Hallo, ich habe eben das Kabel bekommen und getestetoch leider gibt es Probleme : Hab es mit zwei verschiedenen Codes getestet:
Code 1:
$regfile = "m32def.dat"
$crystal = 16000000
$baud = 9600
$hwstack = 32
$swstack = 32
$framesize = 32
Config Portd.7 = Output                                     'Summer
Dim K As String * 100
Open "Comb.0: 38400 , 8 , n , 1" For Input As #1
Open "Comb.1: 38400 , 8 , n , 1" For Output As #2
Waitms 50
Sound Portd.7 , 400 , 450                                   'Summer summt : Alles OK
Sound Portd.7 , 400 , 250
Waitms 50
  Input #1 , K
  Print K
  Waitms 500
End
Code 2: einfach ohne Waitms 500.
Raus habe ich ( ich zeige nur den Anfang . Es geht dann immer so weiter,denke ich mal, habe es aber nicht getestet):
Code 1 : (Da habe ich das Modul zum ersten mal angeschaltet, so könnte ich mir das $GPTXT,01,01,02,ANTSTATUS=INIT*25 erklären,welches nur beim ersten mal erschiennen ist.)
$GPRMC,235945.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*78
$GPRMC,235946.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7C
$GPRMC,235947.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7A
$GPRMC,235948.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*77
$GPRMC,235949.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*71
$GPRMC,235949.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*73
$GPRMC,235950.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7C
$GPRMC,235951.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7F
$GPRMC,235952.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7B
$GPRMC,235952.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*79
$GPRMC,235953.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7F
$GPRMC,235954.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7A
$GPRMC,235955.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7C
$GPRMC,235955.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7E
$GPRMC,235956.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7A
$GPRMC,235957.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*79
$GPRMC,235958.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*71
$GPRMC,235958.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*73
$GPRMC,235959.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*75
$GPRMC,000000.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7E
$GPRMC,000001.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*78
$GPRMC,000001.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7A
$GPRMC,000002.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7E
$GPRMC,000003.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7D
$GPRMC,000004.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7D
$GPRMC,000004.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7F
$GPRMC,000005.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*79
$GPRMC,000006.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*78
$GPRMC,000007.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7E
$GPRMC,000007.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,060180,,,N*7C
Bei Code 2:
$GPRMC,235947.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7D
$GPRMC,235948.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*70
$GPRMC,235948.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*75
$GPRMC,235948.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*72
$GPRMC,235949.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*76
$GPRMC,235949.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*74
$GPRMC,235950.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*79
$GPRMC,235950.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7E
$GPRMC,235950.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7B
$GPRMC,235951.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*78
$GPRMC,235951.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7D
$GPRMC,235951.750,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7A
$GPRMC,235952.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7C
$GPRMC,235952.500,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7E
$GPRMC,235953.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7A
$GPRMC,235953.250,V,0000.0000,N,00000.0000,E,0.00, 0.00,120136,,,N*7D
So jetzt zu den Problemen :
1: Es wird kein Längen und Breitengrad angezeigt! Warum?? (ich habe den nur paar sec laufen lassen. Im Haus)
2: Laut Wikipedia ist das V nach $GPRMC,235953.500, ein Zeichen dafür, dass eine Warnung vorliegt. Was ist das für eine Warnung ???
3: Muss ich das Modul, bevor ich es verwenden möchte erst konfigurieren ?? Nein, oder??
4:Wo muss ich die Abschirmung anschließen ?? Ich habe sie an GND gehängt, aber weß nicht ob man das soll ??
Ich hoffe, ihr könnt mir helfen...
