- Eleshop Messgeraete Angebote    Werbung
Thema: Beispielprogramm läst sich nicht kompilieren
    hallo,
    ich habe mal Test weise das Beispielprogramm aus der Bascom-Hilfe kopiert und kompiliert. Es geht nicht
    Hier der Code, 1:1 auß der Hilfe kopiert
    'name                     : t6963_240_128.bas
    'copyright                : (c) 1995-2005, MCS Electronics
    'purpose                  : T6963C graphic display support demo 240 * 128
    'micro                    : Mega8535
    'suited for demo          : yes
    'commercial addon needed  : no
    $regfile = "m8535.dat"                                      ' specify the used micro
    $crystal = 8000000                                          ' used crystal frequency
    $baud = 19200                                               ' use baud rate
    $hwstack = 32                                               ' default use 32 for the hardware stack
    $swstack = 10                                               ' default use 10 for the SW stack
    $framesize = 40                                             ' default use 40 for the frame space
    '                     (c) 2001-2008 MCS Electronics
    '                 T6963C graphic display support demo 240 * 128
    'The connections of the LCD used in this demo
    'LCD pin                  connected to
    ' 1        GND            GND
    '2        GND            GND
    '3        +5V            +5V
    'micro                    : Mega8535
    ' 1        GND            GND
    '2        GND            GND
    '3        +5V            +5V
    '4        -9V            -9V potmeter
    '5        /WR            PORTC.0
    '6        /RD            PORTC.1
    '7        /CE            PORTC.2
    '8        C/D            PORTC.3
    '9        NC             not conneted
    '10       RESET          PORTC.4
    '11-18    D0-D7           PA
    '19       FS             PORTC.5
    '20       NC             not connected
    'First we define that we use a graphic LCD
    ' Only 240*64 supported yet
    Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 2 , Cd = 3 , Wr = 0 , Rd = 1 , Reset = 4 , Fs = 5 , Mode = 8
    'The dataport is the portname that is connected to the data lines of the LCD
    'The controlport is the portname which pins are used to control the lcd
    'CE, CD etc. are the pin number of the CONTROLPORT.
    ' For example CE =2 because it is connected to PORTC.2
    'mode 8 gives 240 / 8 = 30 columns , mode=6 gives 240 / 6 = 40 columns
    'Dim variables (y not used)
    Dim X As Byte , Y As Byte
    'Clear the screen will both clear text and graph display
    Cls
    'Other options are :
    ' CLS TEXT   to clear only the text display
    ' CLS GRAPH  to clear only the graphical part
    Cursor Off
    Wait 1
    'locate works like the normal LCD locate statement
    ' LOCATE LINE,COLUMN LINE can be 1-8 and column 0-30
    Locate 1 , 1
    'Show some text
    Lcd "MCS Electronics"
    'And some othe text on line 2
    Locate 2 , 1 : Lcd "T6963c support"
    Locate 3 , 1 : Lcd "1234567890123456789012345678901234567890"
    Locate 16 , 1 : Lcd "write this to the lower line"
    Wait 2
    Cls Text
    'use the new LINE statement to create a box
    'LINE(X0,Y0) - (X1,Y1), on/off
    Line(0 , 0) -(239 , 127) , 255                              ' diagonal line
    Line(0 , 127) -(239 , 0) , 255                              ' diagonal line
    Line(0 , 0) -(240 , 0) , 255                                ' horizontal upper line
    Line(0 , 127) -(239 , 127) , 255                            'horizontal lower line
    Line(0 , 0) -(0 , 127) , 255                                ' vertical left line
    Line(239 , 0) -(239 , 127) , 255                            ' vertical right line
    Wait 2
