Ergebnis 1 bis 9 von 9
Thema: Frage an die Java-Profis
    Erfahrener Benutzer Roboter Genie Avatar von pinsel120866
    Hohenems
    Frage an die Java-Profis, ich habe folgenden Java Code:
    * @(#)Wifibot.java
    * Sample Applet application
    * @author
    * @version 1.00 07/10/15
    import java.awt.*;
    import java.applet.*;
    import java.awt.event.*;
    import java.awt.Graphics;
    import java.awt.Image;
    import java.awt.image.BufferedImage;
    import java.awt.Graphics2D;
    public class Wifibot extends Applet {
    	Button Up_Button ;
    	Button Down_Button ;
    	Button Left_Button ;
    	Button Right_Button ;
    	Button Grab_Button;
    	int Port_Id = 10001;
    	TcpIP  gtp=null;
    BufferedImage Graphic_buffer=new BufferedImage(88,120,BufferedImage.TYPE_INT_ARGB);
    int[] Tmp_graphic_Buffer=new int[88*120];
    int x_pad=20;
    int y_pad=140;
    public void init()
    	setLayout(null);
    	gtp= new TcpIP(Port_Id,this);
    	//set the up left right down buttons
    	Up_Button = new Button("Up");
    	Up_Button.setBounds(x_pad+50,y_pad,40,40); // param int
    	Up_Button.addActionListener( new ActionListener()
    	public void actionPerformed( ActionEvent e )
    			gtp.send("UP0");
    			System.out.println("");
    	add(Up_Button);
    	Left_Button = new Button("Left");
    	Left_Button.setBounds(x_pad,y_pad+50,40,40);
    	Left_Button.addActionListener( new ActionListener()
    			gtp.send("LE0");
    	add(Left_Button);
    	Right_Button = new Button("Right");
    	Right_Button.setBounds(x_pad+100,y_pad+50,40,40); // param int
    	Right_Button.addActionListener( new ActionListener()
    			gtp.send("RI0");
    	add(Right_Button);
    	Down_Button = new Button("Down");
    	Down_Button.setBounds(x_pad+50,y_pad+100,40,40);  // param int
    	Down_Button.addActionListener( new ActionListener()
    			gtp.send("DO0");
    			byte[] in=null;
    			in=gtp.receive();
    			System.out.println("lenght ->"+in.length);
    			for(int i=0;i<in.length;i++)
    				System.out.println("lenght ->"+in[i]+'A');
    add(Down_Button);
    Grab_Button = new Button("Grab");
    Grab_Button.setBounds(x_pad+180,y_pad+50,40,40); // param int
    Grab_Button.addActionListener( new ActionListener()
    		gtp.send("RGB");	  //send order to grab picture
    			int tmp=0;
    			gtp.send("RED");
    			byte[] in=null;
    			if (gtp.available()>0) in=gtp.receive();  //flush the input buffer
    			for (int k=0,j=0,i=0; k<120*88;)
    				in=gtp.receive();
    				for(j =0 ;j<in.length;j++)
    					tmp=(int)in[j];
    					if(tmp<0) tmp=256+tmp;
    Tmp_graphic_Buffer[k++]=0xFF000000|tmp<<16|tmp<<8|tmp;
    					gtp.send("e");
    				repaint();
    	add(Grab_Button);
    	for (int i=0; i<120*88;i++)
    		Tmp_graphic_Buffer[i]=0xff808080;
    public void paint(Graphics g)
    	Graphic_buffer.setRGB(0,0,88,120,Tmp_graphic_Buffer,0,88);
    	g.drawImage(Graphic_buffer,x_pad+24,y_pad-130,null);
    Wenn ich kompilieren will kommt:
    Datei.java:42: cannot find symbol
    symbol: class TcpIP
    Die Datei TcpIP.class liegt im gleichen Verzeichnis.
    Was fehlt hier?
    12°29´ O, 48°38´ N
    zu welchem package gehört diese TcpIP-Klasse, hast Du davon die .java, dann brauchts normalerweise noch ein import des ganzen.
