Thema: kleiner als operator geht schief
    Ich mochte ein integer shift right function fuer Integer schreiben mit richtigen abrundung. Die Code ist kein problem. Als ich aber innerhalb die Funktion auswerte:
    test =-40 <=32675
    dan ergibt sich test = 0 (im simulator)
    wenn ich dass gleiche im Hauptprogram mache ergibt sich test = 1.
    'Program Shiftintr
    'Contains demo of function Shiftintr_PR
    'This function shifts integers right and works correctly with integers. It does arithmetic shifting
    'The shift in Bascom is a logical shift, so the sign bit gets lost.
    'To get the sign bit back, for negative numbers the result from the shift is subtrakted from 32768 (=max of int + 1)
    'Based upon shiftintr, that did do the same with rounding towards negative infinity.
    'This version of shiftint does proper rounding instead of rouding all numbers towards negative infinity
    'var = variable to be shifted, N = number of shifts
    $regfile "m168def.dat"
    'Frame and stack settings
    $framesize = 64
    $swstack = 64
    $hwstack = 64
    'System frequency (20Mhz)
    $crystal = 20000000
    Declare Function Shiftintr_pr(var As Integer , Byval N As Byte) As Integer
    Dim A As Integer
    Dim B As Integer
    Dim C As Integer
    Dim D As Integer
    Dim Test As Integer
    Dim Test1 As Integer
    A = -40
    B = -39
    C = -38
    D = -37
    Test = A <= 32765
    D = D / 4
    A = Shiftintr_pr(a , 2)
    B = Shiftintr_pr(b , 2)
    C = Shiftintr_pr(c , 2)
    End                                                         'end program
    'To get the sign bit back, for negative numbers the result from the shift is subtracted from 32768 (=max of int + 1)
    'Note: this logical shift does rounding toward negative infinity (i.e. downwards) on all numbers
    Function Shiftintr_pr(var As Integer , Byval N As Byte ) As Integer
       Local P As Integer                                       'local variable for calculations (for demo purposes it is global here)
       Local I As Integer                                       'local counting variable (for demo purposes it is global here)
       Local Nloop As Byte                                      'Local variable to determine the rounding constant
       Local Maxn As Integer                                    'This is the maximum number that allows adding half the divisor without causing overflow
       P = Var
       P = 1                                                    'Initialse P
       Nloop = N - 1                                            'Initialise Nloop based on the shift
       For I = 1 To Nloop
          P = 2 * P                                             'calculate 2^N-1 (this is half of the divisor)
       Next
       Maxn = 32767 - P                                         'calculate Maxn
       'Maxn = 30000
      Test1 = -40 <= 32765
      Test = Var <= Maxn
       If Var <= Maxn Then                                      'In case overflow will not occur
          P = P + Var                                           'Add half the divisor
       Else
          P = Var
       End If
       For I = 1 To N                                           'This is the actual arithmetic shift
          Shift , P , Right , 1                                 'Shift one step
          If Var < 0 Then
             P = P - 32768                                      'correct sign for negative numbers only
          End If
       Next
       Shiftintr_pr = P                                         'load function variable with result of calculation
    End Function
    Wass passiert hier? Ich kann die Fehler nich finden.
    Danke fuer jede hilfe.
    Merijn
    das ist wohl ein Problem des Simulators. Probier mal
    test=32765>= -40, das sollte gehen.
    Im MCS Electronics Forum hatten wir das Problem auch schon mal (siehe Kommentar von DToolan, hat es auch schon gemeldet)
    http://www.mcselec.com/index2.php?op...ghlight=ds1820
    Rolf
    Hallo Rolf,
    test=32765>= -40
    Geht auch nicht.
    Typisch ist das es nur im Function schief geht, nicht im hauptprogram.
    Ich werde das mal ohne simulator testen.
    Merijn
