Thema: eclipse - sloeber fehlermeldung vom compiler
    nahe Dresden
    hallo allerseits,
    kennt sich jemand mit der sloeber arduino eclipse aus?
    ein code, der sich mit der arduino IDE problemlos compilieren lässt, bringt hier diese fehlermeldung:
    Starting C++ compile
    "/home/georg/Arduino/sloeber/arduinoPlugin/tools/arduino/avr-gcc/4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   -I"/home/georg/Arduino/sloeber/arduinoPlugin/packages/arduino/hardware/avr/1.6.15/cores/arduino" -I"/home/georg/Arduino/sloeber/arduinoPlugin/packages/arduino/hardware/avr/1.6.15/variants/mega" -I"/home/georg/Arduino/sloeber/arduinoPlugin/packages/arduino/hardware/avr/1.6.15/libraries/Wire" -I"/home/georg/Arduino/sloeber/arduinoPlugin/packages/arduino/hardware/avr/1.6.15/libraries/Wire/src" -I"/home/georg/Arduino/libraries/CustomStepper" -I"/home/georg/Arduino/libraries/Arduino-IRremote-master" -I"/home/georg/Arduino/libraries/NewliquidCrystal" -I"/home/georg/Arduino/libraries/NewliquidCrystal/utility" -MMD -MP -MF".ino.cpp.d" -MT".ino.cpp.o" -D__IN_ECLIPSE__=1 -x c++ "../.ino.cpp" -o ".ino.cpp.o"  -Wall
    In file included from ../.ino.cpp:13:0:
    /home/georg/Arduino/libraries/Arduino-IRremote-master/ir_Lego_PF_BitStreamEncoder.h: In member function 'int LegoPfBitStreamEncoder::getRepeatStopPause() const':
    /home/georg/Arduino/libraries/Arduino-IRremote-master/ir_Lego_PF_BitStreamEncoder.h:107:38: warning: integer overflow in expression [-Woverflow]
           return STOP_PAUSE_DURATION + 5 * MAX_MESSAGE_LENGTH - messageLength;
    In file included from ../remote_FB_schwarz_switch_1_ohne_lib_kurzimpuls_dauer_bewegung.ino:18:0,
                     from ../.ino.cpp:26:
    /home/georg/Arduino/libraries/Arduino-IRremote-master/ir_Lego_PF_BitStreamEncoder.h: At global scope:
    /home/georg/Arduino/libraries/Arduino-IRremote-master/ir_Lego_PF_BitStreamEncoder.h:13:7: error: redefinition of 'class LegoPfBitStreamEncoder'
     class LegoPfBitStreamEncoder {
    /home/georg/Arduino/libraries/Arduino-IRremote-master/ir_Lego_PF_BitStreamEncoder.h:13:7: error: previous definition of 'class LegoPfBitStreamEncoder'
    make: *** [.ino.cpp.o] Fehler 1
    19:00:21 Build Finished (took 125ms)
    hat jemand eine idee was das bedeutet?
    gruß inka
    Mehrere Sachen:
    1. Warnung bzgl. Integer Overflow: Beachte: Int-Wertebereich: -32,768 ... 32,767
    der return-Wert in getRepeatStopPause() ist größer!
    -> Konstanten ändern oder Datentyp ändern (z.B. long)
    2. ir_Lego_PF_BitStreamEncoder.h:13:7: error: redefinition of 'class LegoPfBitStreamEncoder'
    Neudefinition einer Klasse ist nicht erlaubt! Evtl. Include-Guard verwenden?
    nahe Dresden
    hallo Sisor,
    danke für die "Übersetzung" - wieso geht sowas bei der arduino IDE durch? Könnte es nicht einfach an der unterschiedlichen Fehlertoleranz in den einstellungen liegen?
    gruss inka
    Es gibt genug Code, der das Überlaufen und wieder bei Null anfangen als Optimierung nutzt.
    Ist doch nett, wenn der Compiler dich warnt, wenn da was "riecht".
    nahe Dresden
    das war der entscheidender hinweis, danke...
    gruß inka
  1. Nutzung von Eclipse
    Von shell im Forum Robby RP6
    Antworten: 16
    Letzter Beitrag: 26.05.2009, 21:12
  2. Antworten: 0
    Letzter Beitrag: 19.01.2008, 23:49
  3. Eclipse, CDT, avr-gcc
    Von MadMan2k im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 14.11.2005, 21:09
  4. Compiler Fehlermeldung
    Von ceekay im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 26.09.2005, 16:12
  5. ICC AVR und Eclipse
    Von bluebrother im Forum AVR Hardwarethemen
    Letzter Beitrag: 18.11.2004, 19:46
