- 3D-Druck Einstieg und Tipps    Werbung
Ergebnis 11 bis 15 von 15
Thema: Arduino Duemillenova mit Eclipse Programmieren
    Leverkusen
    Hallo Markus,
    habe hier mal den Code gepostet. Vielleicht hilft es.
    #include <WProgram.h>
      const int RMotor1  = 2;    // H-bridge leg 3       Input 1        14,4V Motor
      const int RMotor2  = 4;    // H-bridge leg 2       Input 2
      const int RSpeed = 3;      // H-bridge leg 7       Enable A (PWM)
      const int LMotor1 = 7;     // H-bridge leg 13      Input 3        12V Motor
      const int LMotor2 = 8;     // H-bridge leg 14      Input 4
      const int LSpeed = 6;      // H-bridge leg 10      Enable B (PWM)
      const int ledBlue = 12;    // BlueLED  left Motor
      const int ledRed = 13;     // RedLED  right Motor
      int PinOdoR = 1;           // right Pin for IR-Sensor
      int PinOdoL = 0;           // left Pin for IR-Sensor
      // int RSpeed = 120;        // is not needed in this Kontex
      // int LSpeed = 120;
      // int mDirR = 0;
      // int mDirL = 0;
      // int LedPwmR = 0;
      // int LedPwmB = 0;
      int readAnalog(int port);  // Why are these functions initialized here?
      int readOdoR();
      int readOdoL();
      void blink(int whatPin, int howManyTimes, int milliSecs);
      // void motorR (int InputPin2, int InputPin4, int pwm3);
      // void motorL (int InputPin7, int InputPin8, int pwm6);
      void motorStop();
      //-------------------------- Setup ----------------------------------------------------
       void setup() {
          void motorStop();
          pinMode(RMotor1, OUTPUT);
          pinMode(RMotor2, OUTPUT);
          pinMode(RSpeed, OUTPUT);
          pinMode(LMotor1, OUTPUT);
          pinMode(LMotor2, OUTPUT);
          pinMode(LSpeed, OUTPUT);
          pinMode(ledBlue, OUTPUT);
          pinMode(ledRed, OUTPUT);
          Serial.begin(115200);
          // motorStop();        // would be necessary at all?
          Serial.println("***********************");
          Serial.println("* Encoder-Test        *");
          Serial.print("* ");Serial.print(__DATE__);Serial.print(" ");Serial.print(__TIME__);Serial.println("*");
        blink(ledBlue, 3, 1000);
       void loop() {
    		int RSpeed = 120;
              int LSpeed = 120;
              motorR(HIGH,LOW,RSpeed);
              motorL(HIGH,LOW,LSpeed);
              delay(2000);
              Serial.println(" Encoder Rechts/Links ");
              for (int i = 0; i <= 52; i++)
                int valR = readOdoR();
                int valL = readOdoL();
                Serial.print(" ");Serial.print(valR,DEC);Serial.print("  ;");Serial.print(valL,DEC);Serial.println(" ");
                delay (10);                                      // hängt dieser Wert von der Drehzahl des Encoders ab?
                 if (valR > 400)  { digitalWrite(ledRed,HIGH); }
                    else { digitalWrite(ledRed,LOW); }
                 if (valL > 400)  { digitalWrite(ledBlue,HIGH); }
                    else { digitalWrite(ledBlue,LOW); }
      	// motorStop();
      	delay (5000);
      // -------------------------- Left Motor -----------------------------------------------
      void motorR (int InputPin2, int InputPin4, int pwm3){
          digitalWrite(RMotor1, InputPin2);
          digitalWrite(RMotor2, InputPin4);
          analogWrite(RSpeed, pwm3);
    //-------------------------- Right Motor ----------------------------------------------
      void motorL (int InputPin7, int InputPin8, int pwm6){
          digitalWrite(LMotor1, InputPin7);
          digitalWrite(LMotor2, InputPin8);
          analogWrite(LSpeed, pwm6);
     //-------------------------- Stop Motor ----------------------------------------------
      void motorStop (){
          motorL(LOW, LOW, 0);
          motorR(LOW, LOW, 0);
    int readOdoR(){
    	return readAnalog (PinOdoR);
    int readOdoL(){
    	return readAnalog (PinOdoL);
    int readAnalog(int port){
    	int val = 0;
    	for (int i = 0; i <= 3; i++)
    	  { val = val + analogRead(port); }
    	    val = val/3;
    	return val;
    //--------------------------  blinks an LED ------------------------------------
      void blink(int whatPin, int howManyTimes, int milliSecs) {
        int i = 0;
        for ( i = 0; i < howManyTimes; i++) {
          digitalWrite(whatPin, HIGH);
          delay(milliSecs/2);
          digitalWrite(whatPin, LOW);
          delay(milliSecs/2);
    //------------------------- Programm Ende ---------------------------------------
    int main(void) {
      /* Must call init for arduino to work properly */
      init();
      setup();
      for (;;) {
    	  loop();
      } // end for
    } // end main
    Ist bestimmt ein typische Anfängercode, aber in der Arduino IDE funktioniert er.
    Willi
    Karlsruhe
    Hallo Willi,
    unwahrscheinlich dass der in der Arduino-IDE in genau dieser Form funktioniert - du hast die Deklaration von motorR() und motorL() auskommentiert, damit kennt der Compiler diese Funktionen in setup() noch nicht weil sie erst danach implementiert wurden.
