Ergebnis 1 bis 10 von 15
Thema: geschafft : mmc-karte zu fuss mit bascom proggen...hurra
    es ist geschafft. die mmc-karte kann ich jetzt zu fuss proggen mit bascom, nur über "shiftout-befehl" und "shiftin-befehl" sectoren beschreiben.
    das auslesen geht genauso einfach. kann jeder selbst ergänzen.
    bei mir laufen damit 4 verschiedene mmc/sd-karten.
    hier der code :
    $regfile = "m32def.dat"
    $framesize = 32
    $swstack = 32
    $hwstack = 64
    $crystal = 8000000
    $baud = 19200
    Declare Sub Mc_init()
    Declare Sub Mc_write()
    Dim Dout As Byte
    Dim Din As Byte
    Dim A As Word
    Dim Cmd(6) As Byte
    Dim Buffer(515) As Byte
    Dim Tmp As Long
    Dim Sector As Long
    Mcs Alias Portb.0
    Mosi Alias Portb.1
    Miso Alias Pinb.2
    Sck Alias Portb.3
    Config Pinb.0 = Output
    Config Pinb.1 = Output
    Config Pinb.2 = Input
    Config Pinb.3 = Output
    Waitms 255
    Sector = 0
    Buffer(1) = &HFE
    Buffer(514) = &HFF
    Buffer(515) = &HFF
    For A = 2 To 513
       Buffer(a) = 71
    Next
    Call Mc_init()
    Call Mc_write()
    End
    Sub Mc_init()
       Set Mcs
       Dout = &HFF
       For A = 0 To 10
          Shiftout Mosi , Sck , Dout , 1 , 8 , 16
       Next
    Anfang:
       Reset Mcs
       Cmd(1) = &H40
       Cmd(2) = 0
       Cmd(3) = 0
       Cmd(4) = 0
       Cmd(5) = 0
       Cmd(6) = &H95
       For A = 1 To 6
          Shiftout Mosi , Sck , Cmd(a) , 1 , 8 , 16
       Next
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       Shiftin Miso , Sck , Din , 1 , 8 , 16
       If Din <> 1 Then
          Goto Anfang
       End If
       Print Din
    Anfang1:
       Reset Mcs
       Cmd(1) = &H41
       Cmd(2) = 0
       Cmd(3) = 0
       Cmd(4) = 0
       Cmd(5) = 0
       Cmd(6) = &HFF
       For A = 1 To 6
       Next
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       If Din <> 0 Then
          Goto Anfang1
       End If
       Print Din
       Set Mcs
    End Sub
    Sub Mc_write()
       Set Mcs
       Cmd(1) = &H58
       Cmd(2) = 0
       Cmd(3) = 0
       Cmd(4) = 0
       Cmd(5) = 0
       Cmd(6) = &HFF
       Shift Sector , Left , 9
       Tmp = Sector And &HFF000000
       Shift Tmp , Right , 24
       Cmd(2) = Tmp
       Tmp = Sector And &H00FF0000
       Shift Tmp , Right , 16
       Cmd(3) = Tmp
       Tmp = Sector And &H0000FF00
       Shift Tmp , Right , 8
       Cmd(4) = Tmp
    Anfang2:
       Reset Mcs
       For A = 1 To 6
       Next
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       If Din <> 0 Then
          Goto Anfang2
       End If
       Print Din
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       For A = 1 To 515
          Dout = Buffer(a)
          Waitus 10
       Next
       Waitus 10
       Print Din
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       Set Mcs
    End Sub
    Baoding
    Schön , ein paar Kommentare im Quellcode würden dem Anfänger sicher hilfreich sein.
    =D>
    Ja, ein bisschen Erklärung, brauche ich auch. Übrigens, selbst wenn ich was programmiere, schreibe ich mir REM's, denn in 3 Tagen weiß ich nicht mehr warum ich Das oder Dieses gemacht habe....
    Soll heißen: ist keine Kritik !!!
    Warum macht man das immer einmal so zwischendurch :
    For A = 1 To 8
    Reset Sck
    Waitus 10
    Set Sck
    Waitus 10
    Next
    Als "Füller" ?
    man muss das diagramm kennen. einige im forum haben es ohne diagramm gemacht und es haut nicht hin. hier ist die superbeschreibung für eine mmc-karte , viel spass, ist einfach zu lesen. danach habe ich mein programm geschrieben :
    http://elm-chan.org/docs/mmc/mmc_e.html
    ich habe ein hundertjähriges gedächtnis für programme.
    aha ,
    deswegen der Name, ich bin froh mich Morgens im Spiegel zu erkennen....
