Seite 1 von 9 123 ... LetzteLetzte
Ergebnis 1 bis 10 von 85
Thema: RP6Control M32: Library für 8 Servos
    NRW
    Hallo Leute,
    nach meiner Servo-Library für die RP6Base hier:
    https://www.roboternetz.de/phpBB2/viewtopic.php?t=45180
    ... jetzt auch eine einfache Version für max. 8 Servos für die RP6Control M32.
    Demoprogramm:
    // Uncommented Version of RP6ControlServo.c
    // written by Dirk
    #include "RP6ControlServoLib.h"
    uint16_t pos = 0;
    int main(void)
    	initRP6Control();
    	initLCD();
    	showScreenLCD("################", "################");
    	mSleep(1500);
    	showScreenLCD("<<RP6  Control>>", "<<LC - DISPLAY>>");
    	mSleep(2500);
    	showScreenLCD(" Servo - Test 1 ", "  Version 1.00  ");
    	mSleep(2500);
    	clearLCD();
    	setLEDs(0b111111);
    	mSleep(500);
    	setLEDs(0b000000);
    	initSERVO(SERVO1 | SERVO2);
    	startStopwatch2();
    	while(true)
    		if (getStopwatch2() > 48) {
    			servo1_position = pos;
    			servo2_position = pos;
    			setCursorPosLCD(0, 0);
    			writeStringLCD_P("Servopos.: ");
    			writeIntegerLCD(pos, DEC);
    			writeStringLCD_P("   ");
    			pos++;
    			if (pos > RIGHT_TOUCH) {pos = 0;}
    			setStopwatch2(0);
    		task_SERVO();
    		mSleep(3);
    	return 0;
    Header-Datei (RP6ControlServoLib.h):
     *                           _______________________
     *                           \| RP6  ROBOT SYSTEM |/
     *                            \_-_-_-_-_-_-_-_-_-_/             >>> RP6 CONTROL
     * ------------------------ [c]2008 - Dirk ------------------------------------
     * File: RP6ControlServoLib.h
     * Version: 1.0
     * Target: RP6 CONTROL - ATMEGA32 @16.00MHz
     * Author(s): Dirk
     * Description:
     * This is the RP6ControlServoLib header file.
     * You have to include this file, if you want to use the library
     * RP6ControlServoLib.c in your own projects.
     * THE CHANGELOG CAN BE FOUND AT THE END OF THIS FILE!
    // Includes:
    #include "RP6ControlLib.h" 		// The RP6 Control Library.
    								// Always needs to be included!
    // Defines:
    // Servo constants:
    #define SERVO1				0b00000001
    #define SERVO2				0b00000010
    #define SERVO3				0b00000100
    #define SERVO4				0b00001000
    #define SERVO5				0b00010000
    #define SERVO6				0b00100000
    #define SERVO7				0b01000000
    #define SERVO8				0b10000000
    // Servo movement limits (depending on servo type):
    // Standard Servos need an impulse every 20ms (50Hz). This impulse must have
    // a length of 1ms (0.7 .. 1ms) to move the servo lever to the left touch
    // and a length of 2ms (2 .. 2.3ms) for moving it to the right touch. In the
    // middle position the servo needs an impulse length of 1.5ms (1.3 .. 1.6ms).
    // If you want to modify the following constants for a certain servo type,
    // you must adapt the LEFT_TOUCH constant first (values ~70 .. 100 = ~0.7 ..
    // 1ms at 100kHz) by using a servo position value (servoX_position) of zero.
    // After that you have two "screws" to adjust the servo movement limits:
    // First you may change the RIGHT_TOUCH constant. If you choose a higher
    // value than 255, you will use 16-bit values. Higher values mean a longer
    // impulse length, but longer impulses than 2.3ms do not make sense.
    // Second you may alter the Timer 1 frequency constant (F_TIMER1).