    ' draw a line using PSET X,Y, ON/OFF
    ' PSET on.off param is 0 to clear a pixel and any other value to turn it on
    For X = 0 To 140
      Pset X , 20 , 255                                        ' set the pixel
    Next
    For X = 0 To 140
      Pset X , 127 , 255                                       ' set the pixel
    Next
    Wait 2
    'circle time
    'circle(X,Y), radius, color
    'X,y is the middle of the circle,color must be 255 to show a pixel and 0 to clear a pixel
    For X = 1 To 10
    Circle(20 , 20) , X , 255                                 ' show circle
    Wait 1
    Circle(20 , 20) , X , 0                                   'remove circle
    Wait 1
    Next
    Wait 2
    For X = 1 To 10
    Waitms 200
    Next
    Wait 2
    'Now it is time to show a picture
    'SHOWPIC X,Y,label
    'The label points to a label that holds the image data
    Test:
    Showpic 0 , 0 , Plaatje
    Showpic 0 , 64 , Plaatje                                    ' show 2 since we have a big display
    Wait 2
    Cls Text                                                    ' clear the text
    End
    'This label holds the mage data
    Plaatje:
    '$BGF will put the bitmap into the program at this location
    $bgf "mcs.bgf"
    1for X = 1 To 10
    Waitms 200
    Next
    Wait 2
    'SHOWPIC X,Y,label
    Test:
    Wait 2
    End
    Plaatje:
    $bgf "mcs.bgf"
    und hier die Fehlermeldungen
    Error:1 Line: 52 Unknown statement[<], in file : C:\Programme\...Bas
    Error:31 Line :199 Invalid datatyoe [[0011]0], in file : C:\Programme\...Bas
    Error=93 Line:199 variable not dimensioned[0->0], in file : C:\Programme\...Bas
    inzwischen habe ich herrausgefunden, das die anweisung
    Cls text
    folgende Fehlermeldungen bringt:
    Error:1 Line:1 No more space for bit [__LCDREV], in file : C:\Programme\...Bas
    Error:31 Line:1 Invalid datatype[[0011]0], in file : C:\Programme\...Bas
    Error:93 Line:1 Variable not dimensioned [0->], in file : C:\Programme\...Bas
    die anweisung CLS GRAPH bringt ebenfalls die o.g. Fehlermeldungen.
    Die Anweisung
    bringt die Fehlermeldungen
    Error:211 Line:1 External routine not found [_GLINE]  in file : C:\Programme\...Bas
    Error:61 Line:1 Label not Foumd [_GLINE              ] in file : C:\Programme\...Bas
    warum geht das alles nicht?!?
    Ich hoffe ihr könnt mir helfen
    MfG bauteiltöter
    Hallo Bauteiltöter,
    welche Bascom-Version benutzt du? In der history.txt habe ich beim Update auf 1.11.9.2 folgendes gefunden:
    - CLS [option] failed while introducing new option for CLS for EADOGM128
    CLS mit Option sollte also vor und nach Version 1.11.9.1 funktionieren.
    Kann das sein, dass da beim Kopieren irgend etwas schief gegangen ist? Da ist Code doppelt vorhanden. Ist die Grafik, die eingebunden werden soll in deinem Verzeichnis vorhanden? Und "<" als Befehl gibt es wirklich nicht.
    Schau doch mal in dein Bascom-Verzeichnis. Unter Samples -> Lcdgraph findest du das Programm komplett. Da sind auch die BGF (Bascom Graphic File) Dateien drin. Bei mir lässt sich das auch problemlos kompilieren.
    Gruß, Stefan
    StevieL,
    ja, ichg benutze 1.11.9.1. ich hole mir dan ne neue version.
    die demos aus dem von dir genannten ordner funktionieren, außer KS108.
    da fehlt die Lib. is die in anderen versionen enthalten?
    Aber das erklärt immer noch nicht, warum der "line"-Befehl nicht geht...
    MfG Bauteiltöter
    Edit: ich finde nur die 1.11.9.1... auf "line" und "Cls Text" kann ich verzichten, aber ich brauche !Umbedingt! die KS108, kann ich die auch i-wo anderst bekommen?
    Edit2: So, jetzt geht auch die KS108.lib
    Edit3: Jetzt geht auch line. Ich hab einfach vergessen, 255 ans ende zu setzen
    Werbung      Solar Speicher und Akkus Tests