    BA-Wü
    Wir haben aber leider keine Glaskugel ^^ (soll keine Kritik sein) Bild hier
    Viele Grüße,
    Michael
    Sn60Pb40 Rulez
    www.silvestercountdown.de.vu- Dein Countdown bis Neujahr!
    danach kann man mein programm auch gut verfolgen. warum...wo...wie lange...was...hin gehört. auch die codebefehle stehen dabei.
    http://www.ulrichradig.de/site/atmel...CSDTimming.pdf
    Vielen Dank "Hero", auch der erste Link, für Deutschleser wie mich, mit Google übersetzt, ist schon gut lesbar.
    hier für die Tüftler die mc_read-routine(512byte):
    Sub Mc_read()
       Set Mcs
       Cmd(1) = &H51
       Cmd(2) = 0
       Cmd(3) = 0
       Cmd(4) = 0
       Cmd(5) = 0
       Cmd(6) = &HFF
       Cmd(2) = Tmp
       Cmd(3) = Tmp
       Cmd(4) = Tmp
    Anfang3:
       Reset Mcs
       For A = 1 To 6
       Next
       For A = 1 To 8
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       If Din <> 0 Then
          Goto Anfang3
       End If
       Print Din
       For A = 1 To 16
          Reset Sck
          Waitus 10
          Set Sck
          Waitus 10
       Next
       If Din <> &HFE Then
          Goto Ende
       End If
       For A = 2 To 515
          Buffer(a) = Din
       Next
    Ende:
       Waitms 5
       Set Mcs
    End Sub
    mmc-Karte zu fuss
    Hallo, was spricht denn gegen die Verwendung von SPI anstatt von shiftout. Das vereinfacht das ganz doch ganz erheblich. Und wenn man dann noch die fertigen Routinen von Bascom nutzt wirds noch einfacher.
    Ich hänge mal meine Version der MMC-Routinen an die ich vor zwei Jahren geschrieben habe. Im zweiten Block mal die neue Version mit BASCOM-Bordmitteln.
    Vielleicht hilfts dem ein oder anderem.
    mfg.
    Joachim
    ' Connect AVR To MMC/SD with Bascom
    ' Copyright(c) 2005 Joachim Reiter
    ' based on code from Ulrich Radig
    ' Dieses Programm Ist Freie Software. Sie K�nnen Es Unter Den Bedingungen Der
    ' Gnu General Public License , Wie Von Der Free Software Foundation Ver�ffentlicht,
    ' Weitergeben Und / Oder Modifizieren , Entweder Gem�� Version 2 Der Lizenz Oder
    ' (nach Ihrer Option) Jeder Sp�teren Version.
    ' Die Ver�ffentlichung Dieses Programms Erfolgt In Der Hoffnung,
    ' Da� Es Ihnen Von Nutzen Sein Wird , Aber Ohne Irgendeine Garantie,
    ' Sogar Ohne Die Implizite Garantie Der Marktreife Oder Der Verwendbarkeit
    ' F�r Einen Bestimmten Zweck. Details Finden Sie In Der Gnu General Public License.
    ' Sie Sollten Eine Kopie Der Gnu General Public License Zusammen Mit Diesem
    ' Programm Erhalten Haben.
    ' Falls Nicht , Schreiben Sie An Die Free Software Foundation,
    ' Inc. , 59 Temple Place , Suite 330 , Boston , Ma 02111 -1307 , Usa.
