemode: efuse reads as 1
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Georg
Hallo Georg,
ist doch klar, das ich jetzt die dumme Frage stelle, wie Du Deinen Prommer auf Firmware 1.14 bekommen hast ?
Wir reden aber beide von diesem Programmer (rein optische gesehen):
http://www.reichelt.de/Programmer-En...931fce2c802167
Hier gibt es nur das Update auf BIOS Version 1.13, welches ich derzeit verwende.
Gruss R.
Hallo Ritchie,
ich hab den hier [1]. Im Titel wird ja genau dieser hier Atmel Corp. AVR ISP mkII erwähnt. Das Update hab ich auf einem Windows PC mit dem AVRStudio 5.0 oder 5.1 gemacht.
Georg
[1] http://www.shop.robotikhardware.de/s...roducts_id=201
