Thema: LCD - ich bekomms nicht zum laufen
    Nidda
    ich habe mir vom MSC Elekronic einen Beispielcode für die Ansteuerung eines LCD Displays (4*20) besorgt.
    Leider bekomme ich es nicht zu laufen. Kennt ihr das Problem?
    Ich habe den Code, den ich etwas modifizieren musste mal angehängt:
    'LCD Testanzeige
    $regfile = "m8def.dat"
    $crystal = 7372800
    $baud = 4800
    Config Lcd = 20 * 4                                         'LCD-Display mit 20 Zeichen in 4 Zeilen verwendet
    Config Lcdbus = 4                                           '4 bit mode
    Config Lcdmode = Port
    Config Lcdpin = Pin , Db4 = Portc.1 , Db5 = Portc.2 , Db6 = Portc.3 , Db7 = Portc.4 , E = Portc.5 , Rs = Portd.6       'war Portc.6
    Deflcdchar 0 , 7 , 5 , 7 , 32 , 32 , 32 , 32 , 32
    Deflcdchar 1 , 10 , 32 , 14 , 17 , 17 , 17 , 14 , 32
    Dim A As Byte
    Cls                                                         'clear the LCD display
    Lcd "Hello world."                                          'display this at the top line
    Wait 1
    Lowerline                                                   'select the lower line
    Wait 1
    Lcd "Shift this."                                           'display this at the lower line
    Wait 1
    For A = 1 To 10
       Shiftlcd Right                                           'shift the text to the right
       Wait 1                                                   'wait a moment
    Next
    For A = 1 To 10
       Shiftlcd Left                                            'shift the text to the left
    Next
    Locate 2 , 1                                                'set cursor position
    Lcd "*"                                                     'display this
    Shiftcursor Right                                           'shift the cursor
    Lcd "@"                                                     'display this
    Home Upper                                                  'select line 1 and return home
    Lcd "Replaced."                                             'replace the text
    Cursor Off Noblink                                          'hide cursor
    Cursor On Blink                                             'show cursor
    Display Off                                                 'turn display off
    Display On                                                  'turn display on
    '-----------------NEW support for 4-line LCD------
    Thirdline
    Lcd "Line 3"
    Fourthline
    Lcd "Line 4"
    Home Third                                                  'goto home on line three
    Home Fourth
    Home F                                                      'first letteer also works
    Locate 4 , 1 : Lcd "Line 4"
    Wait 1
    Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228       ' replace ? with number (0-7)
    Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240       ' replace ? with number (0-7)
    Cls                                                         'select data RAM
    Rem it is important that a CLS is following the deflcdchar statements because it will set the controller back in datamode
    Lcd Chr(0) ; Chr(1)                                         'print the special character
    '----------------- Now use an internal routine ------------
    _temp1 = 1                                                  'value into ACC
    !rCall _write_lcd                                           'put it on LCD
    End
    Geht bei mir immer :
    Waitms 100
    Initlcd
    Cursor Off Noblink
    Cls
    Gento
    Was für ein Controller hat das LCD?
    Ist der Kontrast richtig eingestellt?
    GND der Schaltung mit GND vom Display verbunden?
    Nidda
    es handelt sich um einen LSI KS0076B von Reichelt (LCD204B).
    Der GND ist angeschlossen. den Kontrast kann ich regeln
    Nidda
    Sorry,
    es war der Kontrast. Ich hatte den falschen Pin erwischt
    Danke für die Unterstützung
    schön, daß es geht
    Falls du doch noch auf Probleme stößt (locate arbeitet falsch etc.) , probiere es mal damit:
    Config Lcd = 20 * 4a , Chipset = Ks077
    Config Lcd = 20 * 4 , Chipset = Ks077
    Christopher