    Hohenems
    ja, im gleichen Verzeichnis gibt es eine tcpip.java. Wie sieht dieser Import aus?
    12°29´ O, 48°38´ N
    Kannst Du die auch hier reinstellen,
    mind. den Anfang bis zur class-Zeile ?!
    Interessant wäre obs da 'ne package-Zeile gibt.
    Was nimmst Du zum proggen, welche IDE ?
    Hohenems
    Installiert habe ich Java SDK 6.13
    import java.*;
    import java.lang.*;
    import java.net.*;
    import java.util.*;
    import java.io.*;
    public class TcpIP
    protected Socket s = null;
    public DataInputStream dis = null;
    protected DataOutputStream dos = null;
    InetAddress reader_ip = null;
    public TcpIP(int port ,Applet a)
    	try
    		reader_ip = InetAddress.getByName(a.getCodeBase().getHost());
    	catch (UnknownHostException e){}
    	if (reader_ip != null)  Connect(reader_ip, port);
    public void Connect(InetAddress ipa, int port)
    	Socket s1 = null;
    try 	{					// Open the socket
    	s1 = new Socket(ipa.getHostAddress(), port);
    catch  (IOException e) {
    	System.out.println("Error opening socket");
    	return;
    s =  s1;
    try 	{				        //  Create an input stream
    	dis =  new  DataInputStream (new  BufferedInputStream (s.getInputStream ()));
    catch(Exception ex) {
    	System.out.println("Error creating input stream");
    try	  {				        // Create an output stream
    	dos = new  DataOutputStream (new BufferedOutputStream (s.getOutputStream ()));
    	System.out.println("Error creating output stream");
    public synchronized void disconnect()
    	if (s != null) {
    	try {
    		s.close();
    	catch (IOException e){}
    public synchronized void send(byte[] temp)
    	try {
    		dos.write(temp, 0, temp.length);
    	dos.flush();
    		System.out.println("Error sending data : " + ex.toString());
    public synchronized void send(byte[] temp, int len)
    	try {
    		dos.write(temp, 0, len);
    		dos.flush();
    public synchronized void send(String given)
    		//  W ARNING : this routine may not properly convert Strings to bytes
    	int length = given.length();
    	byte[] retvalue = new byte[length];
    	char[] c = new char[length];
    	given.getChars(0, length, c, 0);
    	for (int i = 0; i < length; i++) {
    		retvalue[i] =  (byte)c[i];
    	send(retvalue);
    public synchronized  byte[] receive()
    	byte[] retval = new byte[0];
    	try {
    		while(dis.available() == 0);  /* Wait for data */
    	try {
    		retval = new byte[dis.available()];
    	} catch (IOException e){}
    	try {
    		dis.read(retval);
    	return(retval);
    public int available()
    	int avail;
    	avail = 0;
    	try {
    		avail = dis.available();
    	} catch (IOException e) {}
    	return(avail);
    12°29´ O, 48°38´ N
    Bei mir kann ich beide Dateien, so wie sie sind, ohne Fehler übersetzen, obs dann auch läuft weiss ich ned.
    schaut dann Dateimässig so aus:
    04.04.2009  17:50                2.775 TcpIP.class
    04.04.2009  17:49                2.707 TcpIP.java
    04.04.2009  17:50                  667 Wifibot$1.class
    04.04.2009  17:50                  667 Wifibot$2.class
    04.04.2009  17:50                  667 Wifibot$3.class
    04.04.2009  17:50                1.026 Wifibot$4.class
    04.04.2009  17:50                  877 Wifibot$5.class
    04.04.2009  17:50                2.033 Wifibot.class
    04.04.2009  17:49                3.398 Wifibot.java
                   9 Datei(en)         14.817 Bytes
    passen die Dateinamen bei Dir auch mit der Klasse überein ?
    Hohenems
    Sei bitte so gut und stelle mir deine übersetzen Datein gezippt hier rein.
    12°29´ O, 48°38´ N
    Wie gewünscht :
    Hohenems
    Vielen Dank!
    Ich habe die Codes aus einer Anleitung übernommen und wollte sie nur kompilieren.
