Ergebnis 21 bis 30 von 36
Thema: 2 programmierfragen
  1. #21
    Milda
    ja, so ollte das sein... probiere das nochmal... oder öffne die asuro.c, und poste mal alle funktionen die mit SIGNAL anfangen
    Read... or die.
    ff.mud.de:7600
    Bonn
    ich weiß niocht genau was gemeint ist, deshalb schreib ich einfach das ganze hier rein
     * \file asuro.c
     * \brief Die ASURO Bibliothek
     * $Revision: 2.60 $
     * $Date: 27. September 2005 $
     * $Author: Jan Grewe, Robotrixer, Waste, Stochri, Andun, m.a.r.v.i.n $
    * File Name:   asuro.c
    * Project  :   ASURO
    * Description: This file contains ASURO main features
    * Ver.     Date         Author           Comments
    * 1.00	   14.08.2003   Jan Grewe        build
    * 2.00     14.10.2003   Jan Grewe        LEFT_VEL, RIGHT_VEL -> MotorSpeed(unsigned char left_speed, unsigned char right_speed);
    *                                        LeftRwd(),LeftFwd(),RightRwd(),
    *                                        RigthFwd() -> MotorDir(unsigned char left_dir, unsigned char right_dir);
    *                                        GREEN_ON,GREEN_OFF,RED_ON,RED_OFF -> StatusLED(unsigned char color);
    *                                        LED_RED_ON, LED_RED_OFF -> FrontLED(unsigned char color);
    *                                        Blink(unsigned char left, unsigned char right) -> BackLED(unsigned char left, unsigned char right);
    *                                        Alles in Funktionen gefasst => leichter verständlich ?!?!
    * 2.10     17.10.2003   Jan Grewe        new Timer funktion void Sleep(unsigned char time36kHz)
    * Copyright (c) 2003 DLR Robotics & Mechatronics
    * Project  :   asuro library "Robotrixer Buxtehude"
    * Description: This file contains additional functions:
    * signal (SIG_ADC)                 interrupt/signal routine for encoder-counter
    * signal (SIG_INTERRUPT1)          signal for switches
    * Encoder_Init()                   initializing encoder-counter
    * Encoder_Start()                  start autoencoding
    * Encoder_Stop()                   stop autoencoding
    * Encoder_Set(int,int)             set encodervalue
    * Msleep(int delay)                wait for delay in milliseconds
    * Gettime()                        get systemtime in milliseconds
    * PrintInt(int)
    * modifications in Sleep, SIG_OUTPUT_COMPARE2, PollSwitch, LineData
    * beta1	   31.03.2005   Robotrixer	 asuro library
    * the encoder source is based on RechteckDemo.c ver 2.0 by Jan Grewe 22.10.2003
    * Project  :   asuro library modified for IR collision detector
    * Description: modifications made in following functions:
    * SIGNAL (SIG_OUTPUT_COMPARE2)	->	SIGNAL (SIG_OVERFLOW2)
    * Gettime()				counts now 36kHz
    * Init()				timer2 modified for adjustable duty cycle
    * Batterie()				bug fixed
    * Sleep()				counts now 36kHz
    * Msleep()				counts now 36kHz
    * beta2	   11.06.2005   Waste   	 asuro library
    * motor control functions 29.7.2005 stochri
    * void Go(int distance)
    * void Turn(int degree)
    * unsigned char Wheelspeed[2]		measured Wheelspeed by interupt
    * sto1     29.07.2005   stochri		 asuro library with motor control functions
    * void Go(int distance, int speed)
    * void Turn(int degree, int speed)
    * And1     31.07.2005   Andun		 Added Speed and Odometrie
    * void PrintInt(int wert)
    * 2.60     28.09.2005   m.a.r.v.i.n      doxygen comments
    * SIGNAL (SIG_ADC)
    * 2.61     20.11.2006   m.a.r.v.i.n      SIGNAL (SIG_ADC): static Variable toggle initialisiert
    *                                        auf False (Bug report von Rolf_Ebert)
    *                                        PrintInt: Initialisierung text String kann zu Fehler
    *                                        beim Flashen mit RS232/IR Adapter fuehren
    *                                        (Bug report von francesco)
    *   This program is free software; you can redistribute it and/or modify  *
    *   it under the terms of the GNU General Public License as published by  *
    *   the Free Software Foundation; either version 2 of the License, or     *
    *   any later version.                                                    *
    #include "asuro.h"
    #include "string.h"
    /*! \brief Counter fuer 36kHz.\n
     *  Wird in derInterrupt Funktion SIG_OVERFLOW2 hochgezaehlt\n
     *  und in der Sleep() Funktion abgefragt.