    // A higher frequency leads to smaller steps of the servo movement. This of
    // course reduces the impulse length and may be compensated again by a higher
    // RIGHT_TOUCH constant. As a possible range of Timer 1 frequency values you
    // may use 50kHz (20us) .. 105.263kHz (9.5us).
    // HINT: If you alter F_TIMER1, you'll have to adapt LEFT_TOUCH and
    //       RIGHT_TOUCH again as you can see in the following table!
    //     Steps ->		9.5		10		12.5	15		17.5	20    [us]
    //  LEFT_TOUCH		74		71		57		47		41		35
    //  RIGHT_TOUCH		169		162		129		107		92		80
    //  F_TIMER1		105263	100000	80000	66667	57143	50000 [Hz]
    #define LEFT_TOUCH			71			// Left servo touch      (~0.7ms)
    #define RIGHT_TOUCH			162			// Right servo touch     (~2.3ms)
    #define MIDDLE_POSITION		(RIGHT_TOUCH / 2) // Middle position (~1.5ms)
    #define PULSE_REPETITION	17			// Pulse repetition freq. (~50Hz)
    #define F_TIMER1			100000		// Timer 1 frequency     (100kHz)
    // Servo ports:
    #define SERVO1_PULSE_ON		(PORTC |= IO_PC2)	// PC2
    #define SERVO1_PULSE_OFF	(PORTC &= ~IO_PC2)
    #define SERVO2_PULSE_ON		(PORTC |= IO_PC3)	// PC3
    #define SERVO2_PULSE_OFF	(PORTC &= ~IO_PC3)
    #define SERVO3_PULSE_ON		(PORTC |= IO_PC4)	// PC4
    #define SERVO3_PULSE_OFF	(PORTC &= ~IO_PC4)
    #define SERVO4_PULSE_ON		(PORTC |= IO_PC5)	// PC5
    #define SERVO4_PULSE_OFF	(PORTC &= ~IO_PC5)
    #define SERVO5_PULSE_ON		(PORTC |= IO_PC6)	// PC6
    #define SERVO5_PULSE_OFF	(PORTC &= ~IO_PC6)
    #define SERVO6_PULSE_ON		(PORTC |= IO_PC7)	// PC7
    #define SERVO6_PULSE_OFF	(PORTC &= ~IO_PC7)
    #define SERVO7_PULSE_ON		(PORTD |= IO_PD5)	// PD5
    #define SERVO7_PULSE_OFF	(PORTD &= ~IO_PD5)
    #define SERVO8_PULSE_ON		(PORTD |= IO_PD6)	// PD6
    #define SERVO8_PULSE_OFF	(PORTD &= ~IO_PD6)
    // Other possible ports for connecting Servos to RP6Control:
    //#define SERVOx_PULSE_ON		(PORTA |= ADC6)		// PA6
    //#define SERVOx_PULSE_OFF	(PORTA &= ~ADC6)
    //#define SERVOx_PULSE_ON		(PORTA |= ADC7)		// PA7
    //#define SERVOx_PULSE_OFF	(PORTA &= ~ADC7)
    // Variables:
    uint16_t servo1_position;		// Servo 1 position [0..RIGHT_TOUCH]
    uint16_t servo2_position;		// Servo 2 position [0..RIGHT_TOUCH]
    uint16_t servo3_position;		// Servo 3 position [0..RIGHT_TOUCH]
    uint16_t servo4_position;		// Servo 4 position [0..RIGHT_TOUCH]
    uint16_t servo5_position;		// Servo 5 position [0..RIGHT_TOUCH]
    uint16_t servo6_position;		// Servo 6 position [0..RIGHT_TOUCH]
    uint16_t servo7_position;		// Servo 7 position [0..RIGHT_TOUCH]
    uint16_t servo8_position;		// Servo 8 position [0..RIGHT_TOUCH]
    // Functions:
    void initSERVO(uint8_t servos);
    void startSERVO(void);
    void stopSERVO(void);
    void pulseSERVO(void);
    void task_SERVO(void);
     * Additional info
     * Changelog:
     * - v. 1.0 (initial release) 31.12.2008 by Dirk
    // EOF
    Bibliothek (RP6ControlServoLib.c):
     * File: RP6ControlServoLib.c
     * Version: 1.0
     * Author(s): Dirk
     * Description:
     * This is my simple RP6 Control Servo Library for up to 8 Servos.
