Ergebnis 1 bis 2 von 2
Thema: Fehler bei berechnung; warum?
    habe n kleines Problem!
    dieser Code Funtzt:
    ' Define´s
    'Variablen
    Define Vi       Byte
    Define VRemote3 Byte
    Define VLgt1Bt  Bit[185]
    Define VLgt2Bt  Bit[186]
    Define VLgt3Bt  Bit[187]
    Define VAirBt   Bit[188]
    Define VHydBt   Bit[189]
    Define VDeHydBt Bit[190]
    Define VHeatBt  Bit[191]
    Define VCoolBt  Bit[192]
    Define y        byte
    ' Prog
    gosub Initialization
    Print "Start"
    Print
    Print "+--------------------+"
    Print "| Byte->Binärtabelle |"
    Print "+-------+------------|"
    Print "| Byte: | Binärzahl: |"
    Print "+-------+------------+"
    #Main
      for Vi = 0 to 255
        VRemote3 = Vi
        gosub DeCodeRcRelaisData
        Print Vi; " = "; VLgt1Bt; VLgt2Bt; VLgt3Bt; VAirBt; VHydBt; VDeHydBt; VHeatBt; VCoolBt
      next
      Print "End"
    end
    #DeCodeRcRelaisData
      y = ((VRemote3 SHR 7) MOD 2)
      VLgt1Bt  = y
      y = ((VRemote3 SHR 6) MOD 2)
      VLgt2Bt  = y
      y = ((VRemote3 SHR 5) MOD 2)
      VLgt3Bt  = y
      y = ((VRemote3 SHR 4) MOD 2)
      VAirBt   = y
      y = ((VRemote3 SHR 3) MOD 2)
      VHydBt   = y
      y = ((VRemote3 SHR 2) MOD 2)
      VDeHydBt = y
      y = ((VRemote3 SHR 1) MOD 2)
      VHeatBt  = y
      y = (VRemote3 MOD 2)
      VCoolBt  = y
    return
    #Initialization
    Print "Initialization"
    ' Alle Vars (Vxxxxxxx) = 0
    Vi       = 0
    VRemote3 = 0
    VLgt1Bt  = 0
    VLgt2Bt  = 0
    VLgt3Bt  = 0
    VAirBt   = 0
    VHydBt   = 0
    VDeHydBt = 0
    VHeatBt  = 0
    VCoolBt  = 0
    y        = 0
    return
    dieser nicht:
    ' Define´s
    'Variablen
    Define Vi       Byte
    Define y        byte
    ' Prog
    Print "Start"
    Print
    #Main
      for Vi = 0 to 255
        VRemote3 = Vi
      next
      Print "End"
    end
    #DeCodeRcRelaisData
      VRemote3 = ((VRemote3 SHR 7) MOD 2)
      VLgt1Bt  = VRemote3
      VRemote3 = ((VRemote3 SHR 6) MOD 2)
      VLgt2Bt  = VRemote3
      VRemote3 = ((VRemote3 SHR 5) MOD 2)
      VLgt3Bt  = VRemote3
      VRemote3 = ((VRemote3 SHR 4) MOD 2)
      VAirBt   = VRemote3
      VRemote3 = ((VRemote3 SHR 3) MOD 2)
      VHydBt   = VRemote3
      VRemote3 = ((VRemote3 SHR 2) MOD 2)
      VDeHydBt = VRemote3
      VRemote3 = ((VRemote3 SHR 1) MOD 2)
      VHeatBt  = VRemote3
      VRemote3 = (VRemote3 MOD 2)
      VCoolBt  = VRemote3
    return
    #Initialization
    Vi       = 0
    VRemote3 = 0
    VLgt1Bt  = 0
    VLgt2Bt  = 0
    VLgt3Bt  = 0
    VAirBt   = 0
    VHydBt   = 0
    VDeHydBt = 0
    VHeatBt  = 0
    VCoolBt  = 0
    y        = 0
    return
    Kann mir wer sagen Warum?
    Will mir unbedingt die "y"-Variable sparen; Ist das möglich?
    Is Dringend und echt wichtig!
    Toxic
    Bez. Schärding
    hallo toxic!
    bin spät dran, aber besser spät als nie!
    schau dir das mal an:
    #DeCodeRcRelaisData
      VLgt1Bt  = VRemote3
      VLgt2Bt  = VRemote3
      VLgt3Bt  = VRemote3
      VAirBt   = VRemote3
      VHydBt   = VRemote3
      VDeHydBt = VRemote3
      VHeatBt  = VRemote3
      VCoolBt  = VRemote3
    return
    du machst hier folgendes:
    Vremote3 7 stellen nach rechts schieben.==>das ergebnis dann in die Variable Vremote3 Schreiben
    du hast jetzt Vremote3 verändert! bei der zweiten berechnung rechnest du dann wieder mit der veränderten variable Vremote3!
    probier es mal so:
    #DeCodeRcRelaisData
     VLgt1Bt  = ((VRemote3 SHR 7) MOD 2)
     VLgt2Bt  = ((VRemote3 SHR 6) MOD 2)
     VLgt3Bt  =((VRemote3 SHR 5) MOD 2)
     VAirBt   = ((VRemote3 SHR 4) MOD 2)
     VHydBt   =(VRemote3 SHR 3) MOD 2)
     VDeHydBt = ((VRemote3 SHR 2) MOD 2)
     VHeatBt  = ((VRemote3 SHR 1) MOD 2)
     VCoolBt  =  (VRemote3 MOD 2)
    return
    hoffe ich liege richtig,
    gruß martin