     *  \see Sleep
    volatile unsigned char count36kHz;
    /*! \brief Sytemzeit.\n
     *  Wird in der Interrupt Funktion SIG_OVERFLOW2 hochgezaehlt\n
     *  und in der Gettime() Funktion verwendet.
     *  \see Gettime
    volatile unsigned long timebase;
    /*! \brief Odometrie Sensor Abfrage im Interrupt Betrieb.\n
     *  Wird in der Interrupt Funktion SIG_ADC abgefragt,\n
     *  in der Encoder_Init() und Encoder_Start() Funktion gesetzt\n
     *  und in der Encoder_Stop() Funktion geloescht .
     *  \see Encoder_Init, Encoder_Start, Encoder_Stop
    volatile int autoencode=FALSE;
     * \func SIG_OVERFLOW2
     * \brief Interrupt Funktion: Timer2 Overflow
     * uses timer2 (36kHz for IR communication)
    	TCNT2 += 0x25;
    	count36kHz ++;
    	if (!count36kHz) timebase ++;
     * \func SIG_INTERRUPT1
     * \brief Interrupt Funktion: INT1
    SIGNAL (SIG_INTERRUPT1)
    	switched=1;
    	StopSwitch();
     * \func SIG_ADC
     * \brief Interrupt Funktion: A/D Wandler
     *	last modification:
     * 	2.61     20.11.2006   m.a.r.v.i.n      static Variable toggle initialisiert
    SIGNAL (SIG_ADC)
    	static unsigned char tmp[2],flag[2],toggle=FALSE;
    	if (autoencode){
    	tmp[toggle]= ADCH;
    	if (toggle)	ADMUX = (1 <<ADLAR) | (1 <<REFS0) | WHEEL_RIGHT;
    	else ADMUX = (1 <<ADLAR) | (1 <<REFS0) | WHEEL_LEFT;
    	if ( (tmp[toggle] < 140) && (flag[toggle] == TRUE)) {
    		encoder[toggle] ++;
    		flag[toggle] = FALSE;
    	if ( (tmp[toggle] > 160) && (flag[toggle] == FALSE)) {
    		encoder[toggle] ++;
    		flag[toggle] = TRUE;
    	toggle ^= 1;
    // neue Zeitfunktion
    unsigned long Gettime(void)
    	return ((timebase*256)+count36kHz)/36;
    /* Init function Processor will be initalized to work correctly */
    void Init (void)
    	//-------- seriell interface programmed in boot routine and already running -------
    	//  prepare 36kHz for IR - Communication
    	TCCR2 = (1 << WGM20) | (1 << WGM21) | (1 << COM20) | (1 << COM21) | (1 << CS20);
    	OCR2  = 0x91; // duty cycle for 36kHz
    	TIMSK |= (1 << TOIE2); // 36kHz counter for sleep
    	// prepare RS232
    	UCSRA = 0x00;
    	UCSRB = 0x00;
    	UCSRC = 0x86; // No Parity | 1 Stop Bit | 8 Data Bit
    	UBRRL = 0xCF; // 2400bps @ 8.00MHz
    	// I/O Ports
    	DDRB = IRTX | LEFT_DIR | PWM | GREEN_LED;
    	DDRD = RIGHT_DIR | FRONT_LED | ODOMETRIE_LED | RED_LED;
    	// for PWM (8-Bit PWM) on OC1A & OC1B
    	TCCR1A = (1 << WGM10) | (1 << COM1A1) | (1 << COM1B1);
    	// tmr1 running on MCU clock/8
    	TCCR1B = (1 << CS11);
    	// A/D Conversion
    	ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1); // clk/64
    	ODOMETRIE_LED_OFF;
    	FrontLED(OFF);
    	BackLED(ON,ON);
    	BackLED(OFF,OFF);
    	StatusLED(GREEN);
    	MotorDir(FWD,FWD);
    	MotorSpeed(0,0);
    	sei();
    /* Set motor speed */
    inline void MotorSpeed(unsigned char left_speed, unsigned char right_speed)
    	OCR1A = left_speed;
    	OCR1B = right_speed;
    /* Set motor direction */
    inline void MotorDir(unsigned char left_dir, unsigned char right_dir)
    	PORTD = (PORTD &~ ((1 << PD4) | (1 << PD5))) | left_dir;
    	PORTB = (PORTB &~ ((1 << PB4) | (1 << PB5))) | right_dir;
    /* Status LED (OFF,GREEN,YELLOW,RED)*/