     * COMMENT: It is a good idea to use a separate power supply for the servos!
     * Servo connections:
     *         SERVO1 -> I/O Pin 7 (IO_PC2)		SERVO5 -> I/O Pin 4 (IO_PC6)
     *         SERVO2 -> I/O Pin 5 (IO_PC3)		SERVO6 -> I/O Pin 1 (IO_PC7)
     *         SERVO3 -> I/O Pin 6 (IO_PC4)		SERVO7 -> I/O Pin 9 (IO_PD5)
     *         SERVO4 -> I/O Pin 3 (IO_PC5)		SERVO8 -> I/O Pin 8 (IO_PD6)
     * ATTENTION: Stopwatch 1 is used for the servo task! Please do
     *            not use this stopwatch elsewhere in your program!
    // Includes:
    // Variables:
    uint8_t usedservos;
    uint8_t servo_on = FALSE;
    uint16_t impulselength1 = 0;
    uint16_t impulselength2 = 0;
    uint16_t impulselength3 = 0;
    uint16_t impulselength4 = 0;
    uint16_t impulselength5 = 0;
    uint16_t impulselength6 = 0;
    uint16_t impulselength7 = 0;
    uint16_t impulselength8 = 0;
    volatile uint16_t intcounter = 0;
    // Functions:
     * INIT SERVO
     * Call this once before using the servo function.
     * Timer 1 is configured to work in "Clear Timer On
     * Compare Match Mode" (CTC). So no PWM is generated!
     * The timer runs on a fixed frequency (100kHz).
     * Input:  Servos -> Used Servos
     *         Examples:
     *         - initSERVO(SERVO1 | SERVO2) -> Use only Servos 1 and 2
     *         - initSERVO(SERVO1 | SERVO6) -> Use only Servos 1 and 6
     *         - initSERVO(SERVO1 | SERVO2 | SERVO8) -> Use Servos 1, 2 and 8
    	usedservos = servos;				// Save used Servos
    	impulselength1 = 0;
    	impulselength2 = 0;
    	impulselength3 = 0;
    	impulselength4 = 0;
    	impulselength5 = 0;
    	impulselength6 = 0;
    	impulselength7 = 0;
    	impulselength8 = 0;
    	if (servos & SERVO1) {DDRC |= IO_PC2; PORTC &= ~IO_PC2;}
    	if (servos & SERVO2) {DDRC |= IO_PC3; PORTC &= ~IO_PC3;}
    	if (servos & SERVO3) {DDRC |= IO_PC4; PORTC &= ~IO_PC4;}
    	if (servos & SERVO4) {DDRC |= IO_PC5; PORTC &= ~IO_PC5;}
    	if (servos & SERVO5) {DDRC |= IO_PC6; PORTC &= ~IO_PC6;}
    	if (servos & SERVO6) {DDRC |= IO_PC7; PORTC &= ~IO_PC7;}
    	if (servos & SERVO7) {DDRD |= IO_PD5; PORTD &= ~IO_PD5;}
    	if (servos & SERVO8) {DDRD |= IO_PD6; PORTD &= ~IO_PD6;}
    //	if (servos & SERVOx) {DDRA |= ADC6; PORTA &= ~ADC6;}
    //	if (servos & SERVOx) {DDRA |= ADC7; PORTA &= ~ADC7;}
    	cli();
    	// Timer 1: Normal port operation, mode 4 (CTC), clk/8
    	TCCR1A =  (0 << COM1A1)
    			| (0 << COM1A0)
    			| (0 << COM1B1)
    			| (0 << COM1B0)
    			| (0 << FOC1A)
    			| (0 << FOC1B)
    			| (0 << WGM11)
    			| (0 << WGM10);
    	TCCR1B =  (0 << ICNC1)
    			| (0 << ICES1)
    			| (0 << WGM13)
    			| (1 << WGM12)
    			| (0 << CS12)
    			| (1 << CS11)
    			| (0 << CS10);
