jedesmal wenn ich etwas zu installieren versuche erscheint folgendes:
checking for a BSD compatible install... /usr/bin/install -c
*** This configuration is not supported in the following subdirectories:
target-libiberty
(Any other directories should still work fine.)
./configure: line 2343: cc: command not found
*** The command 'cc -o conftest -g -I/sw/include -L/sw/lib conftest.c' failed.
*** You must set the environment variable CC to a working compiler.
### execution of ./configure failed, exit code 1
Failed: compiling avr-binutils-2.15-1 failed
Dies erscheint fast immer:
/usr/libexec/gcc/darwin/ppc/3.3/cc1plus is not executable!
