- Labornetzteil AliExpress    Werbung
Ergebnis 11 bis 20 von 20
Thema: Raspberry Pi mit Vb.net
    Erfahrener Benutzer Fleißiges Mitglied Avatar von Mcgrizzly123
    Hi nochmal
    irgendwie funktioniert es trotzdem nicht so wie es soll. Also so hier mal der Code für Server auf dem Raspberry Pi:
    from socket import *
    import serial
    import sys
    import time
    ECHO_PORT = 55555
    BUFSIZE = 1024
    H = 1
    send = "0;0;00000/70 \n"
    liste = [""]
    m1 = ""
    m2 = ""
    r1 = ""
    r2 = ""
    r3 = ""
    r4 = ""
    rnotaus = ""
    akku1 = ""
    A = "A\r\n"
    zeilenumbruch = "\r\n"
    def main():
        s = socket(AF_INET, SOCK_STREAM)
        s.bind(('', ECHO_PORT))
        s.listen(1)
        serialport = serial.Serial("/dev/ttyUSB0", 9600)
        print "Server gestartet"
        conn, (remotehost, remoteport) = s.accept()
        print 'Verbunden mit %s:%s' % (remotehost, remoteport)
        while H == 1:
            data = conn.recv(BUFSIZE)
            liste = data.split(";")
            del liste[9]
            x = liste[0]
            y = liste[1]
            s1 = liste[2]
            s2 = liste[3]
            b1 = liste[4]
            b2 = liste[5]
            b3 = liste[6]
            b4 = liste[7]
            bnotaus = liste[8]
            serialport.write(A)
            serialport.write(x + "\r\n")
            serialport.write(y + "\r\n")
            serialport.write(s1 + "\r\n")
            serialport.write(s2 + "\r\n")
            serialport.write(b1 + "\r\n")
            serialport.write(b2 + "\r\n")
            serialport.write(b3 + "\r\n")
            serialport.write(b4 + "\r\n")
            serialport.write(bnotaus + "\r\n")
            print  "gosd" + x + y + s1 + s2 + b1 + b2 +b3 + b4 + bnotaus
            m1 = serialport.readline()
            m1l = m1.split("\r\n")
            m1s = m1l[0]
            m2 = serialport.readline()
            m2l = m2.split("\r\n")
            m2s = m2l[0]
            r1 = serialport.readline()
            r1l = r1.split("\r\n")
            r1s = r1l[0]
            r2 = serialport.readline()
            r2l = r2.split("\r\n")
            r2s = r2l[0]
            r3 = serialport.readline()
            r3l = r3.split("\r\n")
            r3s = r3l[0]
            r4 = serialport.readline()
            r4l = r4.split("\r\n")
            r4s = r4l[0]
            rnotaus = serialport.readline()
            rnotausl =  rnotaus.split("\r\n")
            rnotauss =  rnotausl[0]
            akku1 = serialport.readline()
            akku1l =  akku1.split("\r\n")
            akku1s =  akku1l[0]
            print m1s + ";" + m2s + ";" + r1s + r2s + r3s +r4s + rnotauss + "/" + akku1s + "\n"
            conn.send(m1s + ";" + m2s + ";" + r1s + r2s + r3s + r4s + rnotauss + "/" + akku1s + "\n")
            if not data:
                # Die Verbindung wurde getrennt
                # Abbruch
                serialport.close()
                break
