Thema: Fehler beim starten des RP6Loader
    Hi wenn ich den RP6Loader starten möchte bekomme ich diese Fehlermeldung...
    Hab mir von JAVA das neuste JRE besorgt und installiert da gabst keine probleme.
    Auf meinem Rechner läuft WINXP prof. SP2.
    Kann mir da jemand helfen?
    Exception in thread "main" java.lang.NoClassDefFoundError: gnu/io/SerialPortEventListener
    at java.lang.ClassLoader.defineClass1(Native Method)
    at java.lang.ClassLoader.defineClass(Unknown Source)
    at java.security.SecureClassLoader.defineClass(Unknow n Source)
    at java.net.URLClassLoader.defineClass(Unknown Source)
    at java.net.URLClassLoader.access$000(Unknown Source)
    at java.net.URLClassLoader$1.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(Unknown Source)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
    at java.lang.ClassLoader.loadClassInternal(Unknown Source)
    at de.dsh.rp6loader.Init.<init>(Unknown Source)
    at sun.reflect.NativeConstructorAccessorImpl.newInsta nce0(Native Method)
    at sun.reflect.NativeConstructorAccessorImpl.newInsta nce(Unknown Source)
    at sun.reflect.DelegatingConstructorAccessorImpl.newI nstance(Unknown Source)
    at java.lang.reflect.Constructor.newInstance(Unknown Source)
    at java.lang.Class.newInstance0(Unknown Source)
    at java.lang.Class.newInstance(Unknown Source)
    at de.dsh.rp6loader.Init.main(Unknown Source)
    Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: gnu/io/SerialPortEventListener
    at cls.r.paint(Unknown Source)
    at javax.swing.JComponent.paintChildren(Unknown Source)
    at javax.swing.JComponent.paint(Unknown Source)
    at javax.swing.JLayeredPane.paint(Unknown Source)
    at javax.swing.JComponent.paintToOffscreen(Unknown Source)
    at javax.swing.BufferStrategyPaintManager.paint(Unkno wn Source)
    at javax.swing.RepaintManager.paint(Unknown Source)
    at java.awt.GraphicsCallback$PaintCallback.run(Unknow n Source)
    at sun.awt.SunGraphicsCallback.runOneComponent(Unknow n Source)
    at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
    at java.awt.Container.paint(Unknown Source)
    at javax.swing.RepaintManager.paintDirtyRegions(Unkno wn Source)
    at javax.swing.RepaintManager.seqPaintDirtyRegions(Un known Source)
    at javax.swing.SystemEventQueueUtilities$ComponentWor kRequest.run(Unknown Source)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    der JAVA 5 Loader funktioniert...
    Paderborn
    @Neburg
    Der RP6Loader erstellt ein Logfile - da stehen noch einige zusätzliche Infos drin die ich benötige um den Fehler einzugrenzen.
    Also mach mal bitte folgendes:
    - RP6Loader starten
    - Fehlermeldung schließen
    - "RP6Loader_logfile.log" kopieren und mir per Mail oder PN schicken (s. entsprechende Buttons hier im Forum)
    Es sieht so aus, als würde der RP6Loader hier schlicht eine benötigte Library nicht finden, was meistens an falsch gesetzten Pfaden liegt.
    --> Im RP6Loader Verzeichnis sind ZWEI .exe Dateien drin - versuch es mal mit der anderen!
    MfG,
    SlyD
    Hab beide probiert immer das selbe ich habe dir das Log mal per PN geschickt.
    Möchtest du auch das log von dem JAVA 5 Loader?
    Paderborn
    Hallo Neburg,
    ja Du kannst mir auch mal das JRE 5 log schicken, aber versuch es vorher mal hiermit:
    http://www.arexx.com/rp6/downloads/R...r_20070907.zip
    Wenn es damit auch nicht klappen sollte, schick mir bitte davon auch nochmal das Logfile per pn.
    MfG,
    SlyD
    Der Funktioniert.
    Vielen Dank-