    $crystal = 8000000
    $baud = 19200
    Const Attr_long_name = &H0F
    Const Attr_read_only = &H01
    Const Attr_hidden = &H02
    Const Attr_system = &H04
    Const Attr_volume_id = &H08
    Const Attr_directory = &H10
    Const Attr_archive = &H20
    Config Portb = &B10110000
    Mmc_miso Alias Portb.6
    Mmc_mosi Alias Portb.5
    Mmc_cs Alias Portb.4
    Mmc_sck Alias Portb.7
    Set Mmc_cs
    Spsr = 0
    Dim Direntry(32) As Byte
    Dim Dir_name(8) As Byte At Direntry Overlay                    ' 8 chars filename
    Dim Dir_ext(3) As Byte At Direntry+&H08 Overlay                     ' 8 chars filename
    Dim Dir_attr As Byte At Direntry+$0b Overlay                        ' file attributes RSHA, Longname, Drive Label, Directory
    Dim Dir_dummy(10) As Byte At Direntry+$0c Overlay
    Dim Dir_time As Word At Direntry+$16 Overlay                        ' creation time part in milliseconds
    Dim Dir_date As Word At Direntry+$18 Overlay                        ' creation time
    Dim Dir_cluster As Word At Direntry+$1a Overlay                     ' first cluster high word
    Dim Dir_filesize As Long At Direntry+$1c Overlay
    Dim Fat_adresse As Long
    Dim Dir_adresse As Long
    Dim Data_adresse As Long
    Dim Buffer(512) As Byte
    Dim Vbr_start As Long At Buffer+&H1C6 Overlay
    Dim Bytespersektor As Word At Buffer+&H0B Overlay
    Dim Sektorpercluster As Byte At Buffer+&H0D Overlay
    Dim Reservedsektor As Byte At Buffer+&H0E Overlay
    Dim Maxrootentry As Word At Buffer+&H11 Overlay
    Dim Sektorprofat As Word At Buffer+&H16 Overlay
    Dim Cmd(6) As Byte
    Dim Count As Integer
    Dim Count1 As Integer
    Dim Timeout As Byte
    Dim Timeout1 As Byte
    Dim Tmp As Byte
    Dim Anz_bytes As Word
    Dim Fn_ergo As Byte
    Dim Addr As Long
    'Dim Tmpaddr As Long
    Dim Databyte As Byte
    Dim File_cluster As Word
    Declare Sub Mmc_write_byte(databyte As Byte)
    Declare Function Mmc_read_byte() As Byte
    Declare Function Mmc_init() As Byte
    Declare Function Mmc_write_command(cmd() As Byte) As Byte
    Declare Function Mmc_write_sector(addr As Long) As Byte
    Declare Sub Mmc_read_block(cmd() As Byte , Anz_bytes As Word)
    Declare Sub Mmc_read_sector(byval Addr As Long)
    Declare Sub Mmc_read_csd()
    Declare Sub Mmc_read_cid()
    Declare Sub Scandisk()
    Declare Function Readfile(byval Cluster As Word) As Word
    Declare Sub Readdir(byval Nr As Word)
    Declare Sub Outbuffer()
    Main:
      Print "Press any Key"
      Loop Until Inkey() <> 0
      Fn_ergo = Mmc_init()
      If Fn_ergo <> 0 Then
        Print "Keine Karte gefunden " ; Fn_ergo
        Goto Main
      End If
      Print "Karte gefunden"
      Call Scandisk
      Print "DIR :" ; Dir_adresse
      Print "FAT :" ; Fat_adresse
      Print "DATA:" ; Data_adresse
      Call Mmc_read_sector(dir_adresse )
      Call Outbuffer()
      For Count = 1 To 32
        Direntry(count) = Buffer(32 + Count)
      Next X
      For Count = 1 To 8
        Print Chr(dir_name(count));
      Next Count
      Print ".";
      For Count = 1 To 3
        Print Chr(dir_ext(count));
      Next Count
      Print "  " ; Dir_filesize ; "   " ; Dir_cluster
      File_cluster = Readfile(dir_cluster)
      Print "xxxxx:" ; File_cluster
      Call Outbuffer()
    Goto Main
    Sub Outbuffer()
      Local Otmp As Word
      Local Otmp1 As Byte
      Local Ocount As Byte
      Local Ocount1 As Byte
      For Ocount = 0 To 31
        Otmp = Ocount * 16
        Print Hex(otmp) ; "  ";
        For Ocount1 = 1 To 16
          Incr Otmp
          Print Hex(buffer(otmp)) ; " ";
        Next Ocount1
        Otmp = Ocount * 16
          Incr Otmp
          Otmp1 = Buffer(otmp)
          If Otmp1 < 32 Then Otmp1 = 46
          Print Chr(otmp1);
        Next Ocount1
        Print
      Next Ocount