            # Sende die Daten zurück zum client
    if __name__ == '__main__':
        main()
    hier der Bascom Code:
    $regfile = "m2560def.dat"
    $hwstack = 82
    $framesize = 68
    $swstack = 68
    $crystal = 16000000
    $baud = 19200
    '______Onboard-LED___________
    Config Pind.5 = Output
    Led Alias Portd.5
    '__________Relais _________
    Config Pina.0 = Output
    Relais1_l Alias Porta.0
    Config Pina.1 = Output
    Relais1_r Alias Porta.1
    Config Pina.2 = Output
    Relais2_r Alias Porta.2
    Config Pina.3 = Output
    Relais2_l Alias Porta.3
    '_________Motor Ports____________
    Config Pinl.1 = Output
    Motor1_reset Alias Portl.1
    Config Pinl.0 = Output
    Motor1_richtung Alias Portl.0
    Config Pinl.5 = Output
    Motor2_reset Alias Portl.5
    Config Pinl.4 = Output
    Motor2_richtung Alias Portl.4
    Config Pinl.2 = Input
    Pinl.2 = 1
    F1_m1 Alias Portl.2
    Config Pinl.3 = Input
    Pinl.3 = 1
    F2_m1 Alias Portl.3
    Config Pinl.6 = Input
    Pinl.6 = 1
    F1_m2 Alias Portl.6
    Config Pinl.7 = Input
    Pinl.7 = 1
    F2_m2 Alias Portl.7
    Config Timer5 = Timer , Prescale = 8                        'timer für Servos
    Enable Timer5
    Timer5 = 62535
    Config Portc = Output
    Portc.0 = 0                                                 'hier hängt servo1
    Portc.1 = 0                                                 'hier hängt servo2
    Portc.2 = 0                                                 'hier hängt servo3
    Portc.3 = 0                                                 'hier hängt servo4
    On Timer5 Servoirq
    Enable Interrupts
    Config Pine.5 = Input
    USB Alias Pine.5                                            'Ist 1 wenn USB angeschlossen
    Config Com4 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
    Open "com4:" For Binary As #4
    Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 256       ' PWM für Motor 1+2
    Enable Timer1
    Led = 0
    Motor1_reset = 1
    Motor2_reset = 1
    Dim I As Integer
    Dim Alarm As Byte
    Dim Test As String * 5
    Dim Pos1 As Byte
    Dim X As Integer
    Dim X_neu As Integer
    Dim Y As Integer
    Dim Y_neu As Integer
    Dim M1 As Integer
    Dim M2 As Integer
    Dim B1 As Integer
    Dim B2 As Integer
    Dim R1 As Integer
    Dim R2 As Integer
    Dim B3 As Integer
    Dim B4 As Integer
    Dim Notaus As Integer
    Dim Akku1 As Integer
    Dim Kanal As Byte
    Dim Servo(4) As Word
    Dim S1 As Word
    Dim S2 As Word
    Akku1 = 100
    Echo Off
    I = 0
    Servo(1) = 62535
    Servo(2) = 62535
    Servo(3) = 62535
    Servo(4) = 62535
    B1 = 0
    B2 = 0
    R1 = 0
    R2 = 0
    If Akku1 = 0 Then
    Akku1 = 100
    Else
    Akku1 = Akku1 - 1
    End If
    Alarm = F1_m1
    Alarm = Alarm + F1_m2
    Alarm = Alarm + F2_m1
    Alarm = Alarm + F2_m2
    Alarm = 0                                                   '    Fehlermeldungsproblem muss noch behoben werden!!!!!!