    /* example code set StatusLED GREEN */
    /* StatusLED(GREEN); */
    inline void StatusLED(unsigned char color)
    	if (color == OFF)    {GREEN_LED_OFF; RED_LED_OFF;}
    	if (color == GREEN)  {GREEN_LED_ON; RED_LED_OFF;}
    	if (color == YELLOW) {GREEN_LED_ON; RED_LED_ON;}
    	if (color == RED)    {GREEN_LED_OFF; RED_LED_ON;}
    /* Front LED */
    /* example code FrontLED ON */
    /* FrontLED(ON); */
    inline void FrontLED(unsigned char status)
    	PORTD = (PORTD &~(1 << PD6)) | (status << PD6);
    /* function for Break LEDs */
    /* example code right LED On left LED Off */
    /* BackLED(OFF,ON); */
    void BackLED(unsigned char left, unsigned char right)
    	if (left || right) {
    		PORTD &= ~(1 << PD7); // Wheel LED OFF
    		DDRC |= (1 << PC0) | (1 << PC1); // Output => no odometrie
    		PORTC |= (1 << PC0) | (1 << PC1);
    	if (!left) PORTC &= ~(1 << PC1);
    	if (!right) PORTC &= ~(1 << PC0);
    int  Batterie(void)
    	ADMUX = (1 << REFS0) | (1 << REFS1) | BATTERIE;	// internal 2.56V reference with external capacitor
    	ADCSRA |= (1 << ADSC);			// Start conversion
    	while (!(ADCSRA & (1 << ADIF)));	// wait for conversion complete
    	ADCSRA |= (1 << ADIF);			// clear ADCIF
    	return ADCL + (ADCH << 8);
    /* function to read out line follow phototransistors (left,rigth) */
    void LineData(unsigned int *data)
    	int ec_bak=autoencode;
    	autoencode=FALSE;
    	ADMUX = (1 << REFS0) | IR_LEFT;	// AVCC reference with external capacitor
    	Sleep(10);
    	data[0] = ADCL + (ADCH << 8);
    	ADMUX = (1 << REFS0) | IR_RIGHT;	// AVCC reference with external capacitor
    	Sleep(10);
    	data[1] = ADCL + (ADCH << 8);
    	autoencode=ec_bak;
    /* function to read out odometrie phototransistors (left,rigth) */
    void OdometrieData(unsigned int *data)
    	DDRC &= ~((1 << PC0) | (1 << PC1)); // Input => no break LED
    	ODOMETRIE_LED_ON;
    	ADMUX = (1 << REFS0) | WHEEL_LEFT; // AVCC reference with external capacitor
    	ADMUX = (1 << REFS0) | WHEEL_RIGHT; // AVCC reference with external capacitor
    /* function for serial communication */
    void SerWrite(unsigned char *data,unsigned char length)
    	unsigned char i = 0;
    	UCSRB = 0x08; // enable transmitter
    	while (length > 0) {
    		if (UCSRA & 0x20) { // wait for empty transmit buffer
    			UDR = data[i++];
    			length --;
    	while (!(UCSRA & 0x40));
    	for (i = 0; i < 0xFE; i++)
    		for(length = 0; length < 0xFE; length++);
    void SerRead(unsigned char *data, unsigned char length,unsigned int timeout)
    	unsigned int  time = 0;
    	UCSRB = 0x10; // enable receiver
    	/* non blocking */
    	if (timeout != 0) {
    		while (i < length && time++ < timeout) {
    			if (UCSRA & 0x80) {
    				data[i++] = UDR;
    				time = 0;
    		if (time > timeout) data[0] = 'T';
    	/* blocking */
    	else {
    		while (i < length) {
    			if (UCSRA & 0x80)
    				data[i++] = UDR;
    /* function to read out switches */
    unsigned char PollSwitch (void)
    	unsigned int i;
    	autoencode=FALSE;
    	DDRD |= SWITCHES;				// Switches as Output
    	SWITCH_ON;						// Output HIGH for measurement
    	ADMUX = (1 << REFS0) | SWITCH;	// AVCC reference with external capacitor
    	Sleep(10);