    	OCR1A = ((F_CPU/8/F_TIMER1)-1);	// 19 at 100kHz
    // Possible OCR1A values (F_CPU = 16000000):
    //	OCR1A = 2000000 / F_TIMER1 - 1	// F_TIMER1  (Steps)
    //	OCR1A = 18;						// 105263Hz  (9.5us)
    //	OCR1A = 19;						// 100000Hz   (10us)
    //	OCR1A = 24;						//  80000Hz (12.5us)
    //	OCR1A = 29;						//  66667Hz   (15us)
    //	OCR1A = 34;						//  57143Hz (17.5us)
    //	OCR1A = 39;						//  50000Hz   (20us)
    	// Enable output compare A match interrupts:
    	startSERVO();
    	sei();
    	startStopwatch1();					// Needed for 20ms pulse repetition
     * START SERVO
     * If the servo function was stopped with the
     * function stopSERVO() before, it can be
     * started again with this function.
    	TIMSK |= (1 << OCIE1A);
    	servo_on = TRUE;
     * STOP SERVO
     * The servo function uses a certain amount of the
     * processor's calculating time. If the Servos are
     * not moving for a while, the Timer 1 interrupt
     * can be stopped with this function.
    	TIMSK &= ~(1 << OCIE1A);
    	servo_on = FALSE;
     * PULSE SERVO
     * This is the servo pulse generation. This function
     * must be called every 20ms (pulse repetition).
     * position = 0               : Left touch
     * position = RIGHT_TOUCH     : Right touch
     * position = MIDDLE_POSITION : Middle position
     * ! Please make sure in your main program, that the !
     * ! servo position values (servoX_position) don't   !
     * ! exceed RIGHT_TOUCH!!!                           !
     * COMMENT: The pulses are only started here!
     *          The pulses end in the Timer 1 ISR!
    	if (servo_on) {
    		intcounter = RIGHT_TOUCH;		// Avoid interference of Timer 1 ISR!
    								// (Only necessary, if pulseSERVO() is called
    								//  from outside of this library!)
    		if (usedservos & SERVO1) {
    			SERVO1_PULSE_ON; impulselength1 = LEFT_TOUCH + servo1_position;}
    		if (usedservos & SERVO2) {
    			SERVO2_PULSE_ON; impulselength2 = LEFT_TOUCH + servo2_position;}
    		if (usedservos & SERVO3) {
    			SERVO3_PULSE_ON; impulselength3 = LEFT_TOUCH + servo3_position;}
    		if (usedservos & SERVO4) {
    			SERVO4_PULSE_ON; impulselength4 = LEFT_TOUCH + servo4_position;}
    		if (usedservos & SERVO5) {
    			SERVO5_PULSE_ON; impulselength5 = LEFT_TOUCH + servo5_position;}
    		if (usedservos & SERVO6) {
    			SERVO6_PULSE_ON; impulselength6 = LEFT_TOUCH + servo6_position;}
    		if (usedservos & SERVO7) {
    			SERVO7_PULSE_ON; impulselength7 = LEFT_TOUCH + servo7_position;}
    		if (usedservos & SERVO8) {
    			SERVO8_PULSE_ON; impulselength8 = LEFT_TOUCH + servo8_position;}
    		intcounter = 0;
     * TIMER1 ISR
     * In this ISR the servo pulses are finished, if the
     * correct pulse length of each servo is reached.