    If Alarm > 0 Then
    Else
    '__________Joystick Koordinaten lesen und verarbeiten_________
    Input #4 , Test
    Pos1 = Instr(test , "A")
    If Pos1 = 1 Then
    Input #4 , "" , X
    Input #4 , "" , Y
    Input #4 , "" , S1
    Input #4 , "" , S2
    Input #4 , "" , B1
    Input #4 , "" , B2
    Input #4 , "" , B3
    Input #4 , "" , B4
    Input #4 , "" , Notaus
     If Notaus = 0 Then
     Servo(1) = 61535 + S1
     Servo(2) = 63535 - S2
    If B1 = R1 Then
    Elseif B1 = 1 Then
    Relais1_r = 1
    Waitms 250
    Relais1_r = 0
    R1 = 1
    Elseif B1 = 0 Then
    Relais1_l = 1
    Waitms 250
    Relais1_l = 0
    R1 = 0
    End If
    If B2 = R2 Then
    Elseif B2 = 1 Then
    Relais2_l = 1
    Waitms 250
    Relais2_l = 0
    R2 = 1
    Elseif B2 = 0 Then
    Relais2_r = 1
    Waitms 250
    Relais2_r = 0
    R2 = 0
    End If
     If X < 0 Then
     X = 32767 + X
     X = X / 128
     Else
     X = 32767 - X
     X = X * -1
     X = X / 128
     End If
     If Y < 0 Then
     Y = 32767 + Y
     Y = Y * -1
     Y = Y / 128
     Else
     Y = 32767 - Y
     Y = Y / 128
     End If
    If Y > 0 Then
    If X < 0 Then
    X_neu = X * -1
    If Y > X_neu Then
    M1 = Y
    Else
    M1 = X
    M1 = M1 * -1
    End If
    Else
    M1 = Y - X
    End If
    Else
    If X > 0 Then
    Y_neu = Y * -1
    If Y_neu > X Then
    M1 = Y
    Else
    M1 = X
    M1 = M1 * -1
    End If
    Else
    M1 = Y - X
    End If
    End If
    If Y > 0 Then
    If X > 0 Then
    If Y > X Then
    M2 = Y
    Else
    M2 = X
    End If
    Else
    M2 = Y + X
    End If
    Else
    If X < 0 Then
    If Y < X Then
    M2 = Y
    Else
    M2 = X
    End If
    Else
    M2 = Y + X
    End If
    End If
    M1 = M1 / 2
    M2 = M2 / 2
    If M1 > 5 Then
    Motor1_richtung = 1
    Compare1a = M1
    Elseif M1 < -5 Then
    Motor1_richtung = 0
    Compare1a = -m1
    Else
    Compare1a = 0
    End If
    If M2 > 5 Then
    Motor2_richtung = 1
    Compare1b = M2
    Elseif M2 < -5 Then
    Motor2_richtung = 0
    Compare1b = -m2
    Else
    Compare1b = 0
    End If
    Else
    Compare1a = 0
    Compare1b = 0
    End If
    End If
    End If
    Print #4 , M1
    Print #4 , M2
    Print #4 , R1
    Print #4 , R2
    Print #4 , B3
    Print #4 , B4
    Print #4 , Notaus
    Print #4 , Akku1
    Servoirq:
    If Kanal = 0 Then
       If Portc.0 = 0 Then
          Timer5 = Servo(1)
          Portc.0 = 1
       Else
          Portc.0 = 0
          Incr Kanal
       End If
    End If
    If Kanal = 1 Then
       If Portc.1 = 0 Then
          Timer5 = Servo(2)
          Portc.1 = 1
       Else
          Portc.1 = 0
          Incr Kanal
       End If
    End If
    If Kanal = 2 Then
       If Portc.2 = 0 Then
          Timer5 = Servo(3)
          Portc.2 = 1
       Else
          Portc.2 = 0
          Incr Kanal
       End If
    End If
    If Kanal = 3 Then
       If Portc.3 = 0 Then
          Timer5 = Servo(4)
          Portc.3 = 1
       Else
          Portc.3 = 0
          Incr Kanal
       End If
    End If
    If Kanal = 4 Then
      Timer5 = 40000
      Kanal = 0
    End If
    Return
    End
    Das Problem ist was vom RN-Mega2560 kommt wird zwar richtig vom Server empfangen und richtig weiter an den Client gesendet, aber was an das RN-Mega2560 vom RPi gesendet wird, empfängt dieser wohl nicht richtig. Empfangen werden soll es "A" das klappt, dann x(0), y(0), s1(1000), s2(1000), b1(0), b2(0), b3(0), b4(0), bnotaus(0). Bei diesen Werten sollte zurückkommen m1(-255), m2(255), r1(0), r2(0), r3(0), r4(0), rnotaus(0), akku1(langsam von 100 bis 0 und dann wieder bei 100 anfangen). Wenn jetzt der Joystick neutral steht(x= 37268, y= 37268 und zurückkommen m1 = 0 m2 = 0) und das selbe bei den Buttons wenn 1 gesendet wird soll 1 zurückkommen.
