Ich möchte Daten vom AD-Wandler über den USB-Bus übertragen. Leider gibt es ein Problem und zwar werden mehr Bytes übertragen als ich senden will. Das Programm sieht folgendermaßen aus:
; uC: Atmel, AT90s2333
; Used PINs:
;	+5V, GND        - power supply
;	ADC0...ADC5     - ADC
;	PD0..7			- Data I/O
;	PB0				- RXF#	(IN)
;	PB1				- TXF#	(IN)
;	PB2				- WR	(OUT)
;	PB3				- RD#	(OUT)
;   Further connection for XTAL and ADC see manual.
;   (8 MHz)
.include "2333def.inc"
;***** Register definitions *****
.equ    tmp,            16
.equ	data,			17
.equ	adc_lo, 		18
.equ	adc_hi,			19
.equ	bool,			20
;***** Bit definitions **********
.equ	RXF,			0		; bit number
.equ 	TXF,			1		; bit number
.equ	WR,				2		; bit value
.equ	RD,				3		; bit value
;***** Interrupt Vectors ********
        RJMP RESET              ; Reset         - Hardware Pin, Power-on Reset, Watchdog Reset
        reti				    ; INT0          - external interrupt request 0
        reti                    ; INT1          - external interrupt request 1
        reti                    ; Timer1 capt1  - timer/counter1 capture event
        reti                    ; Timer1 comp1  - timer/counter1 compare mach
        reti                    ; Timer1 ovf1   - timer/counter1 overflow
        reti                    ; Timer0 ovf0   - timer/counter0 overflow
        reti                    ; SPI           - SPI interrupt
        reti                    ; Uart, Rx      - UART, RX complete
        reti                    ; Uart, UDRE    - UART Data Register Empty
        reti                    ; Uart, Tx      - Uart, TX complete
        RJMP ADC_Interrupt	    ; ADC           - ADC interupt
        reti                    ; EEPROM        - EEPROM Interrupt
        reti                    ; Ana_comp      - Analog Comparator
ADC_Interrupt:
	IN      r0,SREG
	IN		adc_lo,ADCL
	IN		adc_hi,ADCH
	LDI		bool,1
	OUT		SREG,r0
	reti
SendData:
	LDI		tmp,0xFF			; PORTD as ouput
	OUT		DDRD,tmp
	LDI		adc_lo,65
	LDI		adc_hi,65
	LDI		tmp,0x00			; select channel 0
	OUT		ADMUX,tmp
	LDI		tmp,0xCF			; start AD conversion
	OUT		ADCSR,tmp
	LDI 	bool,0
WAIT:
	CPI		bool,1
	BRNE	WAIT
	LDI		tmp,0
	OUT		PORTD,adc_lo		; send low byte
	SBI		PORTB,WR			; set WR bit
	CBI		PORTB,WR			; clear WR bit
	LDI		tmp,0
	OUT		PORTD,adc_hi		; send high byte
	NOP
	NOP
	LDI		tmp,0x00			; PORTD as input
	OUT		DDRD,tmp
	OUT		PORTD,tmp
	RET
RESET:
	LDI     tmp,0x80			; init 32 byte stack
	OUT     SPL,tmp
								; PD0..7 as Data I/O
    OUT     DDRD,tmp
    OUT     PORTD,tmp           ; Pull-ups off
								; PB0..3 as Control
	LDI		tmp,0xFC			; PB2,PB3 as Output
	OUT		DDRB,tmp
	LDI		tmp,0x08			; WR,RD# inactiv
	OUT		PORTB,tmp
	LDI		tmp,0x80			; GIE
	OUT		SREG,tmp
MAIN:
	IN		tmp,PINB			; read Control bits
	SBRC	tmp,RXF				; Skip if Bit in Register is Clear = Data available
	RJMP	NoData
	CBI		PORTB,RD			; clear READ# bit
	NOP
	NOP
	IN		data,PIND			; read Data
	SBI		PORTB,RD			; set RD# bit
	CPI		data,0x01			; send data?
	BRNE	NotDataCommand
	RCALL	SendData
NotDataCommand:
NoData:
	RJMP 	MAIN
Wenn ich die Datenblätter richtig verstanden habe, sollte das Programm beim empfangen von "1" zwei Bytes senden. Gesendet wird aber folgendes:
Wenn ich ein Poti am ADC0 gegen Masse gedreht habe erhalte ich folgendes:
0, 1, 0 - 2. und 3. Byte sind richtig (= ADC_lo/hi)
Wenn ich es gegen +5V gedreht habe erhalte ich die Bytes:
0, 127, 3, 3 - 2. und 3. sind richtig (= ADC_lo/hi)
Ich habs auch mal ausprobiert nur den PORTD von Input auf Output umschalten selbst dann wird ein Byte gesendet.
Vermuten tue ich das es beim Umschalten des PORTD irgendwie zu störungen kommen muss die ein Schreiben des Bytes auslösen, was wohl an meinem Steckbrett aufbau liegen könnte.
Hat jemand sonst eine Idee?