      Print
    End Sub
    Goto Main
      Call Mmc_read_csd()
      For Count = 1 To 16
        Print Hex(buffer(count)) ; " ";
      Next X
      Print
      Input "Blocknummer " , Addr
      Goto Main
    End
    ' Lese Directoryeintrag
      Local X As Byte
      Local Y As Byte
      Local Rcount As Byte
      Local Rtmp As Word
      Call Mmc_read_sector(dir_adresse)
      For X = 1 To 15
        Rtmp = X * 32
        ' Leereintrag, das wars dann
        If Buffer(rtmp + 1) = 0 Then Exit For
        ' Gel�schter Eintrag
        If Buffer(rtmp + 1) <> &HE5 Then
          For Count = 1 To 32
            Incr Rtmp
            Direntry(count) = Buffer(rtmp)
          Next Count
          For Count = 1 To 8
          Next Count
         Print ".";
         For Count = 1 To 3
          Next Count
        End If
      Next X
    End Sub
    ' liest Cluster von File aus und gibt n�chsten Cluster zur�ck
    ' FFFF als R�ckgabe = Ende des Files
      Local Nextcluster As Word
      Local Fatblock As Long
      Local Fatadresse As Long
      Local Tcl As Long
      Print "bbbbbb"
      Fatblock=Cluster*2
      Fatadresse = Fatblock Mod Bytespersektor
      Fatblock = Fatblock / Bytespersektor
      Fatblock = Fatblock + Fatadresse
      Call Mmc_read_sector(fatblock)
      Print "ccccc" ; Fatblock ; " " ; Fatadresse
      NextCluster=Buffer(Fatadresse)*256
      NextCluster=Nextcluster+Buffer(Fatadresse+1)
      Call Mmc_read_sector(tcl)
      ' Offset wegen Dateianfang
      Cluster = Cluster - 2
      Cluster = Cluster * Sektorpercluster
      ' und zu Anfang dazumachen
      Cluster = Cluster + Data_adresse
      ' und auslesen
      Tcl = Cluster
    Print "aaa:" ; Tcl ; "  " ; Nextcluster
    Print "vvvvv"
      ' Naechsten Cluster zurueckgeben
      ReadFile=NextCluster
    End Function
    Sub Scandisk()
      Local Ltmp As Long
      Ltmp = 0
      ' Aus Sektor 0 an H1C6 Long auslesen = Volume-Boot Record
      Call Mmc_read_sector(ltmp )
      ' VBR lesen
      Ltmp = Vbr_start
      Dir_adresse = 2 * Sektorprofat
      Dir_adresse = Dir_adresse + Ltmp
      Dir_adresse = Dir_adresse + Reservedsektor
      Fat_adresse = Ltmp + 1
      Data_adresse = Maxrootentry * 32
      Data_adresse = Data_adresse / Bytespersektor
      Data_adresse = Data_adresse + Dir_adresse
    End Sub
      Spdr = Databyte
      Bitwait Spsr.spif , Set
    End Sub
      Spdr = &HFF
      Mmc_read_byte = Spdr
    End Function
    ' ###### Routine zur Initialisierung der MMC /SD - Karte (spi -mode)
      Set Mmc_cs
      Spsr = 0
      Set Spcr.spe
      Set Spcr.mstr
      Set Spcr.spr0                                             ' CLK/128
      Set Spcr.spr1
      Set Mmc_cs                                                ' disable card
      ' Initialisiere MMC / SD - Karte in den SPI-Mode
      Databyte = &HFF
      For Count = 1 To 16                                       ' Sendet Min 74+ Clocks an die MMC/SD-Karte
        Call Mmc_write_byte(databyte)
      Next Count
      ' Sendet Kommando Cmd0 an MMC/SD-Kkarte
      Cmd(1) = &H40
      Cmd(2) = &H00
      Cmd(3) = &H00
      Cmd(4) = &H00
      Cmd(5) = &H00
      Cmd(6) = &H95
      Timeout = 0
        Fn_ergo = Mmc_write_command(cmd(1))
        Incr Timeout
        If Timeout > 200 Then
          Mmc_init = 1                                          ' Abbruch Bei Commando1
          Exit Function
        End If
      Loop Until Fn_ergo = 1
      Cmd(1) = &H41
      Cmd(2) = &HFF
      Timeout = 0
        Incr Timeout
          Mmc_init = 2                                          ' Abbruch Bei Commando 2
          Exit Function
        End If
      Loop Until Fn_ergo = 0
      ' SPI Bus auf maximale Ggeschwindigkeit
      Reset Spcr.spr0
      Reset Spcr.spr1
      Set Spsr.spi2x