    Grundregel: Alle verwendeten Funktionen müssen vor ihrer Verwendung deklariert worden sein.
    Dir bleiben also zwei Möglichkeiten:
    1. Du machst die Auskommentierung dieser Zeilen rückgängig und lieferst damit eine Deklaration:
    2. Du verschiebst motorL() und motorR() vor setup().
    mfG
    Markus
    Leverkusen
    Hallo Markus,
    Du hast natürlich Recht. Die Auskommentierungen waren durch die Versuche gekommen. Hier der org. Arduinocode.
      int PinOdoR = 0;           // right Pin for IR-Sensor
      int PinOdoL = 1;           // left Pin for IR-Sensor
      // int mSpeedR = 0;        // is not needed in this Kontex ?
      // int mSpeedL = 0;
      // int mDirR = 0;
      // int mDirL = 0;
      // int LedPwmR = 0;
      // int LedPwmB = 0;
      int readOdoR ();
      int readOdoL ();
    //-------------------------- Left Motor -----------------------------------------------
      void motorStop (){
     void setup() {
        // set all the other pins you're using as outputs:
        blink(ledRed, 3, 1000);
      void loop() {
            int RSpeed = 170;
            int LSpeed = 150;
            delay(1000);
            for (int i = 0; i <= 100; i++)
              delay (15);                                      // hängt dieser Wert von der Drehzahl des Encoders ab?
    	motorStop();
    	delay (5000);
    int readOdoR (){
    int readOdoL (){
    	int val = 0;
    	    val = val/3;
    	return val;
        int i = 0;
          delay(milliSecs/2);
          delay(milliSecs/2);
    Ich hoffe ich habe Deinen Tipp richtig verstanden.
     * File Name:   Encoder-Test
     * Project  :   Scheibenbot Kucky 1
     * Description: Freie Bewegungen im unbekannten Raum
     * Ver.     Date         Author               Comments
     * 0.1      12.08.2010   W. Kuckelsberg       initial build
     *  Co-Author and helpfull Hand: Stephan Scholz
     *  Hardware: Arduino Duemillenova
     *  H-bridge: L298H
     *  Self test for Encoderdisc
     *  Informations:
     *  right planetmotor rotates until ???
     *  left  planetmotor rotates until ???
      // int mDirR = 0;
      // int mDirL = 0;
      // int LedPwmR = 0;
      // int LedPwmB = 0;
      int readOdoR();
      int readOdoL();
      //void motorR (int InputPin2, int InputPin4, int pwm3);
      //void motorL (int InputPin7, int InputPin8, int pwm6);
      void motorL ();
      void motorR ();
      void motorStop();
       void setup() {
          void motorStop();
       void loop() {
    		int RSpeed = 120;
              int LSpeed = 120;
              delay(2000);
      	// motorStop();
      	delay (5000);
      void motorStop (){
    int readOdoR(){
    int readOdoL(){
    	int val = 0;
    	    val = val/3;
    	return val;
        int i = 0;
          delay(milliSecs/2);
          delay(milliSecs/2);
    int main(void) {
      init();
      setup();
      for (;;) {
    	  loop();
      } // end for
    } // end main
    Nun bekomme ich diese Meldung:
    "D:\UserDaten\Users\Willi\Prog\Projekte\ProjEclips e\ArduinoCore\Release\libArduinoCore.a(Print.o).data+0x6): undefined reference to `__cxa_pure_virtual'
    make: *** [Encoder.elf] Error 1"
    (der traurige Smilie entstand zwar automatisch, passt aber irgendwie)
    Die ArduinoCore ist im Verzeichniss "xxx/ArduionoCore/Release"
    Die Dateien mit der Endung *.h sind im Verzeichniss "xxx/ArduionoCore"
    Ist das richtig? Wurde automatisch beim erstellen der static Library so hinterlegt. Oder müssen die alle in einem Verzeichniss sein. Um das Problem zu umgehen, habe ich beide Verzeichnisse bei den Projekteinstellungen genannt.
    Wäre es für Dich sehr viel Aufwand, meine Code in Eclipse so umzuschreiben, dass ich hier schon mal keinen Fehler habe. =D>
    Ich weiss das ist ziemlich unverschämt, wäre Dir aber wirklich sehr dankbar.
    Willi
    Karlsruhe
    Ich habe keinen Arduino und kann daher nur allgemeine Hilfestellung zu AVR-Eclipse und C geben, und dieses Problem ist sehr C++-Spezifisch.
    Welche WinAVR-Version verwendest du? Der letzte Post in diesem Thread deutet darauf hin dass man ein aktuelles WinAVR braucht, hier wird eine Problemlösung beschrieben von der ich nicht beurteilen kann, wie gefährlich sie ist ...
    mfG
    Markus
    Edit: "keinen" Arduino statt "einen"
    Leverkusen
    Hallo Markus,
    das mit dem gefährlich sehe ich genauso. Aber ein Link hat mir gezeigt, wie ich Funktionen vor dem SetUp deklarieren muss. Also vielen Dank. Mühsam ernährt sich das Eichhörchen.
    Gruß Willi
    Werbung      12V Akku bauen