    Mit dem alten vb.net Server hat das prima funktionier, hier mal der Code für den alten vb.net Server:
    Imports System.Text
    Imports System.Net.Sockets
    Imports System.Threading
    Imports System.IO
    Public Class Form1
        Dim X As String = "32767"
        Dim Y As String = "32767"
        Dim B1 As String = "0"
        Dim B2 As String = "0"
        Dim B3 As String = "0"
        Dim B4 As String = "0"
        Dim notaus As String = "0"
        Dim M1 As String = "0"
        Dim M2 As String = "0"
        Dim S1 As String = "1000"
        Dim S2 As String = "1000"
        Dim R1 As String = "0"
        Dim R2 As String = "0"
        Dim R3 As String = "0"
        Dim R4 As String = "0"
        Dim Rnotaus As String = "0"
        Dim Akku1 As String = "78"
        Dim port As Integer = 31415
        Dim tcpclient As TcpClient
        Dim tcplistener As New TcpListener(port)
        Dim networkstream As NetworkStream
        Dim streamw As StreamWriter
        Dim streamr As StreamReader
        Dim clientmessage As String
        Dim thread_server As System.Threading.Thread
        Private timer1 As New System.Timers.Timer
        Private timer2 As New System.Timers.Timer
        Dim down As Byte
        Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
            SerialPort1.PortName = TextBox1.Text
            SerialPort1.Open()
            Timer3.Start()
            Timer4.Start()
            TextBox1.BackColor = Color.Lime
            multi_server()
        End Sub
        Private Sub multi_server()
            thread_server = New System.Threading.Thread(AddressOf server)
            thread_server.Start()
        End Sub
        Private Sub server()
            tcplistener.Start()
            ListBox1.Items.Add("[SERVER]: ist ONLINE")
            ListBox1.SelectedIndex = ListBox1.Items.Count - 1
            Try
                tcpclient = tcplistener.AcceptTcpClient
                ListBox1.Items.Add("[CLIENT]: Connected")
                notaus = 0
                timer1.Start()
                timer2.Start()
            Catch ex As Exception
                MsgBox("FAIL_____FAIL_____FAIL")
            End Try
        End Sub
        Private Sub Timer_empfangen(ByVal sender As System.Object, ByVal e As System.Timers.ElapsedEventArgs)
    o:
            Dim pos5 As Integer
            Dim pos1 As Integer
            Dim pos2 As Integer
            Dim pos3 As Integer
            Dim pos4 As Integer
            networkstream = tcpclient.GetStream()
            Dim streamr = New StreamReader(networkstream)
            clientmessage = streamr.ReadLine()
            pos1 = InStr(1, clientmessage, ";")
            pos2 = InStr(1, clientmessage, ",")
            pos3 = InStr(1, clientmessage, "!")