    	while (!(ADCSRA & (1 << ADIF)));// wait for conversion complete
    	i = ADCL + (ADCH << 8);
    	SWITCH_OFF;
    	Sleep(5);
    	autoencode=ec_bak;
    	//return  ((unsigned char) ((( 1024.0/(float)i - 1.0)) * 61.0 + 0.5));
    	return ((10240000L/(long)i-10000L)*61L+5000L)/10000;
    /* for working with Interrupt */
    void StartSwitch(void)
    	SWITCH_OFF;
    	DDRD &= ~SWITCHES;					// Switches as Input => ext. Int 1
    	MCUCR &= ~((1 << ISC11) | (1 << ISC10));// Low level generates interrupt
    	GICR |= (1 << INT1);					// Enable external Interrupt 1
    void StopSwitch(void)
    	GICR &= ~(1 << INT1);
    /* uses 36kHz timer => Sleep(x) = x/36kHz [sec] */
    	unsigned char ziel=(time36kHz+count36kHz) & 0x00FF;
    	while (count36kHz != ziel);
    void Encoder_Init(void)
    	cli();
    	DDRC &= ~ ((1<<PC0) | (1<<PC1)); // Input => no break LED
    	ODOMETRIE_LED_ON;
    	ADCSRA = (1<<ADEN) | (1<<ADFR) | (1<<ADIE) | (1<<ADSC) | (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2); // clk/128
    	ADMUX = (1<<ADLAR) | (1<<REFS0) | WHEEL_LEFT; // AVCC reference with external capacitor
    	autoencode=TRUE;
    	sei();
    	Encoder_Set(0,0);
    void Encoder_Stop(void){autoencode=FALSE;}
    void Encoder_Start(void){autoencode=TRUE;}
    void Encoder_Set(int setl,int setr)
    	encoder[LEFT]=setl;
    	encoder[RIGHT]=setr;
    * 	2.60     28.09.2005   m.a.r.v.i.n      strlen instead fixed length
    * 	2.61     20.11.2006   m.a.r.v.i.n      Initialisierung text String kann zu Fehler
    	char text[6];
    	itoa(wert,text,10);
    	SerWrite(text,strlen(text));
    (gekürzt)
  3. #23
    Milda
    hmm... der code ist gekürzt. von dir oder vom system?
    so spontan kann ich nichts entdecken. schau mal hier
    http://sourceforge.net/project/showf...ease_id=465255
    aus diesem zip-archiv entpackst du die asuro.c und die asuro.h in das projektverzeichnis, und überschreibst die alten dateien nochmal. gehts dann?
    (die dateien sind irgendwo im unterverzeichnis "lib")
    Read... or die.
    ff.mud.de:7600
    Bonn
    habe ich gemacht, aber das problem bleibt das gleiche
  5. #25
    Milda
    dann solltest du nach einer etwas älteren version ausschau halten. vielleicht ist da der fehler noch nicht aufgetreten... oder setz dich mal mit m.a.r.v.i.n in verbindung, der kennt sich da sehr gut aus...
    Read... or die.
    ff.mud.de:7600
    Saarland
    versuche mal das zu compilieren
    #include <asuro.h>
    int main(void)
      Init();
      while (1);
      return 0;
    weil bei der alten lib heisst es #include "asuro.h" und bei der neuen #include <asuro.h> der unterschied ist halt einmal " und einmal <> wo asuro.h drin steckt
  7. #27
    Milda
    es sollten "" sein und keine <>...
    Read... or die.
    ff.mud.de:7600
    Bonn
    selbst das geht nicht
  9. #29
    Milda
    also "" bedeutet: die einzubindende datei liegt im selben verzeichnis wie der quellcode.
    <> bedeutet: die einzubindende datei liegt im include-verzeichnis des compilers.
    darum heisst es <math.h>, aber "asuro.h"
    Read... or die.
    ff.mud.de:7600
    Saarland
    hmm bei mir geht beides ist das schlimm? so stand es jedenfalls mal in Test.c drin ich hatte es nur raus kopiert und comp. konnte ich es auch