      Set Mmc_cs                                                ' Set Mmc_chip_select To High(mmc / Sd -karte Inaktiv)
      Mmc_init = 0
    End Function
    ' ###### Sendet ein Commando an die MMC/SD-Karte
      Local Ldatabyte As Byte
      Ldatabyte = &HFF
      Local Ltimeout As Byte
      Ltimeout = 0
      ' Set Mmc_chip_select to high(MMC/SD-Karte Inaktiv)
      Set Mmc_cs
      ' Sendet 8 Clock Impulse
      Call Mmc_write_byte(ldatabyte)
      ' Set Mmc_chip_select to low(MMC/SD-Karte Aktiv)
      Reset Mmc_cs
      ' Sendet 6 Byte Commando
      For Count = 1 To 6
        Call Mmc_write_byte(cmd(count))
      Next Count
      Ldatabyte = &HFF
      ' Wartet Auf Ein G�ltige Antwort Von Der Mmc / Sd -karte
      While Ldatabyte = &HFF
        Ldatabyte = Mmc_read_byte()
        Incr Ltimeout
        If Ltimeout > 100 Then Exit While
      Wend
      Mmc_write_command = Ldatabyte
    End Function
    ' ###### Routine Zum Schreiben Eines Blocks(512byte) Auf Die Mmc / Sd -karte
      Local Tmpaddr As Long
      ' Sende Kommando Cmd24 zum Schreiben an MMC/SD-Kkarte
      Cmd(1) = &H58
      Cmd(2) = &H00
      Cmd(3) = &H00
      Cmd(4) = &H00
      Cmd(5) = &H00
      Cmd(6) = &HFF
      ' Die Adressierung Der Mmc / Sd -karte Wird In Bytes Angegeben,
      ' Addr Wird Von Blocks Zu Bytes Umgerechnet Danach Werden
      ' Diese In Das Commando Eingef�gt * /
      Shift Addr , Left , 9                                     ' Addr = Addr * 512
      Tmpaddr = Addr And &HFF000000
      Shift Tmpaddr , Right , 24
      Cmd(2) = Tmpaddr
      Tmpaddr = Addr And &H00FF0000
      Shift Tmpaddr , Right , 16
      Cmd(3) = Tmpaddr
      Tmpaddr = Addr And &H0000FF00
      Shift Tmpaddr , Right , 8
      Cmd(4) = Tmpaddr
      ' Sendet Commando Cmd24 An Mmc / Sd -karte(write 1 Block / 512 Bytes)
      If Fn_ergo <> 0 Then Return
      ' Wartet Einen Moment Und Sendet Einen Clock An Die Mmc / Sd -karte
      For Count = 1 To 100
        Databyte = Mmc_read_byte()
      Next
      ' Sendet Start Byte An Mmc / Sd -karte
      Databyte = &HFE
      ' Schreiben Des Bolcks(512bytes) Auf Mmc / Sd -karte
      For Count = 1 To 512
        Call Mmc_write_byte(buffer(count))
      Next Count
      ' Crc -byte Schreiben
      Databyte = &HFF
      ' Wartet Auf Mmc / Sd -karte Busy
      Loop Until Databyte = &HFF
      Set Mmc_cs
      Mmc_write_sector = 0
    End Function
    ' ###### Routine Zum Lesen Des Cid Registers Von Der Mmc / Sd -karte(16bytes)
      ' Sendet Commando Cmd An Mmc / Sd -karte
      ' Wartet Auf Start Byte Von Der Mmc / Sd -karte(feh / Start Byte)
      Loop Until Databyte = &HFE
      ' Lesen Des Bolcks(normal 512bytes) Von Mmc / Sd -karte
      For Count = 1 To Anz_bytes
        Buffer(count) = Mmc_read_byte()
      Next Count
      ' Crc -byte Auslesen
      Set Mmc_cs
    End Sub
    ' ###### Routine Zum Lesen Eines Blocks(512byte) Von Der Mmc / Sd -karte
    Sub Mmc_read_sector(byval Addr As Long )
      ' Kommando 17 Zum Lesen Eines Blocks Von Der Mmc / Sd - Karte
      Cmd(1) = &H51
      Cmd(2) = &H00
      Cmd(3) = &H00
      Cmd(4) = &H00
      Cmd(5) = &H00
      Cmd(6) = &HFF
      Cmd(2) = Tmpaddr
      Cmd(3) = Tmpaddr
      Cmd(4) = Tmpaddr
    Print "READSEC  ";
      Anz_bytes = 512
      Call Mmc_read_block(cmd(1) , Anz_bytes)
    Print "retuor"
    End Sub
    Sub Mmc_read_cid()
      ' Kommando 10 zum Lesen des CID
      Cmd(1) = &H4A
      Cmd(2) = &H00
      Cmd(3) = &H00
      Cmd(4) = &H00
      Cmd(5) = &H00
      Cmd(6) = &HFF
      Anz_bytes = 16
    End Sub
    ' ###### Routine Zum Lesen Des Csd Registers Von Der Mmc / Sd -karte(16bytes)
    Sub Mmc_read_csd()
      ' Kommando 9 zum Lesen des CSD
      Cmd(1) = &H49
      Cmd(2) = &H00
      Cmd(3) = &H00
      Cmd(4) = &H00
      Cmd(5) = &H00
      Cmd(6) = &HFF
      Anz_bytes = 16
    End Sub
    Und nun die neue Version mit der mmc-lib.