            pos4 = InStr(1, clientmessage, "§")
            pos5 = InStr(1, clientmessage, "clientdown")
            If pos5 > 0 Then
                timer1.Stop()
                timer2.Stop()
                notaus = 1
                tcpclient.Close()
                ListBox1.Items.Add("[CLIENT]: has Disconnected")
                server()
                GoTo o
            Else
                X = Mid(clientmessage, 1, pos1 - 1)
                Y = Mid(clientmessage, pos1 + 1, pos2 - pos1 - 1)
                S1 = Mid(clientmessage, pos2 + 1, pos3 - pos2 - 1)
                S2 = Mid(clientmessage, pos3 + 1, pos4 - pos3 - 1)
                B1 = Mid(clientmessage, pos4 + 1, 1)
                B2 = Mid(clientmessage, pos4 + 2, 1)
                B3 = Mid(clientmessage, pos4 + 3, 1)
                B4 = Mid(clientmessage, pos4 + 4, 1)
                notaus = Mid(clientmessage, pos4 + 5, 1)
                TextBox2.Text = X & "/" & Y & "/" & S1 & "/" & S2 & "/" & B1 & B2 & B3 & B4 & notaus
                ListBox1.Items.Add("[CLIENT]: " + clientmessage)
            End If
        End Sub
        Private Sub Form1_FormClosend(ByVal sender As Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles Me.FormClosed
            tcpclient.Close()
            tcplistener.Stop()
        End Sub
        Private Sub Timer_senden(ByVal sender As System.Object, ByVal e As System.Timers.ElapsedEventArgs)
            Dim streamw = New StreamWriter(networkstream)
            TextBox5.Text = M1 & ";" & M2 & ";" & R1 & R2 & R3 & R4 & Rnotaus & "/" & Akku1
            streamw.WriteLine(M1 & ";" & M2 & ";" & R1 & R2 & R3 & R4 & Rnotaus & "/" & Akku1)
            streamw.Flush()
        End Sub
        Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
            Control.CheckForIllegalCrossThreadCalls = False
            AddHandler timer1.Elapsed, New System.Timers.ElapsedEventHandler(AddressOf Me.Timer_empfangen)
            timer1.Interval = 1
            AddHandler timer2.Elapsed, New System.Timers.ElapsedEventHandler(AddressOf Me.Timer_senden)
            timer2.Interval = 4
        End Sub
        Private Sub Timer3_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer3.Tick
            If SerialPort1.BytesToRead > 0 Then
                    M1 = SerialPort1.ReadLine()
                    M2 = SerialPort1.ReadLine()
                    R1 = SerialPort1.ReadLine()
                    R2 = SerialPort1.ReadLine()
                    R3 = SerialPort1.ReadLine()
                    R4 = SerialPort1.ReadLine()
                    Rnotaus = SerialPort1.ReadLine()
                    Akku1 = SerialPort1.ReadLine()
                    TextBox4.Text = M1 & ";" & M2 & ":" & R1 & R2 & R3 & R4 & Rnotaus & "/" & Akku1
                    If SerialPort1.BytesToRead = 0 Then
                        Exit Do
                    End If
            End If
        End Sub
        Private Sub Timer4_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer4.Tick
            TextBox3.Text = X & "/" & Y & "/" & S1 & "/" & S2 & "/" & B1 & B2 & B3 & B4 & notaus
            SerialPort1.Write("A")
            SerialPort1.Write(Chr(13))
            SerialPort1.Write(X)
            SerialPort1.Write(Y)
            SerialPort1.Write(S1)
            SerialPort1.Write(S2)
            SerialPort1.Write(B1)
            SerialPort1.Write(B2)
            SerialPort1.Write(B3)
            SerialPort1.Write(B4)
            SerialPort1.Write(notaus)
        End Sub
    End Class
    Private Sub Timer4_Tick ist der Teil in dem an das RN-Mega2560 gesendet wird und Private Sub Timer3_Tick wo die Daten vom RN-Mega2560 empfangen werden.
    Mfg McGrrizzly
    Bauderate mal angesehen?
    "serialport = serial.Serial("/dev/ttyUSB0", 9600)"
    "$crystal = 16000000 $baud = 19200"
    bauderaten dieser code vereinigt euch
    btw zum thema steuerung über website geht websocket (html5)gut, und für webcam soll mjpg_streamer gut gehen auch wenn ich noch probleme damit habe
    was gibt es noch zu sagen
    hi
    die Bauderate für USB wird aber hier definiert
    ok 4 hardware uarts auch gut
    wenn ich das so richtig verstanden habe lässt er sich auch darüber flashen (mit bootloader), muss man ihn dafür manuel reseten?
    beim arduino muss man dies nicht dies führt aber zu dem neben effekt das wenn der port geöffnet wird dieser ersteinmal reset wird (http://playground.arduino.cc/Main/Di...rialConnection)
    \r\n chr(13) + chr(10)
    im vb.net code
    oder hat SerialPort1.Write chr(10) automatisch angehängt?