    ISR (TIMER1_COMPA_vect)
    	intcounter++;
    	if (intcounter == impulselength1) {SERVO1_PULSE_OFF;}
    	if (intcounter == impulselength2) {SERVO2_PULSE_OFF;}
    	if (intcounter == impulselength3) {SERVO3_PULSE_OFF;}
    	if (intcounter == impulselength4) {SERVO4_PULSE_OFF;}
    	if (intcounter == impulselength5) {SERVO5_PULSE_OFF;}
    	if (intcounter == impulselength6) {SERVO6_PULSE_OFF;}
    	if (intcounter == impulselength7) {SERVO7_PULSE_OFF;}
    	if (intcounter == impulselength8) {SERVO8_PULSE_OFF;}
     * SERVO TASK
     * This is the servo task. The task performes the pulse repetition
     * with the help of a stopwatch.
     * At the next call of the servo task (earliest about 3ms after the
     * last servo pulse generation) the compare A match interrupt will
     * be disabled to reduce the interrupt load. It will be enabled
     * again after the next pulseSERVO() function call.
    	if (getStopwatch1() > 2) {TIMSK &= ~(1 << OCIE1A);}
    	if (getStopwatch1() > PULSE_REPETITION) { // Pulse every ~20ms
    		pulseSERVO();					// Servo pulse generation
    		if (servo_on) {TIMSK |= (1 << OCIE1A);}
    		setStopwatch1(0);
     * Additional info
     * Changelog:
    // EOF
    Euch allen einen guten Rutsch! Und denkt dran: um 0.00 Uhr nicht zu früh die Korken knallen lassen! Da wird an 2008 noch eine Schaltsekunde angehängt! Das ist eine gute Chance, eigene DCF-Decoder wie z.B. diesen hier für den RP6:
    https://www.roboternetz.de/phpBB2/viewtopic.php?t=34240
    ... 'mal auf ihre Schaltsekunden-Tauglichkeit zu überprüfen. Man kann ja danach auch noch böllern!
    Dirk
    Cool Danke
    aber ihrgent wie sagt mein Notepad das in deiner Domo 2 Fehler sind einmal hier: initSERVO(SERVO1 | SERVO2); und task_SERVO(); liegt das an mir??
    kannst du das ganze mal als zip hochladen?
    lg
    Allgäu
    hallo, ich weiß der thread ist schon etwas älter. aber da die servo ansteuerung von dirk sicherlich die grundlage von vielen unerfahreren c programmierung ist, möchte ich kurz auf Christian3 geschildertes problem beheben.
    wenn man den von dirk geposteten quellcode unverändert nimmt, kommt ja die von Christian3 geschilderte ferhlermeldung.
    darum muss man meiner meinung nach im demoprogramm noch oben #include "RP6ControlServoLib.c" einfügen, damit das programm fehlerfrei kompiliert werden kann.
    NRW
    Hallo proevofreak,
    das ist es nicht.
    Fehlermeldungen bei initSERVO(SERVO1 | SERVO2) und task_SERVO() in der Demo kommen, wenn man im makefile nicht dieses hier eingetragen hat:
    SRC += $(RP6_LIB_PATH)/RP6control/RP6ControlServoLib.c
    Gruß Dirk
    Allgäu
    danke, wieder was gelernt.
    Allgäu
    so, nach fast schon stundenlangem durchforsten und durchdenken von dirks servo_libs für die M32 und dem dazugehörigem demoprogramm werfen sich bei mir einige fragen auf:
    intcounter = 0;
       intcounter++;
    was hat es mit dem intcounter auf sich?
    wenn ich die Lib richtig verstehe wird intcounter jedes mal im pulse_Servo der wert von RIGHT_TOUCH (also 162) zugewiesen und danach am ende von pulse_Servo bzw. sofort danach der wert 0.
    wozu wird das gemacht?
       intcounter++;
    was geschieht genau hier?
    wie ich es verstehe, wird im pulse_servo der ausgewählte servoport auf high geschaltet und gleichzeitig wird die impulselength aus der Summe LEFT_TOUCH (71) und servox_position; berechnet.
    der wert von servo1_position ändert sich ja in dirks demoprogramm ständig, somit ja auch die impulselength1.
    wenn ich dirks demoprogramm richtig verstehe, geht der wert von servo1_position stehts von [0...163].
    somit der wert von impulselength1 von [71....234]
    Richtig?
    bei der ISR habe ich berechnet, dass sie alle 0,19ms ausgelöst wird.
