Hallo Leute
Bitte um Hilfe!!
Bin gerade am Umsteigen von Bascom auf C
Habe leider derzeit Probleme mit den Makefile!
Habe das zuerst mal das originale Makfile mit "Mfile" probiert
Funktionierte leider nicht .
Dann habe ich eine Makefile von den Demo Programmen probiert.
Inzwischen läuft zumindest die Compilierung und ich konnte mein kleines Versuchsprogramm im AVR Studio simulieren.
Dieses Makfile schaute so aus:
Jetzt möchte ich aber gerne das schreiben in den AVR auch gleich mit dem "AVRDUDE" erledigen lassen.Code:PRG = Meines OBJ = Meines.o #MCU_TARGET = at90s2313 #MCU_TARGET = at90s2333 #MCU_TARGET = at90s4414 #MCU_TARGET = at90s4433 #MCU_TARGET = at90s4434 #MCU_TARGET = at90s8515 #MCU_TARGET = at90s8535 #MCU_TARGET = atmega128 #MCU_TARGET = atmega1280 #MCU_TARGET = atmega1281 MCU_TARGET = atmega16 #MCU_TARGET = atmega163 #MCU_TARGET = atmega164p #MCU_TARGET = atmega165 #MCU_TARGET = atmega165p #MCU_TARGET = atmega168 #MCU_TARGET = atmega169 #MCU_TARGET = atmega169p #MCU_TARGET = atmega32 #MCU_TARGET = atmega324p #MCU_TARGET = atmega325 #MCU_TARGET = atmega3250 #MCU_TARGET = atmega329 #MCU_TARGET = atmega3290 #MCU_TARGET = atmega48 #MCU_TARGET = atmega64 #MCU_TARGET = atmega640 #MCU_TARGET = atmega644 #MCU_TARGET = atmega644p #MCU_TARGET = atmega645 #MCU_TARGET = atmega6450 #MCU_TARGET = atmega649 #MCU_TARGET = atmega6490 #MCU_TARGET = atmega8 #MCU_TARGET = atmega8515 #MCU_TARGET = atmega8535 #MCU_TARGET = atmega88 #MCU_TARGET = attiny2313 #MCU_TARGET = attiny24 #MCU_TARGET = attiny25 #MCU_TARGET = attiny26 #MCU_TARGET = attiny261 #MCU_TARGET = attiny44 #MCU_TARGET = attiny45 #MCU_TARGET = attiny461 #MCU_TARGET = attiny84 #MCU_TARGET = attiny85 #MCU_TARGET = attiny861 OPTIMIZE = -O2 DEFS = LIBS = # You should not have to change anything below here. CC = avr-gcc # Override is only needed by avr-lib build system. override CFLAGS = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS) override LDFLAGS = -Wl,-Map,$(PRG).map OBJCOPY = avr-objcopy OBJDUMP = avr-objdump all: $(PRG).elf lst text eeprom $(PRG).elf: $(OBJ) $(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS) # dependency: clean: rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak rm -rf *.lst *.map $(EXTRA_CLEAN_FILES) lst: $(PRG).lst %.lst: %.elf $(OBJDUMP) -h -S $< > $@ # Rules for building the .text rom images text: hex bin srec hex: $(PRG).hex bin: $(PRG).bin srec: $(PRG).srec %.hex: %.elf $(OBJCOPY) -j .text -j .data -O ihex $< $@ %.srec: %.elf $(OBJCOPY) -j .text -j .data -O srec $< $@ %.bin: %.elf $(OBJCOPY) -j .text -j .data -O binary $< $@ # Rules for building the .eeprom rom images eeprom: ehex ebin esrec ehex: $(PRG)_eeprom.hex ebin: $(PRG)_eeprom.bin esrec: $(PRG)_eeprom.srec %_eeprom.hex: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@ %_eeprom.srec: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@ %_eeprom.bin: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@ # Every thing below here is used by avr-libc's build system and can be ignored # by the casual user. FIG2DEV = fig2dev EXTRA_CLEAN_FILES = *.hex *.bin *.srec dox: eps png pdf eps: $(PRG).eps png: $(PRG).png pdf: $(PRG).pdf %.eps: %.fig $(FIG2DEV) -L eps $< $@ %.pdf: %.fig $(FIG2DEV) -L pdf $< $@ %.png: %.fig $(FIG2DEV) -L png $< $@
Habe dafür die beiden Zeilen für AVRDUDE von den Hilfen hier im Netz dazugefügt.
AVRDUDE_PROGRAMMER= stk200
AVRDUDE_PORT =lpt1
Leider rührt sich da aber nix
Jetzt habe ich mal wieder das Originale File Von "MFILE" probiert und
meine Werte dazu geändert
c-File = Meines.c
STK200 /LPT1
Ist in der zweiten Teil (Nachrichtentext zu lang)
Es kommt dann immer die Meldung:
No rule to make target 'obj/main.o' needed by 'Meines.elf'. STop
Bitte um Hilfe!
Habe das Forum durchgeschaut , aber dazu leider nicht viel gefunden
(nur Standardeinstellungen für das Makfile von File-Name und Prozessor..)
Gibt es vielleicht irgendwo ein gute beschreibung für Makile's in deutsch?
l.G. Roberto
Zitieren
Lesezeichen