    $baud würde ich trotzdem rausnehmen oder auch auf 9600 definieren
    ok
    wie soll ich den Code dann ändern
    so
    serialport.write(x + "\r\n" + chr(13) + chr(10))
    oder
    serialport.write(x + chr(13) + chr(10))
    oder
    serialport.write(x + "\r\n" + chr(10)
    ps: $baud wurde entfernt
    mach es doch wie im vb.net code
    serialport.write(x)
    serialport.write(chr(13))
    wenn es mit dem Bascom code so funktioniert hat, wobei es mich wundert, dass es den zeilenumbruch überhaupt braucht.
    edite
    bzw zu code auf seite 1 mit
    Test = Waitkey()
    vlt mal mit Waitkey(#4)
    Geändert von Thomas$ (07.08.2013 um 17:13 Uhr)
    Ok
    Danke hat geklappt
    edite
    Test = Waitkey()
    Upps
    Mfg McGrizzly
    | Mfg |
    | McGrizzly123 |
    Hab mal Motion ausprobiert hat mir aber eine zu große Zeitverzögerung
    bei mjpg_streamer bekomme ich folgende fehlermeldung
    pi@raspberrypi ~/mjpg-streamer $ mjpg_streamer -i "input_uvc.so -d /dev/video0" -o "output_http.so -p 8025 -y -w /usr/local/www"
    MJPG Streamer Version: svn rev: 3:172
    i: Using V4L2 device.: /dev/video0
    i: Desired Resolution: 640 x 480
    i: Frames Per Second.: 5
    i: Format............: MJPEG
    i: The format asked unavailable, so the width 640 height 472
    The inpout device does not supports MJPEG mode
    You may also try the YUV mode (-yuv option), but it requires a much more CPU power
    Init v4L2 failed !! exit fatal
    i: init_VideoIn failed
    ich kann mich der fehlermeldung nur anschliesen, soweit bin ich auch schon gekommen ^^
    mit fswebcam kann man zumindestens einzelbider machen, aber zum streamen die bilder immer auf der sdkarte speichern und über website aufrufen ist nun auch nicht das ideale
    Ach noch ne Frage ich bekomme zwar einen Mumble Server auf dem RPi insatlliert aber nicht den Clienten den einzigen Link den ich gefunden, der "is broken".
    Oder geht das überhaupt nicht.
    Ziel ist es wie zb. mit Teamspeak (server+Client auf Roboter +Client am SteuerPC) mit der Umgebung des Roboters kommunizieren zu können.
    Muss nicht mumble , hätte auch nichts gegen was anderes(freeware bitte).
    Mfg Mcgrizzly123
  1. RP6 mit Raspberry Pi
    Von ccontroller im Forum Robby RP6
    Antworten: 20
    Letzter Beitrag: 11.05.2018, 00:31
  2. [ERLEDIGT] Frequenzmessung mit dem Raspberry Pi
    Von Kampi im Forum Raspberry Pi
    Letzter Beitrag: 09.02.2013, 06:06
  3. Erster Roboter mit Raspberry Pi
    Von Zondan im Forum Allgemeines zum Thema Roboter / Modellbau
    Antworten: 11
    Letzter Beitrag: 17.10.2012, 12:32
  4. [ERLEDIGT] Problem mit GPIO beim Raspberry Pi
    Antworten: 19
    Letzter Beitrag: 25.08.2012, 18:49
  5. [ERLEDIGT] Webserver mit Raspberry Pi und Solarversorgung
    Von miicchhii im Forum Raspberry Pi
    Letzter Beitrag: 20.07.2012, 19:12
Stichworte
    Werbung      LiFePO4 Speicher Test