    Richtig?
    Das würde bedeuten, dass im Abstand von zwei pulse_servo- aufrufen die ISR ca. 100 mal ausgeführt wird.
    beginnt der intcounter++, jetzt wenn wir mal das demoprogramm zugrunde legen und nur servo1 betrachten, in der ISR bei 0 aufwärts zu zählen oder beim wert von RIGHT_TOUCH?
    bei welchem wert ist intcounter==impulselength1 und somit SERVO1_PULSE_OFF?
    wie lange in ms ist dann der high impulse für servo1 in diesem demoprogramm.
    die restlichen teile der Lib bzw. des programms hab ich im großen und ganzen verstanden.
    ich weiß das sind jetzt eine menge fragen, nur bin ich noch nicht so C und vor allem Servo erfahren und denke, dass dirks servolib sehr gut zum ansteuern meiner 5 Servos an meinem roboterarm eignet.
    drum will ich alles genau wissen.
    danke schon mal im voraus für eure mühen.
    mfg andi
    NRW
    Hallo andi,
    ne Menge Fragen, puh ...
    1. Intcounter:
    In pulseSERVO() wird ja der Impuls für jedes Servo gestartet und am Ende der Funktion intcounter = 0 gesetzt.
    Damit läuft jetzt die Zeit für die Timer1-ISR: Wenn die Impulslänge der Servos erreicht ist, wird der Impuls für das jeweilige Servo in der ISR beendet.
    "intcounter = RIGHT_TOUCH;" in pulseSERVO() kann man eigentlich weglassen, wenn man pulseSERVO() nur aus dieser Lib heraus aufruft. Denkbar wäre aber, dass jemand die Impulswiederholung alle 20ms nicht mit der task_SERVO() machen will, sondern eine eigene Funktion dafür schreibt. Dann kann ich nicht garantieren, dass es nicht passiert, dass die Timer1-ISR in die Funktion pulseSERVO() "einbricht" und unkontrolliert Servoimpulse beendet, obwohl die ja gerade gestartet werden sollen. Das verhindere ich mit "intcounter = RIGHT_TOUCH;", weil damit intcounter größer als impulselengthX ist, und die ISR somit nie einen Impuls beenden kann, solange pulseSERVO() läuft.
    Aber wie gesagt: "intcounter = RIGHT_TOUCH;" kann man ersatzlos streichen, wenn man die Impulswiederholung nur mit task_SERVO() machen will (es schadet aber auch nicht, wenn man es drin läßt).
    2. ImpulselengthX:
    Ja, genau. Die Impulslänge ist immer LEFT_TOUCH + servoX_position.
    Das mache ich immer so, damit ich alle meine Servos von 0 (Null am linken Anschlag) bis zu einem Maximalwert (rechter Anschlag = RIGHT_TOUCH) mit servoX_position ansteuern kann.
    Vorteil: Man kann einfach beide Anschläge in der Lib einstellen, ohne dass das Hauptprogramm sich darum kümmern muss. Einfacher wäre, eine Ansteuerung von 71..234 zu erlauben und auf den Offset von LEFT_TOUCH zu verzichten. Geht natürlich auch ...
    3. Timer1-ISR Frequenz:
    In der Demo wird sie mit 100kHz aufgerufen. Das ist fast schon das Maximum, das mit der M32 erreichbar ist. Das heißt, alle 10us läuft die ISR ab und zählt intcounter hoch. Der wird am Ende von pulseSERVO() auf Null gesetzt, damit beginnt der Impuls. Wird die max. Impulslänge (impulselengthX) in der ISR erreicht, wird der Impuls beendet. Bei einer ISR-Frequenz von 100kHz (= 10us) braucht man einen intcounter von 70..230 für eine Impulsdauer von 0,7..2,3ms, also für den vollen Ansteuerungsbereich.