    $crystal = 16000000
    $baud = 9600
    Baud = 9600
    Dim Abuffer(512) As Byte
    Dim Wsrampointer As Word
    '                         Config_MMC.BAS
    '               Config File for MMC Flash Cards Driver
    '        (c) 2003-2005 , MCS Electronics / V�gel Franz Josef
    ' Place MMC.LIB in the LIB-Path of BASCOM-AVR installation
    'Connection as following
    'MMC    M128/M103
    '1      MMC_CS PORTB.0
    '2      MOSI PORTB.2
    '3      GND
    '4      +3.3V
    '5      CLOCK PORTB.1
    '6      GND
    '7      MISO, PORTB.3
    ' you can vary MMC_CS on HW-SPI and all pins on SOFT-SPI, check settings
    ' ========== Start of user definable range =====================================
    ' you can use HW-SPI of the AVR (recommended) or a driver build in Soft-SPI, if
    ' the HW-SPI of the AVR is occupied by an other SPI-Device with different settings
    ' Declare here you SPI-Mode
    ' using HW-SPI:     cMMC_Soft = 0
    ' not using HW_SPI: cMMC_Soft = 1
    Const Cmmc_soft = 0
    ' define Chip-Select Pin
    Config Pinb.0 = Output                                      ' define here Pin for CS of MMC/SD Card
    Max_cs Alias Portb.0
    Set Max_cs
    Config Pinb.1 = Output                                      ' define here Pin for CS of MMC/SD Card
    Mmc_cs Alias Portb.1
    Set Mmc_cs
    ' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
    Config Pinb.4 = Output                                      ' define here Pin of SPI SS
    Spi_ss Alias Portb.4
    Set Spi_ss                                                  ' Set SPI-SS to Output and High por Proper work of
                                                      ' SPI as Master
    ' HW-SPI is configured to highest Speed
    Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = high , Phase = 1 , Clockrate = 64 , Noss = 1
    'Spsr = 1                                                    ' Double speed on ATMega128
    Spiinit                                                     ' Init SPI
    ' ========== End of user definable range =======================================
    ' Error
    Const Cperrdrivereset = 225                                 ' Error response Byte at Reset command
    Const Cperrdriveinit = 226                                  ' Error response Byte at Init Command
    Const Cperrdrivereadcommand = 227                           ' Error response Byte at Read Command
    Const Cperrdrivewritecommand = 228                          ' Error response Byte at Write Command
    Const Cperrdrivereadresponse = 229                          ' No Data response Byte from MMC at Read
    Const Cperrdrivewriteresponse = 230                         ' No Data response Byte from MMC at Write
    Const Cperrdrive = 231
    Const Cperrdrivenotsupported = 232                          ' return code for DriveGetIdentity, not supported yet
    Waitms 1                                                    ' Wait some time before initialising MMC/SD
    Dim Gbdriveerror As Byte                                    ' General Driver Error register
    Dim Gbdriveerrorreg As Byte                                 ' Driver load Error-Register of HD in case of error
    Dim Gbdrivestatusreg As Byte                                ' Driver load Status-Register of HD on case of error
    Dim Gbdrivedebug As Byte
    $lib "MMC.LIB"                                              ' link driver library
    $external _mmc
    Dim I As Word
    Dim Sectornr As Long
    Wsrampointer = Varptr(abuffer(1))
    Print
    Input "Start?" , I
    Gbdriveerror = Driveinit()                                  ' Init MMC/SD Card
    Print "Init ";
    Print Gbdriveerror
      Print
      Input "Sector:" , Sectornr
      Gbdriveerror = Drivereadsector(wsrampointer , Sectornr)
      Print "Read" ; Gbdriveerror
      For I = 1 To 512
        Print Abuffer(i) ;
        Print " ";
      Next I
      Waitms 1000
    End                                                         'end program
