Ergebnis 11 bis 20 von 26
Thema: AT MEGA 8 - TWI - Master und Slave - Programmbeispiel
    jojo.glaser
    Hi Martin!
    Der Slave läuft!
    Beim Master werden mir noch folgende fehler angezeigt:
    rm -rf main.o main.elf dep/* main.hex main.eep
    Build succeeded with 0 Warnings...
    avr-gcc.exe -mmcu=atmega8 -Wall -gdwarf-2 -O0 -MD -MP -MT main.o -MF dep/main.o.d -c ../main.c
    avr-gcc.exe -mmcu=atmega8 main.o -o main.elf
    main.o: In function `main':
    ../main.c:29: undefined reference to `i2c_init'
    ../main.c:32: undefined reference to `i2c_start'
    ../main.c:35: undefined reference to `i2c_stop'
    ../main.c:39: undefined reference to `i2c_write'
    ../main.c:40: undefined reference to `i2c_write'
    ../main.c:41: undefined reference to `i2c_stop'
    ../main.c:45: undefined reference to `i2c_start_wait'
    ../main.c:46: undefined reference to `i2c_write'
    ../main.c:47: undefined reference to `i2c_rep_start'
    ../main.c:48: undefined reference to `i2c_readNak'
    ../main.c:49: undefined reference to `i2c_stop'
    ../main.c:55: undefined reference to `i2c_start_wait'
    ../main.c:56: undefined reference to `i2c_write'
    ../main.c:57: undefined reference to `i2c_write'
    ../main.c:58: undefined reference to `i2c_write'
    ../main.c:59: undefined reference to `i2c_write'
    ../main.c:60: undefined reference to `i2c_write'
    ../main.c:61: undefined reference to `i2c_stop'
    ../main.c:65: undefined reference to `i2c_start_wait'
    ../main.c:66: undefined reference to `i2c_write'
    ../main.c:67: undefined reference to `i2c_rep_start'
    ../main.c:68: undefined reference to `i2c_readAck'
    ../main.c:69: undefined reference to `i2c_readAck'
    ../main.c:70: undefined reference to `i2c_readAck'
    ../main.c:71: undefined reference to `i2c_readNak'
    ../main.c:72: undefined reference to `i2c_stop'
    make: *** [main.elf] Error 1
    Build failed with 26 errors and 0 warnings...
    in der i2cmaster.h steht fast nichts nur von irgend welchen externen funktionen oder so, verstehe nicht ganz was damit gemeint ist und für was die i2cmaster.h gut ist. Is kaum code drin...
    Gruß Jo!
    Geislingen a. d. Steige
    du musst die i2c_master.c ins make file includen
    jojo.glaser
    Hm.. hab ich gemacht.. also in der liste links vom AVR studio ist es unter header eingetragen... Aber is rot durchgestrichen, weis net was des bedeudet...
    du musste den unter source files rein tun!
    MfG Martin
    jojo.glaser
    Grrrrr... Danke, dass du mir hilfst, würd des allein nie hinbekommten!
    rm -rf main.o i2cmaster.o main.elf dep/* main.hex main.eep
    make: *** No rule to make target `i2cmaster.o', needed by `main.elf'. Stop.
    Build failed with 1 errors and 0 warnings...
    Mainz
    Hi Leute, bin durch Zufall hier vorbeigestolpert.
    Ich benutze die TWI-Lib auch in meinem Projekt.
    Wie ist das mit "twimaster.c" vs "i2c_master.S"?
    Dachte die Assembler-Implementierung (.S) sei zu bevorzugen, da Hardwarenah???
    12°29´ O, 48°38´ N
    @mefiX
    das ist genau andersrum, TWI ist die Hardware,
    der Assemblerteil für die Softwarelösung.
    Mit Assembler ist die Programmierung Hardwarenah, aber nicht das I2C
    jojo.glaser
    Mein Compiller zeigt noch folgende Meldung:
    Was hab ich falsch gemacht?
    Gruß Jo
    Irgent was stimmt mit deinem make file nicht!
    MfG Martin
    Hallo MartinFunk,
    Zitat Zitat von MartinFunk
    für den master würde ich die I2C library von P. Fluery nehmen: http://homepage.hispeed.ch/peterfleu...ware.html#libs
    und für den Slave die Aplication Note 311 von Atmel verwenden.
    MfG Martin
    Hättest Du bitte auch einen Ratschlag für mich? Ich will einen mega168 als Master (eigene Flash- und Experimentierplatine) und einen m16 als Slave (auf der RNControl) betreiben. Später sollen es zwei m168 sein. Ziel ist ein Austausch von ein paar Steuerdaten und Messwerten zwischen den beiden (m168: Master + Steuerdaten an m16, m16 Messwerte an m168; m168 schickt später auch Stausmeldungen an die RS232.
    Dazu habe ich mir vor ein paar Tagen die beiden App´s 311 und 315 geholt, den Code dazu und einfach übersetzt. Leider finde ich nirgendwo die beiden headerfiles ioavr.h und inavr.h und steh nun etwas auf dem sprichwörtlichen Schlauch. Hättest Du bitte einen Tip?
    Ich verwende ansonsten AVRStudio 4.13.557 Service Pack 1 GUI Version , 13, 0, 557 und WinAVR 2007 0525.
    Danke im Voraus
