Seite 3 von 3 ErsteErste 123
Ergebnis 21 bis 25 von 25
Thema: Erstes eigenes Programm
    Hallo Felix
    Ich kann dein Programm (mit auskommentiertem Speed) Fehler und warnungsfrei kompilieren. Irgendwas läuft wohl mit deinem Makefile schief:
    Mein Make mit KamAVR:
    avr-gcc -mmcu=atmega8 -Os -mno-interrupts -funsigned-char -funsigned-bitfields -Wall -Wstrict-prototypes -ggdb -c -DF_CPU=8000000UL -Wa,-acdhlmns=temp.lst temp.c -o temp.o
    avr-gcc -mmcu=atmega8 -Os -mno-interrupts -funsigned-char -funsigned-bitfields -Wall -Wstrict-prototypes -ggdb temp.o asuro.o -o test.elf -Wl,-Map=test.map --cref -lm
    avr-objcopy -j .text -j .data -O ihex test.elf test.hex
    avr-objcopy -j .eeprom --change-section-lma .eeprom=0 -O ihex test.elf test_eeprom.hex
    avr-objdump -d -S test.elf > test.lst
    Felix Make:
    C:\ASURO_src\FirstTry>make all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    [ -s test.d ] || rm -f test.d
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o --output test.elf -Wl,-Map=test.map,--cref -lm
    avr-objcopy -O ihex -R .eeprom test.elf test.hex
    avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    --change-section-lma .eeprom=0 -O ihex test.elf test.eep
    C:\Users\FELIXK~1\AppData\Local\Temp\make33804.sh: /c/WinAVR/bin/avr-objcopy: Invalid argument
    make: [test.eep] Error 126 (ignored)
    avr-objdump -h -S test.elf > test.lss
    C:\Users\FELIXK~1\AppData\Local\Temp\make33805.sh: /c/WinAVR/bin/avr-objdump: Invalid argument
    make: *** [test.lss] Error 126
    > Process Exit Code: 2
    Was das bedeutet kann ich auch nicht sagen. Mein KamAVR erzeugt seine Makefiles selbstständig.
    mic
    Hildesheim
    Ich habe mir das Programm auch mal gehiolt nur leider kann ich die Tools make und Clean nicht erstellen bzw einstellen gibt es da einen trick? wenn es so geht könnte mir dann vielleicht mal jemand die hex datei schicken? Falls ich es mit kam AVR auch nicht hinkrige?
    Wäre sehr nett
    Vielen dank im Vorraus
    felix
    Bevor du nun zig neue Anläufe mit anderen Programmen machst solltest du nochmals versuchen das mit dem asuro gelieferte winavr/gcc-Paket zum Laufen zu bringen. Zumal zumindest KamAVR auch eine funktionierende Installation von WinAVR benötigt. Also alles wieder löschen und neu installieren. Das ist zwar bitter, aber wenn es dann mal funktioniert brauchst du dich darum nie mehr zu kümmern.
    Im Anhang meine KamAVR-Einstellungen für den asuro. Wie gesagt wird aber eine funktionierende WinAVR-Installation vorausgesetzt. [Link: KamAVR]
    mic
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken kamavr-asuro.jpg
  4. #24
    Hildesheim
    Hallo Radbruch,
    Ich habe gar nicht bei KamAVR diese leiste zum einstellen der Tools beim mir sieht das so aus:
    ich habe Ihren tipp alles neu zu installieren probiert aber leider bleibt es beim gleichen wie vorher auch.. Kann das was mit Vista vielleicht in irgendeiner Form zu tun haben?
    Falls irgendjemand noch eine Idee hat bitte sagt sie mir ich bin am verzweifeln..
    Vielen dank
    Felix
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken unbenannt_149.jpg
  5. #25
    Es gibt scheinbar einige Probleme bei Vista. In der Forumsuche mal nach "asuro AND vista" suchen.
    Die Einstellunen in KamAVR sieht man erst nach file->new->new Project.
    mic
