Zitat:
5.9.6 Floating Point Aritmetic
The ESP32 supports hardware acceleration of single precision floating point arithmetic (float) via Floating Point
Units (FPU, also known as coprocessors) attached to each core. The use of the FPUs imposes some behavioral
restrictions on ESP-IDF FreeRTOS.
ESP-IDF FreeRTOS implements Lazy Context Switching for FPUs. In other words, the state of a core's FPU registers
are not immediately saved when a context switch occurs. Therefore, tasks that utilize float must be pinned to a
particular core upon creation. If not, ESP-IDF FreeRTOS will automatically pin the task in question to whichever core
the task was running on upon the task's first use of float. Likewise due to Lazy Context Switching, interrupt service
routines must also not use float.
allerdings tritt der Fehler ja auch bei fp64 auf, was die 32bit-FPU nicht betreffen würde.... ::?