    Rechnung: 70 x 10us = 0,7ms und 230 x 10us = 2,3ms.
    ... so, jetzt brauche ich 'nen Kaffee.
    Gruß Dirk
    Allgäu
    puh, so viele antworten
    ne im ernst, vielen dank dirk für so ne ausführliche und gut erklärte antwort.
    ich glaube jetzt hast du mir wirklich mächtig weitergeholfen. soweit weg war ich ja dann bisher gar nicht mit meinem verständnis, nur jetzt sind mir die zusammenhänge noch wesentlich klarer geworden.
    mal schauen ob ich diese woche neben dem studium mal zum programmieren komme. ich meld mich auf jeden fall wieder, sobald ich deine lib in der praxis angewendet habe.
    Allgäu
    so dirk, jetzt bin ich bei der programmierung meines 5-achs-armes, wo deine lib ja die hauptrolle spielt angekommen.
    allerdings stehe ich vor einem ersten problem. kann es sein, dass die servoansteuerung mit deiner lib nicht korrekt funktioniert, wenn man mehrere Servos gleichzeitig ansteuert?
    hier mein programm:
    //Servo 1 => PC2
    //Servo 2 => PC3
    //Servo 3=> PC4
    //Servo 4=> PC5
    //Servo 5=> PC6
    //Reflexkoppler => PD6
    uint8_t a;
    void task_teil_erkannt(void)
    {if (PIND & (1<<6))
    	{setStopwatch3(0);
    	a=1;
    	writeString_P("kein Teil erkannt\n");}
    else {a=0;
    	writeString_P("Teil erkannt\n");
    	initSERVO(SERVO1);
    	startStopwatch3();
    void task_servoansteuerung(void)
    {if (a==0 && getStopwatch3() >0)
    	servo1_position = 0;
    	writeString_P("Greifer zu\n");
    if (a==0 && getStopwatch3() > 2000 )
    	{initSERVO(SERVO3|SERVO4);
    	servo3_position = MIDDLE_POSITION;
    	servo4_position = 50;
    	writeString_P("Arm hoch\n");}
    int main(void)
       initRP6Control();
       DDRD &=~ (1<<6);		//Eingang für Reflexkoppler
       startStopwatch2();
       while(true)
       {task_servoansteuerung();
        task_teil_erkannt();
          task_SERVO();
          mSleep(3);
       return 0;
    wenn ein teil erkannt wird, wird der greifer geschlossen (bis dahin funktioniert das programm), allerdings sollten dann nach 2sekunden verzögerung die Servos 3 und 4 den arm nach oben fahren lassen. das geschieht leider nie, obwohl im terminal "Arm hoch" angezeigt wird. der greifer soll die ganze zeit über an seinen linken anschlag takten (das funktioniert auch schon).
    kannst du mir vielleicht sagen, an was das genau liegt?
    mfg andi
    NRW
    Hallo andi,
    so ganz verstehe ich dein Prog nicht.
    Rein formal:
    1. Mit initSERVO() must du ALLE Servos, die du angeschlossen hast, in der Main (also VOR der while(1)-Schleife!) EINMAL definieren. Wenn du also Servos an 1, 3 und 4 hast, dann steht da:
    initSERVO(SERVO1 | SERVO3 | SERVO4);
    In einer Funktion (und bes. in einer Schleife) hat initSERVO nichts zu suchen.
    2. Wenn sich der Arm bewegen soll, müßtest du die Servopositionen für eine bestimmte Bewegung z.B. in einer Funktion (Armrunter, Armhoch, Handauf ...) zusammen fassen. Das sind dann mehrere Positionen pro Bewegung, zwischen denen je eine Pause liegt.
    Gruß Dirk
